post #1 of Old 12-18-2008, 08:01 PM Thread Starter
AlexTJ
Rockland Standard Gear/AISIN AX-15 "Terminator"
TERMINATORô
The TERMINATOR Jeep XJ & TJ Trans Upgrade
Jeep transmission upgrade for 2000-04 TJ and 2000-2001 XJ.
Jeep owners now have an alternative to the New Venture 3550 5-speed manual transmission found in 2000-2001 XJ and 2000-2004 TJ Wrangler six cylinder models. The NV 3550 is infamous for the rattling sound it makes in neutral, grinding on the 1-2 shift and jumping out of gear on deceleration.
To make matters even worse, New Venture Gear is out of business, and the only replacement parts are inferior offshore components, or used salvaged parts. Rockland Standard Gear's new 5-speed upgrade appropriately called "The Terminator" is a direct bolt-in replacement with more torque capacity for extreme duty, and for Jeeps with engine modifications.
The Terminator uses the stock shifter (and 4WD shifter) in its original location. OEM replacement parts are guaranteed to be available for the next 10 years, and RSG carries a complete inventory of parts and transmissions. Best of all, upgrading to the Terminator is very affordable and ensures that you will only need to make this fix once.
Editorial Comment:
On the trail, a manual transmission has many advantages and some disadvantages. One of those disadvantages would be crawling over a series of obstacles and having the transmission slip out of gear while both hands are on the steering wheel. Any improvement in keeping gears from jumping out of sync when you take your foot of the accelerator is definite advantage.
Rated up to 385ft*lbs
28% stronger than an NV3350 based on New Venture's numbers
AlexTJ is offline
post #2 of Old 12-18-2008, 08:07 PM Thread Starter
AlexTJ
(I had military discount, I believe they are about 1700 or so)
I decided on the terminator after my old AX-15 ate itself behind my stroker.
The increased torque capacity over even a NV3550 sold me, sure its not a NV4500 but it bolts right in. And it was not too crazy on my wallet.
I believe they used the Toyota gear set in the Jeep case that added the extra strength.
Did I mention it shifts reeeeeallly smooooth
AlexTJ is offline
post #3 of Old 01-20-2009, 04:44 PM
bfolla06
stock............................................. ...........................
bfolla06 is offline
post #4 of Old 02-21-2010, 09:25 PM
dethomas07
OEM not much else to say!
dethomas07 is offline
post #5 of Old 04-30-2013, 02:08 PM
DocMicro
Solid Reliable Transmission. Re-build able, parts kit available online.
A lot of throw in the stick, brass gets out of sync easy. Hard to find transmission but as I said above.
DocMicro is offline
post #6 of Old 11-18-2015, 04:06 PM
Gainer
Gainer's Avatar
I have had this transmission for about 3 years. It has been great and gets better with use. It was a little "tight" when first installed. Has never given me any cause for concern.
Gainer is offline
post #7 of Old 12-17-2015, 08:04 PM
slayer9019
I had purchased this trans to hopefully upgrade my jeep. It was whining horribly from the factory and now they are fighting on the warrenty! This thing has 20 miles on it!! I have to say this is the WORST customer service I have ever had. The guy who works on the tranmissions said there is no way his trans is bad from the factory. AVOID AT ALL COSTS!
slayer9019 is offline
post #8 of Old 03-21-2016, 11:10 AM
txmjpunisher
Does the NV 3550 bellhousing bolt up to this transmission?
txmjpunisher is offline
Aisin-Warner - Ax-5 Mediarocker Transmissions 15 04-06-2013 09:12 AM
Royal Purple Max-Gear 75W-90 wrangler_usmc Transmissions 3 03-25-2010 05:05 PM
You may not post new threads
You may not post replies
