post #1 of Old 10-24-2011, 08:39 PM Thread Starter
TexJeepTJ
Best stuff around for your manual transmission TJ.
Jeep (Chrysler) says you don't have to service your NV3550 manual transmission ever, but those of us who know better know better.
Red Line MTL smooths out the annoying hard 1-2 and 2-3 shift, especially in colder weather. It also quieted down the higher-rev 1st gear rattle in my TJ, but that was probably due to the prior owner having never serviced the tranny in 100k miles.
Good stuff - check out the reviews and experiences of others on the forum posts (that where I found out to do it). You'll make your Jeep Happy (and you too on those cold mornings).
Click image for larger version
TexJeepTJ is offline
post #2 of Old 10-24-2011, 09:35 PM Thread Starter
TexJeepTJ
Smooths out the dreaded cold-weather 2-3 shift and prevents excessive wear in the transmission. Jeep FSM says the tranny is "serviced for life" but after changing the fluid at 100K miles, it made a world of difference.
post #3 of Old 05-29-2012, 01:38 PM
0424Jeep
just put the stuff in seems to work great
0424Jeep is offline
post #4 of Old 07-20-2012, 10:50 PM
97JeepZJ5spd
Best oil I ever used/seen. I will NOT go to any other oil. Only will use Amsoil MTG, ONLY OF NO ACCESS TO REDLINE MT-90 GL-4.
97JeepZJ5spd is offline
You may not post new threads
You may not post replies
