Go Back JeepForum.com > Reviews > Transmissions > Transmissions > B&M 70268 Supercooler
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREELifetime LED on Sale at Baseline 4x4 Outfitters LED Light Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
B&M 70268 Supercooler Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transmissions Next Product
Rating: None
Product Information
MSRP: $49.95
Average Price: $52.31
Manufacturer: B&M
Recommended?
Yes: 3 / No: 0
Company Website: http://www.bmracing.com/PRODUCTS/Automatic-Transmission-SuperCoolers/Automatic-Transmission-SuperCooler-rated-at-13-000-BTU-11x7-1-2x3-4
Automatic Transmission SuperCooler rated at 13,000 BTU 11"x7-1/2"x3/4"
* Stacked Plate design
* ‘Low Pressure Drop’ feature
* All aluminum construction
* Oven brazed construction
* Small & efficient design
* Includes installation kit
* 3/4” thinline coolers are ideal for tight fit locations
* 3/8” extended nipple fittings providing improved hose & clamp contact
B&M SuperCoolers are 100% aluminum construction and use stamped plates sandwiched together to create one of the most efficient oil cooling devices available. Not only does this unique design provide for maximized cooling through more efficient heat dissipation but it also provides a much sturdier cooler which is practically impervious to flying rocks or other debris. The Super-Coolers intended for automatic transmission fluid also offer an additional feature known as “Low Pressure Drop”. The coolers assembled with hose barb ends include a unique bypass feature allowing a controlled amount of ATF to bypass the stacked plate core when the fluid is cold. This is beneficial in cold climate areas to guard against lube system failure. Controlled by viscosity, fluid is returned directly to the lube circuit through bypass openings in the stacked plate core. As the temperature increases, more ATF is directed through the core. This highly efficient design combines improved protection against lube system failure with the required levels of optimal heat transfer.
None
brand0nlp
brand0nlp's Reviews
10-30-2009, 10:13 PM
Price: $60.00
Pros: much larger than stock,
Cons: none
Recommended? Yes
Comments: great upgrade, much better than the stock unit, also removing the radiator cooling lines helped
RichN
RichN's Reviews
08-29-2009, 11:17 PM
Price: $46.99
Pros: Cooler transmission fluid!
Cons: None
Recommended? Yes
Comments: Recommended by just about everybody here, I pull a trailer from time to time and my Jeep didn't come from the factory with the towing (external cooler, hitch, etc.) package. This was the smart thing to do.
GregB_00XJ
GregB_00XJ's Reviews
06-12-2009, 02:21 AM
Price: $49.95
Pros: excellent quality, ease of installation, good documentation, great functionality and looks
Cons: None?
Recommended? Yes
Comments: So far so good....
This B&M Trans cooler was easy to install, and is working great. No leaks, no fuss, came with many options for install and the fit and finish are superb. Can not recommend this enough!
Jeep Parts at Andy's
