Go Back JeepForum.com > Reviews > Transmissions > Transmissions > Aisin-Warner - Ax-5
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Aisin-Warner - Ax-5 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transmissions Next Product
Aisin-Warner - Ax-5
Rating:
Product Information
MSRP: $1,595.00
Average Price: $83,333,975.42
Manufacturer: Aisin-Warner
Recommended?
Yes: 6 / No: 6
Company Website: http://www.aisin.com
The Aisin Warner AX5 transmission was a standard shift, five-speed transmission introduced in the 1984 XJ Cherokee Jeep, and found in the 1984 to 2006 Jeep XJ, YJ & TJ models. It is a light-duty transmission found behind the AMC 150 (2.5L) I4 engine. It was also found behind the GM 2.8L 60 degree V6 (early XJ only).
The AX5 is prevalent, but sadly it's strength is minimal, making it a questionable off-road transmission. Failures behind even stock engines are not uncommon.
The AX5 is a split-case, top shifting, overdrive transmission with the shifter being located in the rear section of the transmission. The AX5 is fully synchronized in all gears. All gears are helically cut.
The AX5 transmission case is 15-5/8" long. It features a cast aluminum case with a cast-iron mid-plate. The case is ribbed and features the shifter in the rear quarter of the assembly. In the vein of newer transmissions, the AX5 uses dowel pins for bellhousing alignment.
The Jeep AX5 has a 21 spline output shaft for connecting to the transfer case input shaft. The AX5 was used with an internal slave/throwout assembly up through the 1994 model year. In 1995, a more conventional slave cylinder and cross-arm were used. The input shaft is a 14 spline and its stickout length is 7-1/2".
The AX5 looks similar to the AX15 and are they are occasionally confused in identification as well as interchange.
The Jeep AX5 was factory-married to the Jeep Jeep New Process (aka New Venture) Model 231 transfer case.
91YJShag
91YJShag's Reviews
10-11-2011, 03:06 PM
Price: $1.00
Pros: stock
Cons: stock
Recommended? No
Comments: It shifts...
Utfan010
Utfan010's Reviews
12-25-2010, 11:13 AM
Price: $1.00
Pros: good transmission
Cons: none
Recommended? Yes
Comments: its a jeep transmission couldn't get any better
tater_kamik
tater_kamik's Reviews
07-27-2010, 09:54 PM
Price: $3,200.00
Pros: na
Cons: na
Recommended? Yes
Comments: filling in my info, why do I have to do a review on stock?
iiizman
iiizman's Reviews
06-24-2010, 12:06 PM
Price: $1.00
Pros: none
Cons: light
Recommended? No
Comments: wish i had an ax15 with external slave, but maybe next year
mikecrts
mikecrts's Reviews
06-11-2010, 09:52 PM
Price: $1,000,000,000.00
Pros: None
Cons: Easy to break.
Recommended? No
Comments: Not the best but it works.
n6ey
n6ey's Reviews
06-09-2010, 09:44 AM
Price: $2,500.00
Pros: It's a transmission...
Cons: ...it's not a great transmission.
Recommended? Yes
Comments: It's a transmission. You need one. They're not impossible to rebuild - own one long enough and you'll find out.
distncernr
distncernr's Reviews
06-08-2010, 05:22 PM
Price: $999.00
Pros: great transmission,
Cons: none
Recommended? Yes
Comments: transmission running strong still. I would recommend it
theducksguts
no whiners!
theducksguts's Reviews
03-17-2010, 01:29 PM
Price: $0.01
Pros: It works fine.
Cons: 21 spline, Light duty manual transmission.
Recommended? No
Comments: It is what it is. Comes with most 2.5L YJ's and TJ's. 21 splines on the output shaft. The AX-15 has 23 spline.
dethomas07
dethomas07's Reviews
02-21-2010, 10:30 PM
Price: $1.00
Pros: stock
Cons: none
Recommended? Yes
Comments: not much to say OEM!
crzylgzz
crzylgzz's Reviews
12-08-2009, 11:33 AM
Price: $1,000.00
Pros: can be found in most street level tranny repair shops and magazines at a reasonable price.. why?? see the cons.
Cons: Everything.
Recommended? No
Comments: this is a class "A" piece of S@*T tranny that fails Alot...
The 15 is a stronger and all around better made transmission but unfortunately isnt designed or prescribed for the 4 banger YJ's. that is unless you do a few mods here and there. if they could only design a simpler case to match up with the YJ, life would be a whole lot better.
cubewhiz
cubewhiz's Reviews
09-28-2009, 03:09 PM
Price: $1.00
Pros: Smooth
Cons: More to be desired
Recommended? Yes
Comments: Came stock on my YJ. Not a great transmission, but it does what it needs to. I will probably change the transmission eventually, but for now, this one is okay.
Mediarocker
Mediarocker's Reviews
08-29-2009, 02:26 AM
Price: $1.00
Pros: Its a Transmission It works
Cons: Weak Pops out of gear easily
Recommended? No
Comments: This transmission came stock on my Jeep Wrangler. I'm unsatisfied with its performance and lack of 6th o/d gear. (which the 4 banger DESPERATELY NEEDS.) Its strength is questionable and is always scary to try anything technical with it.
ThreadForumRepliesLast Post
Borg-Warner Borg-Warner T150 Transmissions 3 11-23-2009 09:20 AM
Borg-Warner T-18A Transmissions 6 05-29-2009 01:59 PM
borg-warner T-5 Transmissions 3 05-06-2009 07:12 PM
Rockland Standard Gear/AISIN AX-15 "Terminator" Transmissions 2 01-20-2009 05:44 PM
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
