Go Back JeepForum.com > Reviews > Transfer Case > Transfer Cases > #SK2XC Cable Shifter Assembly for 231/242
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
#SK2XC Cable Shifter Assembly for 231/242 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transfer Cases
Rating: None
Product Information
MSRP: $167.00
Average Price: $177.50
Manufacturer: Novak Conversions
Recommended?
Yes: 2 / No: 0
Company Website: http://www.novak-adapt.com/index.htm
This is probably the best upgrade I have done to the Cherokee so far. It replaces the ridiculous factory shift linkage with a cable like the one Jeep used to shift the AW4. I always questioned what gear I was truly in with the factory setup, it felt very clunky, loose, and ultimately a broken bushing in it resulted in a busted 231 t-case when it failed to shift all the way back down to 2WD and I drove it on pavement.
If you're tired of having that question in your mind "Is it in or out?" this is your answer. It also retains the stock shift handle.
$185 shipped from their place in Utah to me in Pennsylvania.
None
Jeeper4life88
Jeeper4life88's Reviews
12-30-2012, 01:31 AM
Price: $180.00
Pros: Easy to install, and shifts great!
Cons: I can't think of any!
Recommended? Yes
Comments: I bought this product after becoming fed up with my stock linkage on my 97 TJ. Before purchasing this Novak cable shifter I was a little worried about being able to install it myself. However once the kit came, I looked over everything and got it done! The instructions are very helpful, its pretty simple to install and get adjusted. Just make sure your shifter lever in the Jeep is in the same mode that you have the transfer case in and you should be golden!
cfmiller58
cfmiller58's Reviews
02-03-2012, 07:05 AM
Price: $175.00
Pros: Can install and TT or BL without every have to worry about adjusting linkage again. Very easy install.
Cons: None
Recommended? Yes
Comments: Shifts like butter, highly recommended. Nothing else needs to be said.
ThreadForumRepliesLast Post
Skyjacker T-Case Shifter Bracket Transfer Cases 4 06-20-2009 07:48 AM
Jeep Parts at Andy's
