Notices
New Process NP 231 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transfer Cases Next Product
New Process NP 231
Rating:
Product Information
MSRP: $749.00
Average Price: $10,661.13
Manufacturer: New Process
Recommended?
Yes: 104 / No: 7
AKA NP 231 J
None
Page 5 of 6 1 2 3 4 5 6 > Last
PackDude
PackDude's Reviews
08-16-2009, 11:48 PM
Price: $1,025.00
Pros: Heavy duty chain and gears All new parts
Cons: No "2 low" mode
Recommended? Yes
Comments: I decided to get a SYE to correct the slight vibes in my drive shaft since doing a 2" OME lift. But since the SYE kits by themself are upwards of $300, I figured what the heck, spend another $600 and get a heavy duty NP231 to boot.
Researching the various options, it looked to me like the JB Conversions HD NP231 with their super short SYE was the way to go. It's got a wider chain, a planetary gear with 6 helical gears instead of 3, and all the parts are brand new, not refurbs.
The folks at JBC are very professional and had the unit built and delivered within a few weeks. The unit was packaged very well for the several thousand mile freight trek from Louisiana to Washington State.
So far, no leaks or anything. It bolted right in, and worked from the get go. It came from the factory with the studs attached in a ziploc bag. The studs are kind of hard to install, but I guess they didn't want them poking holes through the shipping crate or getting bent in transit.
I will give the transfer case a 5 star rating unless something happens to it! I am planning to install a Super 35 30-spline rear axle with Detroit locker, and an upgraded front differential, so my Jeep can actually handle what this transfer case can dish out.
iowaneedshills
iowaneedshills's Reviews
08-05-2009, 11:43 PM
Price: $0.10
Pros: came with the jeep, hasn't broken yet
Cons: slip yoke, chain drive, 2.72:1 Low range, Gear driven speedometer signal
Recommended? Yes
Comments: This is the transfer case that comes in about every jeep. Works pretty well.
Oaktree
Oaktree's Reviews
07-29-2009, 08:31 PM
Price: $300.00
Pros: pretty much a stock transfer case.
Cons: nothing is wrong with it
Recommended? Yes
Comments: its alright. the NP 231 is pretyt much the stock transfer case that a wrangler comes with.
dajeepman
dajeepman's Reviews
07-26-2009, 12:33 PM
Price: $1.00
Pros: It came with the JEEP
Cons: Not low enough stock
Recommended? Yes
Comments: This is the Factory T case that comes with most XJ's
kurt13r
kurt13r's Reviews
07-15-2009, 06:54 AM
Price: $700.00
Pros: Works like it should
Cons: ?
Recommended? Yes
Comments: Never had an issue putting it in 4x4. Works good.
skip-yj
skip-yj's Reviews
07-01-2009, 09:11 PM
Price: $111.00
Pros: never failed me. and easy to take apart
Cons: ......
Recommended? Yes
Comments: very good. and veerryyy universal. never failed me.
compcrasher86
compcrasher86's Reviews
05-18-2009, 11:07 PM
Price: $1.00
Pros: Its pretty sick and shifts really well, 4low sounds and feels great. Good to be able to switch into 2wd when you need it
Cons: No 4wd Fulltime so you absolutely can not use 4wd on dry paved surfaces, and unlike the QD in the new Jeep Grand Cherokees, it is hand shift and not electric shift... but hey, its a Jeep, make a sacrifice for many benefits
Recommended? Yes
Comments: I like it alot but I miss the 242 that I had in my ZJ because this one can only use 4wd as you need it and will not automatically kick in like the 4fulltime on the ZJ does. Oh well, its a Jeep
Dmax5er
Dmax5er's Reviews
05-17-2009, 11:10 AM
Price: $3,000.00
Pros: Built heavier than stock.
Cons: none yet
Recommended? Yes
Comments: bought with my trans as a kit from mantrans, its is now a NP231JHD and working great .
ncsmokeeater
ncsmokeeater's Reviews
03-09-2009, 03:53 PM
New Process NP 231
Recommended? Yes
Comments: Got issues that I'm not sure of. I like it but there are some kinks I'd like worked out. The stock chain and sprockets SUCK.
mj-jeeper
mj-jeeper's Reviews
03-05-2009, 06:38 PM
New Process NP 231
Recommended? Yes
Comments: NP231 - "Command-Trac" part-time only - 2.72:1 ratio low range - shift pattern 2H - 4H - N - 4L
bignateb
bignateb's Reviews
03-05-2009, 08:08 AM
New Process NP 231
Recommended? Yes
Comments: Great. only had some problems with oil leaking out of it due to some cracks but that was the way that I bought it so it will be fixed soon
ckhanna71
ckhanna71's Reviews
03-04-2009, 10:48 AM
New Process NP 231
Price: $500.00
Recommended? Yes
Comments: REPLACED THE INPUT SHAFT TO MATE UP TO THE TH700R4 TRANSMISSION FROM ADVANCE ADAPTERS
abbottg
Junior Member
abbottg's Reviews
02-28-2009, 11:18 PM
New Process NP 231
Price: $200.00
Recommended? Yes
Comments: Made the upgrade with the AX15. Had to make some linkage, but otherwise good piece. Wish I had the SYE. Maybe for Christmas
laurxj
laurxj's Reviews
02-22-2009, 12:25 AM
New Process NP 231
Recommended? Yes
Comments:
lostincanada
lostincanada's Reviews
02-17-2009, 10:58 PM
New Process NP 231
Price: $1.00
Recommended? Yes
Comments: not bad... rather an atlas gear drive 4 to 1 ratio... but have 2 more spares before i think i will bauy another one..
cdsmith_2002
cdsmith_2002's Reviews
02-14-2009, 08:22 PM
New Process NP 231
Recommended? Yes
Comments:
badlands1
badlands1's Reviews
01-25-2009, 08:14 PM
New Process NP 231
Recommended? Yes
Comments: Tride and true t-case.Always been good to me with all my xj's...Nice to beable to put it in on the fly..
cademan04
cademan04's Reviews
01-22-2009, 08:50 PM
New Process NP 231
Recommended? Yes
Comments: i was told i should get a jeep with the 231, so thats what i got. i like it so far. however, i have nothing to compare it to.
River Ryder
River Ryder's Reviews
01-12-2009, 05:30 PM
New Process NP 231
Recommended? Yes
Comments: It never given me a problem pretty reliable. Easy to Service and upgrade. Parts are also readily available.
Ron Farrell
Ron Farrell's Reviews
12-26-2008, 11:41 PM
New Process NP 231
Price: $600.00
Recommended? Yes
Comments: no problems with the NP 231. One tough, bullet proof transfercase for what we use them for. Trouble free and easy to work on on the trail or back at the parking lot.
ThreadForumRepliesLast Post
NEW PROCESS GEAR NP242 Transfer Cases 27 08-06-2016 01:22 AM
New Process NP249 Transfer Cases 27 12-04-2014 11:22 AM
