New Process NP 231
Rating: |
Product Information
| MSRP: |
$749.00 |
| Average Price: |
$580.57 |
| Manufacturer: |
New Process |
| Recommended? |
93zjer's Reviews
Price: $1.00 Pros: better than my 249! Cons: none. Recommended? Yes
Comments: great t-case. missed having it in my current zj so i had to swap out the 249.
Desert_Rampage's Reviews
Price: $1.00 Pros: It's a New Process. Cons: Not that I can find. Recommended? Yes
Comments: Great t-case. Well worth its weight in gold.
Flyboy161's Reviews
Price: $1,000.00 Pros: A sturdy little unit Cons: Good ratio, works well Recommended? Yes
Comments: Well, what can I say. It functions well. It's not geared super low, but honestly I think 2.72 to 1 is low enough.
SwampFox375's Reviews
Price: $1.00 Pros: good Cons: none Recommended? Yes
Comments: don't know much about it. it's stock.
Price: $1.00 Pros: Its's New Process!! Cons: None Recommended? Yes
Comments: Never had a problem. It's a NP! Best company out there.
scotts_sahara's Reviews
Price: $400.00 Pros: It makes 4 wheels spin Cons: Sometimes not all 4 wheels spin Recommended? No
Comments: I feel it is a weak t case. Im not happy with it, i have broke alot of things in it. A NP205 is much stronger and will be my next one,
uplandhawaii's Reviews
Price: $20.00 Pros: bolt in swap Cons: should have done an SYE at the same time as the swap. Recommended? Yes
Comments: Swapping to the 231 certainly made the 5.9 more fun to drive! I can smoke the rear tires instantly!
mike_breaker_5's Reviews
Price: $200.00 Pros: easy to work on, simple construction. Cons: comes stock with a slip yoke. Recommended? Yes
Comments: stock x-case was replaced with another. it has taken all the abuse i have thrown at it. we will see how long it lasts behind my 5.2.
wjjeep4x4's Reviews
Price: $1.00 Pros: Has put up with my abuse over 180K Cons: Does not have Full-time Recommended? Yes
Comments: I have had no issues with my NP 231. Had supported my Jeep lifestyle and has yet to let me down.
suzukirm's Reviews
Price: $1.00 Pros: good in winter time Cons: sometimes if not all the way in gear, when driving u will hear ticking from the transfer case Recommended? Yes
Comments: good t case overall. i dont do offroad to much just use my 4wd in the winter time in bad weather conditions and it handles my driving conditions just fine
Juha's Reviews
Price: $300.00 Pros: Part-time 4WD, good on paved roads Cons: can't drive in 4H on dry pavement, ok by me. Recommended? Yes
Comments: The Quadra-drive transfer case in my Jeep went at 80K. I was told that they were filled with the wrong fluid at the factory, and the previous owner never changed the fluid. I replaced it with heavy duty 231. South bay driveline (San Jose,CA) has built a custom driveshaft for this application. The Jeep spends most of its life on dry pavement, so it lives in 2WD most of the time. It's quite a bit more fuel efficient in 2WD. I still have the 4WD when I need it, for example for winter skiing trips. Overall, I highly recommend this conversion if you live in California or a place with similar climate. If I lived up north, I'd probably want full-time 4WD.
XJhank's Reviews
Price: $0.01 Pros: works Cons: none Recommended? Yes
Comments: came with the jeep stock. better than the 242 i dont know what else to say
UnlWrnglr's Reviews
Price: $20,000.00 Pros: Provides power to my front driveshaft. I'm a big fan of 4wd. And the capability for front wheel drive incase of problems. Cons: Could be deeper. Recommended? Yes
Comments: Came stock with the Jeep. Pretty deep, not the deepest. Pretty beefy, not the beefiest.
JeepTJMike's Reviews
Price: $1.00 Pros: stock Cons: stock Recommended? Yes
Comments: what do you expect
deerassassin22's Reviews
Price: $1.00 Pros: stock ON JEEP Cons: Came with jEEP Recommended? Yes
Comments: Stock on Jeep ON MUCH LONGER DOES IT NEED BE
YJoe1993's Reviews
Price: $250.00 Pros: TORQUE Cons: nothing Recommended? Yes
Comments: Great T-case with the AX15 and 4.0L engine
pkoehrer's Reviews
Price: $12.00 Pros: strong and works better than my junk 249. basic tcase Cons: doesnt work with VIC in my zj Recommended? Yes
Comments: replaced my locked 249 with this works well
captainauti's Reviews
Price: $1.00 Pros: np231cj bolted to my 4l60e and still allowed use of stock drive shafts Cons: none Recommended? Yes
Comments: whats there to review..... this is stooopid.
Dasbrick's Reviews
Price: $1.00 Pros: Part time Cons: part time Recommended? No
Comments: works. full time for winter would be nice, but thats just a luxury
