Jeep Rubicon NV241OR
Rating: |
Product Information
| MSRP: |
$32,000.00 |
| Average Price: |
$7,581.84 |
| Manufacturer: |
Jeep Rubicon |
| Recommended? |
Transfer case from the Rubicon model.
04goldrubi74's Reviews
Price: $1.00 Pros: great t-case, smooth operation, always goes right to 4WD-H-L-N-2WD, Cons: none as far as i have experienced Recommended? Yes
Comments: great t-case, smooth operation, always goes right to 4WD-H-L-N-2WD, never any problems with any thing
NOUNOURS_GLAD65's Reviews
Price: $600.00 Pros: GOOD FOR OFF-ROAD, 4-1 LOW RANGE. Cons: AIR HOSE TO PROTECT FROM ROCK AND BRANCHES. Recommended? Yes
Comments: GOOD FOR THE PRICE COMPARE TO A ATLAS. ROCK TRAC HAS 4-1 LO RANGE ENOUGH FOR MOST TRAIL APPLICATION.
camera-man's Reviews
Price: $13,900.00 Pros: this gives a lower gear than the 2:1 from the other jeeps Cons: linkage when lifted. Recommended? Yes
Comments: the only thing better than this would be a dana 300, atlas, or stak. this thing is tough and durable.
TJamie's Reviews
Price: $900.00 Pros: Great low range Cons: can be a little difficult to stuff under an older TJ Recommended? Yes
Comments: This t-case is a beast. It's slow, it's durable, and it bolted right up to my 2000 nv3550 (only needed a pigtail for 4wd light). The t-case skid needed a little help, and the shifter linkage bound up, but the work was totally worth it. I swapped the linkage for a Novak cable shifter, no problems since.
catalog's Reviews
Price: $23,000.00 Pros: low gearing and strong Cons: gearing can be to low at times Recommended? Yes
Comments: nice that it came with SYE on it from factory. Love the 4:1 low at times. makes sticking with 4.10 axles and 35's livable BUT in mud and on hill climbs I gotta shift to much to get any speed up them.
kyjeep98's Reviews
Price: $1.00 Pros: 4 to 1 Cons: None Recommended? Yes
Comments: Love the OR vs the standard transfer case. Make your crawl ratio awesome for stock Jeep.
omgwtfbbqcopter's Reviews
Price: $1.00 Pros: Very low low-ratio for rock crawling. Cons: None listed Recommended? Yes
Comments: The transfer case was on the vehicle when I purchased it. Seeing how it's a 2004 Rubicon model, it already has the 4:1 transfer case. I like the super low low-ratio gearing of the TC, since it will come in handy for off roading.
Josephus's Reviews
Price: $4,500.00 Pros: Rubicon Cons: none. Recommended? Yes
Comments: I really appreciate teh ability to crawl over obstacles with ease.
Only downside is non-Rubicon Jeepers badger me on the trail for "taking too long"... get over it (literally).
snakesolds's Reviews
Price: $1.00 Pros: low gear is killer shift on the fly high torque capacity Cons: none Recommended? Yes
Comments: awesome t-case
shockwave562's Reviews
Price: $2,000.00 Pros: excellent gearing for off road, plus no slip yoke Cons: no real disadvantages. best transfer case you can get in a jeep Recommended? Yes
Comments: the pros say it all. i switched from a sahara to a rubicon and the difference on the trail is drastically improved over the NV241 Command-Trac
cglez81's Reviews
03-16-2009, 09:16 AM |
Recommended? Yes
Comments: Well as far as the transfer case it self, it seems fine, but as others have experienced as well the transfer case cable is junk. Seems like a weak design. I'm sure its made that way for some purpose, but I broke one and the dealer broke the another and it hasn't even been off road yet. So have lost a bit of confidence on that part.It can easily leave you stranded if you can't get underneath to move the transfer case manually.
CamposZJ's Reviews
02-21-2009, 03:38 PM |
Price: $600.00 Recommended? Yes
Comments:
jetguy81's Reviews
01-16-2009, 03:56 PM |
Recommended? Yes
Comments: ???not really sure yet??? I've heard good things tho.
aw12345's Reviews
12-31-2008, 04:16 AM |
Price: $750.00 Recommended? Yes
Comments: I run a terralow and so far it has served me very well love that little box makes rock crawling so much easier
05jeeper's Reviews
12-18-2008, 10:55 PM |
Price: $14,000.00 Recommended? Yes
Comments: 4 to 1 case is the bomb. Wish cable driven twin stick was available. Someone get busy with this request than PM me.
goodnuff_17's Reviews
12-12-2008, 05:34 AM |
Recommended? Yes
Comments: really ow torque works great shifts smooth and supposibly supposed to be tough.
2003RubiBlue's Reviews
12-02-2008, 06:36 PM |
Price: $30,000.00 Recommended? Yes
Comments: Awesome low range. I love the 4:1 reduction. This transfer case rocks.
abeshures's Reviews
11-11-2008, 07:24 PM |
Price: $1.00 Recommended? Yes
Comments: one of the best transfer cases around. i love the fact that it comes stock with a fixed yoke cant go wrong with this
BIGET's Reviews
10-11-2008, 05:15 PM |
Price: $1,100.00 Recommended? Yes
Comments: What can I say, OMG - 4:1 crawl. Love the lack of slip yoke!!. Easy swap to 03 TJ
