Jeep NV242 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transfer Cases Next Product
Jeep NV242
Rating:
Product Information
MSRP: $400.00
Average Price: $931.30
Manufacturer: Jeep
Recommended?
Yes: 21 / No: 2
The NV242 provides full time 2-wheel, or 4-wheel drive operation. A differential in the transfer case is used to control torque transfer to the front and rear axles. A low range gear provides increased low speed torque capability for off road operation. The low range provides a 2.72:1 reduction ratio
The 2WD and 4x4 full time ranges can be used at any time and on any road surface. The 4x4 part-time and 4 Lo ranges are for off road use only. The only time these ranges can be used on hard surface roads, is when the surface is covered with snow and ice.
None
Page 1 of 2 1 2 > Last
wj_2000blk
wj_2000blk's Reviews
02-15-2017, 01:23 AM
Price: $200.00
Pros: haven't installed
Cons: n/a
Recommended? Yes
Comments: So far haven't put it on yet just waiting til I have time
Spoonman275
Spoonman275's Reviews
01-28-2016, 04:49 PM
Price: $999.00
Pros: NA
Cons: NA
Recommended? Yes
Comments: AWESOME JEEP PART
ZJay1998
ZJay1998's Reviews
08-08-2015, 09:01 PM
Price: $150.00
Pros:  Easy to work on and install
Cons: None to think of.
Recommended? Yes
Comments: I bought this at a local junk yard for a good deal. Decided to swap out my 249 and install this one. Once back at my shop i took apart. Make sure you have a great set of snap ring pliers (wide ones would help). Once I installed my input gears I was ready to build it back together. Id say if you dont have a photographic memory take pictures of everything. I remembered how to installed from memory. Im only 18 and if i can do Im sure any one can do it that has some type of mechanical skill.
scross1220
scross1220's Reviews
04-26-2013, 07:55 PM
Price: $700.00
Pros: Works great
Cons: none
Recommended? Yes
Comments: Happy with it. Works great.
STORM_JK
STORM_JK's Reviews
04-23-2013, 11:37 PM
Price: $150.00
Pros: Strong, 5 selectable ranges
Cons: None
Recommended? Yes
Comments: I6 242 in my V8, just needed to swap input shafts. Not front shaft yet so can't test.
1996ZJI-6
1996ZJI-6's Reviews
03-03-2013, 10:01 PM
Price: $1.00
Pros: came with the jeep.
Cons: gets stuck in part time 4wd
Recommended? No
Comments: has a hard time going back into 2wd. so its an okay transfer case.
JimmydaGreek
JimmydaGreek's Reviews
02-05-2013, 02:13 PM
Price: $400.00
Pros: I now have 2wd option
Cons: None
Recommended? Yes
Comments: The 242 Selectrac allows 2wd now along with all time 4x4, N, 4H and 4L. Perfect!
mackcs212
mackcs212's Reviews
08-05-2012, 01:49 PM
Price: $109.00
Pros: has 2wd, 4 full, 4 part and 4 low
Cons: non yet
Recommended? Yes
Comments: swapped my 249 for 242 and never want to go back. no more getting under vehicle to remove/install front drive shaft.
97JeepZJ5spd
97JeepZJ5spd's Reviews
07-21-2012, 12:48 AM
Price: $12,345.00
Pros: Aweosme, great selection
Cons: Nothing, just a high low range.
Recommended? Yes
Comments: I love this t-case beacuse of all the options and it is really heavy. 2HI, 4HI PART-TIME, 4HI FULL-TIME, NEUTRAL, 4LO. The low range is 2.73:1. I wold like 4:1 or at very least 3:1.
kirbyZJORVIS
kirbyZJORVIS's Reviews
07-08-2012, 04:04 PM
Price: $660.00
Pros: Great I now have 2wd thank god. Thanks JRMechanic.
Cons: None
Recommended? Yes
Comments: JrMechanic does what he says. Direct bolt on easy install.249/242 swap.
94zj318
94zj318's Reviews
02-09-2012, 09:09 PM
Price: $250.00
Pros: always in 4wd, reliable, hardworking
Cons: no 2wd mode
Recommended? Yes
Comments: Quadra-Trac works great. However, I wish it could be shifted out of 4WD sometimes for more performance. SelecTrac allows you to do this, however, Quadra-Trac does not.
EisBlade
De Oppresso Liber
EisBlade's Reviews
12-06-2011, 10:00 AM
Price: $600.00
Pros: One of the best Jeep transfer cases out there. Offers the following modes: 2 Wheel High 4 Wheel Part Time 4 Wheel Full Time 4 Wheel Lo
Cons: None
Recommended? Yes
Comments: An outstanding combination with this t/c would be quadra-drive axles for better capability offroad in a stock-type configuration.
straightZJ6
straightZJ6's Reviews
09-20-2011, 03:14 PM
Price: $1.00
Pros: very strong
Cons: it gets stuck in part time 4wd
Recommended? No
Comments: its a strong and good reliable transfercase but i gets stuck in 4wd part time for some reason
justn
justn's Reviews
04-20-2011, 03:13 PM
Price: $1.00
Pros: Selec-Trac
Cons: Finicky about sifting out of 4 sometimes
Recommended? Yes
Comments: Gets the job done. Won't be changing it out anytime soon.
adam03wj
adam03wj's Reviews
01-05-2010, 01:36 PM
Price: $100.00
Pros: many options
Cons: hangs low
Recommended? Yes
Comments: great transfer case, gives you the option to shift into 2wd as well, which is great for gas mileage and road driving.
fizzer
fizzer's Reviews
09-15-2009, 11:11 PM
Price: $400.00
Pros: Can switch gears on the fly
Cons: Got stuck in 4WD part time once
Recommended? Yes
Comments: This is a great transfer case. The only problem i had with it was it got stuck in 4WD part time once but it got fixed on its own.
soulfinger
soulfinger's Reviews
09-12-2009, 10:13 PM
Price: $800.00
Pros: full-time and part-time 4wd
Cons: low range could be lower
Recommended? Yes
Comments: it is what it is
jere34
jere34's Reviews
08-19-2009, 09:25 PM
Price: $60.00
Pros: 2wd
Cons: information centr issues
Recommended? Yes
Comments: love having 2wd t-case is out of an older xj so ther is some info center issues.....
MustangJAB02
MustangJAB02's Reviews
03-25-2009, 02:20 PM
Jeep NV242
Price: $300.00
Recommended? Yes
Comments: It is the stock 242 select trac but that is what was in it and I like the selection that I have with it. Needed replacing.
bushwacked
bushwacked's Reviews
02-23-2009, 09:35 PM
Jeep NV242
Recommended? Yes
Comments: its stock and has not broke on me yet .
