Notices
JB Custom Fabrication LLC - Dana 300 Twin Stick Shifters Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transfer Cases Next Product
Rating:
Product Information
MSRP: $99.00
Average Price: $115.13
Manufacturer: JB Custom Fabrication LLC
Recommended?
Yes: 8 / No: 0
Company Website: http://www.jbfab.net/
Quote and Picture taken directly from JB Fab's website:
Stainless steel twin-stick shifter Made for the Jeep Dana 300 transfer case (5/8" pivot bolt) This transfer case shifter is made specifically to replace the stock shifter. You won’t have the problems with our D-300 shifters that you will with "one size fits all" erector set lookin' twin-stick shifters that puts the shifter handles up under your dash! These shifters are designed to be rock-solid you won't find any "one size fits all" brackets held together with ny-lock nuts that are not designed for heat. We use only, all metal, mechanical self-locking hardware. This shifter comes with installation / adjustment instructions, boot, stainless steel trim ring, shift pattern decal, and even stainless steel screws to finish it off! Note: Not all installations / applications are the same, some floor trimming or shifter adjustment might be necessary. MADE IN THE U.S.A.
None
Travcall
Travcall's Reviews
05-08-2017, 02:47 PM
Price: $160.00
Pros: All stainless steel construction Made in the USA Quality welds and hardware
Cons: None
Recommended? Yes
Comments: Could not be happier with the JB Fab twin sticks. Quality welds and hardware, plus made in the USA. Solid product and strong design.
You can contact Jon and have custom shift sticks made up to an additional 6" in length.
I went with an additional 4" on my set up and it worked out perfect. I did not have to modify the shift sticks. I did add some tub clearance, but not much.
Great product!
Biggun113
Biggun113's Reviews
08-17-2014, 01:39 PM
Price: $108.00
Pros: High Quality, super easy to install
Cons: none as of yet
Recommended? Yes
Comments: I just bought these, they seem exceptionally well made and include everything you could possibly want in a neat kit form. I am extremely satisfied with how easy it was to install this kit, the bending of the levers is probably the hardest part and that isn't even that hard to do. Pulling off stock parts takes longer than the entire install, but plan to drop your transfer case crossmember down some to get the mounting bolt to clear the tub if you don't have a body lift on your rig.
adjective
adjective's Reviews
05-27-2014, 10:02 AM
Price: $106.00
Pros: Easy to install. Works well once installed, great visual indicator of drive status. I used the etched shifter knobs and they look great.
Cons: The main bolt the shifters pivot on was too large for the mount on the transfer case. Had to replace it with a thinner one. Simple trip to the hardware store but would have been annoying if I had no transportation.
Recommended? Yes
Comments: The hardest part of this install was getting the old and supremely rusted single stick assembly out. Had to finally remove the cross member and drop the transfer case down a few inches to be able to reach everything. It took an angle grinder and a lot of torching to get the parts out. The install was much easier, but required a different sized pivot bolt. The one that came with the kit was too large for the holes it had to pass through, by about 1mm. Once installed, the shifters work very well. I'm pleased with the product and the hassle of getting the old stuff out was a good opportunity to change fluids and paint the cross member.
Ruthless1
Ruthless1's Reviews
03-25-2014, 10:47 AM
Price: $140.00
Pros: I like the smooth shift I get over the stock
Cons: Wouldn't mind seeing the kit offered in black vs raw stainless to match my trans shifter and maybe a little taller
Recommended? Yes
Comments: Excellent product for the price! Its made a lot better than other kits and I recommend springing for the billet knobs
spottedfrog
spottedfrog's Reviews
08-13-2013, 07:10 PM
Price: $109.00
Pros: Very good quality, allows flexibility, and makes it easier to shift the T-case.
Cons: Might have to mod your Trans tunnel.
Recommended? Yes
Comments: Good product
jamesdart
jamesdart's Reviews
07-19-2013, 03:44 PM
Price: $100.00
Pros: very nice materials
Cons: they didn't offer a kit to fit my application, so I bought a "weld your own" kit
Recommended? Yes
Comments: very nice materials used In the kit, came with everything. the billet knobs add a nice touch
titomars
titomars's Reviews
10-02-2010, 11:59 AM
Price: $99.00
Pros: excellent construction nice heavy duty boot simple hook up
Cons: i had to reverse some of the hardware to fit my taste where the sticks end up. but not really a con. the sticks are a bit short to me.
Recommended? Yes
Comments: excellent well thought out product. everything you need comes with it. stainless for the win. with my install i had to reverse and re-drill the collars that mount on the shift rods to get the sticks to point straight up in neutral. no big deal. just my personal preference. once installed they work perfectly.
the sticks seem too short to me but i just made 2 inch extensions for them. i also purchased their billet knobs those also were very high quality and compliment the sticks
JeepnBlake
JeepnBlake's Reviews
10-05-2009, 01:29 AM
Price: $99.00
Pros: Excellent Product, Great Quality.
Cons: Slight fitment may be needed.
Recommended? Yes
Comments: Install was easy instructions were clear. Installation can vary, my tub needed a little modification because of the body lift.
100% worth the time and money.
ThreadForumRepliesLast Post
Dana Spicer Dana 300 Transfer Cases 31 10-14-2013 10:10 PM
Tom Wood's Custom Driveshafts 242 SYE kit SYE Kits 5 12-06-2012 08:01 PM
Tom Wood's Custom Drive Shafts 242 SYE kit SYE Kits 4 09-29-2012 08:15 PM
Tom Wood's Custom Drive Shafts 231 Super-Duty Tail Shaft Conversion SYE Kits 21 01-18-2012 09:54 AM
JB Custom Fabrication LLC - Dana 20 Twin Stick Shifters Transfer Cases 1 10-04-2009 11:19 PM
