Notices
JB Custom Fabrication LLC - Dana 20 Twin Stick Shifters Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transfer Cases Next Product
Rating:
Product Information
MSRP: $109.00
Average Price: $112.58
Manufacturer: JB Custom Fabrication LLC
Recommended?
Yes: 1 / No: 0
Company Website: http://www.jbfab.net/
Picture and the following description are taken straight from JB Fab Website:
This shifter fits the Jeep CJ transfer case that has the stock shifter mounted about 7 in front of the transfer case, and a straight shift pattern, typicly a 4-speed application. Does not fit J series, Wagoneer, Cherokee, Commando / Jeepster. Allows independent operation of front and rear drive. (completely independent with removal of internal shift interlock pills) Stainless steel twin-stick shifter Made for the Dana Jeep CJ Dana-20 transfer case This transfer case shifter is made specifically to replace the stock shifter. BEWARE OF ONE SIZE FITS ALL shifters, there are 7 different configurations of Jeep D-20 cases / shifter combinations, unless you want to cut new holes in your floor, make sure you get a shifter that is built for your setup. Our shifters mount to your stock mounting bracket eliminating most of the locating issues with custom shifters. These shifters are designed to be rock-solid, you won't find any ny-lock nuts that are not designed for heat. We use only, all metal, mechanical self-locking hardware. This shifter comes with installation / adjustment instructions, boot, stainless steel trim ring, shift pattern decal, and even stainless steel screws to finish it off! Note: Not all installations / applications are the same, a little floor trimming or shifter adjustment might be necessary. MADE IN THE U.S.A. It offers short throw shifting, and rock solid feel due to the heavy stainless stock used to construct the shifter. This shifter comes with adjustable linkage made from stainless threaded rod, and quality metal rod ends.
None
JeepnBlake
JeepnBlake's Reviews
10-05-2009, 01:19 AM
Price: $112.58
Pros: Excellent Product, Great Quality.
Cons: Slight fitment may be needed.
Recommended? Yes
Comments: Install was easy instructions were clear. Installation can vary, my tub needed a little modification mainly because it's tweaked.
Bought mine for $99.00 and shipping was $13.58.
100% worth the time and money.
ThreadForumRepliesLast Post
JB Custom Fabrication LLC - Dana 300 Twin Stick Shifters Transfer Cases 8 06-03-2016 11:41 PM
Dana Spicer Dana 300 Transfer Cases 31 10-14-2013 11:10 PM
Tom Wood's Custom Driveshafts 242 SYE kit SYE Kits 5 12-06-2012 09:01 PM
Tom Wood's Custom Drive Shafts 242 SYE kit SYE Kits 4 09-29-2012 09:15 PM
Tom Wood's Custom Drive Shafts 231 Super-Duty Tail Shaft Conversion SYE Kits 21 01-18-2012 10:54 AM
