Go Back JeepForum.com > Reviews > Transfer Case > Transfer Cases > Advanced adapters Atlas II
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Advanced adapters Atlas II Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Transfer Cases Next Product
Rating:
Product Information
MSRP: $2,421.23
Average Price: $2,417.40
Manufacturer: Advanced adapters
Recommended?
Yes: 14 / No: 0
Atlas II 3.8:1 2-speed
daveshan
Feeding the money pit
daveshan's Reviews
09-25-2010, 11:00 AM
Price: $2,100.00
Pros: It's an Atlas what's to say ;-) I got it free from the '09 Jeep Safari but the site wouldn't let me put in 0.00
Cons: Tight fit with a 33 engineering skid even with a bit of work with the BFH on the tub. Not really a con but the only one I could think of.
Recommended? Yes
Comments: Well worth the work to install, and the cost of 2 new driveshafts and the cable shifters. The ability to have 2lo and front wheel only is a big plus in the areas I wheel. Front only allows re-positioning on waterfalls which came in handy a couple of times in the first few outings, 2lo is great on slickrock.
TurdyFive
That'll do pig.
TurdyFive's Reviews
08-01-2010, 02:37 PM
Price: $2,300.00
Pros: Bomb proof. Great quality. Built to my spec's. It's an Atlas!
Cons: Took a looooong time to receive, but I guess that's to be expected from a build-to-order company that puts so much emphasis on quality.
Recommended? Yes
Comments: Advanced Adapter's not only make THE best transfer cases in the world, they are also a class act. Two weeks after I ordered my Atlas II, Advanced had a 10% off sale. I called to ask if I could get in on the reduced price. No problem. They credited me back $23 on the spot.
Jeepme2
Jeepme2's Reviews
06-28-2010, 11:58 AM
Price: $2,900.00
Pros: love the options of many gear choices at your finger tips.
Cons: spendy but you get what you pay for
Recommended? Yes
Comments: I have the 4 speed with the 10.34 low range.One of the best upgrades i have done and ive done alot.
punty
punty's Reviews
06-23-2010, 11:11 PM
Price: $3,400.00
Pros: Great selection of gear ranges
Cons: Price
Recommended? Yes
Comments: Atlas 10.4:1 4 speed transfer case. One of the best upgrades I've done
bstewart91yj
bstewart91yj's Reviews
06-21-2010, 11:59 AM
Price: $3,550.00
Pros: everything
Cons: nothing
Recommended? Yes
Comments: It's actually a 4-speed Atlas. It has ratios 1:1, 2.72:1, 3.8:1, and 10.34:1. What else needs to be said?
95JPYJ
95JPYJ's Reviews
04-22-2010, 08:27 AM
Price: $2,200.00
Pros: The ability to switch the front and rear diffs in and out of 4x4
Cons: none
Recommended? Yes
Comments: I have never had one before i was going to build a dana 300 twin stick till i compared the price and talked to a few people. I have only wheel it once and it was cool to use.
hotelconucc93
hotelconucc93's Reviews
04-16-2010, 09:00 AM
Price: $2,000.00
Pros: HD output front and rear 32 spline,
Cons: size and retrofit
Recommended? Yes
Comments: Fairly easy to install if you have 1"mml and 1" bl in a yj. best to have body off during a rebuild if you can do it. Requires multiple test fits, and some pan mods. I had to cut my shifter tunnel and reweld new plates.
Great case.
punty
punty's Reviews
03-10-2010, 09:41 PM
Price: $3,000.00
Pros: Great gear selection, 2 LOW
Cons: Price
Recommended? Yes
Comments: Installed the Atlas 4 speed 10:1 transfer case in flat rotation for more clearance, should have come from the factory this way.
SlinkyTJ
This space for rent.
SlinkyTJ's Reviews
04-06-2009, 08:21 AM
Price: $2,300.00
Recommended? Yes
Comments: The install was a bit more complicated than I originally though, but well worth it. The lower gears are great for crawlin' and the added manueverability with the twin sticks is great. As an added plus... front digs are just cool.
stjjames
stjjames's Reviews
12-25-2008, 12:56 PM
Price: $1,000.00
Recommended? Yes
Comments: Well - I hear its awesome.
We shall see as soon as my rigs rolls again. I am certainly looking forward to it.
KMAfabrication
KMAfabrication's Reviews
10-11-2008, 12:09 AM
Recommended? Yes
Comments: Awesome product, you can't get any better than an Atlas. There product is superior and there customer service is phenominal.
wroose
wroose's Reviews
10-06-2008, 12:39 AM
Price: $1,995.00
Recommended? Yes
Comments: just got it and i don't know if i like ti yet but i sure i will 4.3 is 50% lower than my stock 2.72 to 1
Jim93YJ
Jim93YJ's Reviews
07-25-2008, 02:48 PM
Price: $2,421.23
Pros: All gear driven goodness, 4.3:1 low range, Independent Axle Control
Cons: If anything the weight and size
Recommended? Yes
Comments: Just installed the Atlas but from the install everything went well. The key I think is on your end getting the shifters setup correctly. I am fully confident that AA took care of their end in terms of putting together a great transfer case....hopefully the last one I will ever need.
EDIT: Have been using it and WOW the 4.3:1 ratio is awesome and it drives GREAT!! IMO it was worth the money.
apexjeepinjoe
apexjeepinjoe's Reviews
06-12-2008, 07:47 PM
Price: $2,260.00
Recommended? Yes
Comments: What can I say. This case kicks butt!! If you got the money get one. Add the cable shifter and rock on.
ThreadForumRepliesLast Post
Advance Adapters Drive Shaft Angle Reduction Kit (Slip Yoke Eliminator) SYE Kits 78 12-06-2011 11:20 PM
Advanced Adapters/Tom Woods NP231 SYE Kit w/ drive shaft SYE Kits 23 03-04-2011 08:48 AM
Advanced Adapters Transfer case Linkage bracket Transfer Cases 5 12-02-2010 09:20 AM
advance adapters atlas 2/II 5.0 Transfer Cases 6 01-13-2009 06:00 PM
Glock Forum
