Notices
rugged ridge - sye Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product SYE Kits Next Product
rugged ridge - sye
Rating: None
Product Information
MSRP: $1.00
Average Price: $234.03
Manufacturer: rugged ridge
Recommended?
Yes: 29 / No: 2
bought this sye kit from just jeeps in toronto and is very easy to install, except for the fact you have to cut a bit of the shift fork to make it work other then that very good instructions...
sye kit
Page 1 of 2 1 2 > Last
Theman1945
Theman1945's Reviews
10-01-2016, 06:44 PM
Price: $220.00
Pros: Does everything it needs to; easy to install
Cons: none
Recommended? Yes
Comments: This SYE kit does everything it needs to and nothing less. Have yet to have any problems with it. Install was just as easy as any other SYE kit, and it costs a bit less than some of the others.
Bobby6319
Bobby6319's Reviews
12-27-2015, 12:27 PM
Price: $275.00
Pros: Wasn't to exspesive
Cons: Seal started leaking early on matey didn't get it lubed enough I got the kit with the cv shaft
Recommended? Yes
Comments: If you are going to do the install you will need a really good set of snap ring pliers I fought with them for hours before borrowing a set of snap on and only took like seconds after that
john02tj
john02tj's Reviews
05-09-2015, 12:08 AM
Price: $350.00
Pros: does its job
Cons: Bad seal, speedo wont sit properly
Recommended? No
Comments: After a long install by me and a friend we sealed it up and found there is a bit of play in and out and the seal is bad and mist fluid all over everying, i dont need the mist due to living in Az where i dont have to worry about rust!
Dmarkowski
Dmarkowski's Reviews
02-28-2015, 01:53 PM
Price: $250.00
Pros: Easy install
Cons: plastic speedometer insert on spline
Recommended? Yes
Comments: pretty good for the price
ryanmylenek
ryanmylenek's Reviews
12-30-2014, 06:12 PM
Price: $189.99
Pros: Decent price and has held up well.
Cons: None so far
Recommended? Yes
Comments: Excellent product with a decent price range. Had held up well during wheeling.
johnnykind
johnnykind's Reviews
12-08-2014, 03:16 PM
Price: $300.00
Pros: easy to install, fixed a lot of issues with drive line noise and vibrations
Cons: cant think of any
Recommended? Yes
Comments: installed in about 2 hours with normal tools, came with new HD drive line, may need axle wedges to adjust pinon angle after install or before lifting
hookerstj98
hookerstj98's Reviews
02-09-2014, 02:02 PM
Price: $250.00
Pros: simple, easy to install, cheap-ish, very strong
Cons: none.
Recommended? Yes
Comments: definitely worth it if you are building on a budget.
kssig1
kssig1's Reviews
01-06-2014, 09:07 PM
Price: $200.00
Pros: Works well
Cons: None
Recommended? Yes
Comments: Works well so far. Easy to install. Instructions very basic but I know how to work on these so that was not a problem for me.
matt001122
matt001122's Reviews
12-15-2013, 12:51 PM
Price: $150.00
Pros: Got it on sale
Cons: None so far
Recommended? Yes
Comments: It's a SYE kit, lets you put in a CV rear driveshaft so that you can lift your transfercase when you lift your Jeep, instead of spacing it lower.
SandyBottoms
SandyBottoms's Reviews
09-23-2013, 10:26 AM
Price: $210.00
Pros: great price
Cons: none to date
Recommended? Yes
Comments: Had this installed and haven't had a single problem to date. Worked for me.
Meighty8
Meighty8's Reviews
07-24-2013, 02:22 PM
Price: $190.00
Pros: EXCELENT QUALITY. NO MORE DRIVE LINE VIBES. DEPENDABLE 4WD
Cons: HAD TO MODIFY AND CUT SHIFT LEVER ON OLDER STYLE CASE.
Recommended? Yes
Comments: HAVE HAD IT ON FOR 2 YEARS NOW NO LEAKS OR NOISES RUNS AND SHIFTS PERFECT. HEAVY DUTY SHORTER OUTPUT SHAFT AND LONGER DRIVE SHAFT MAKE HUGE DIFFERENCE IN RIDE QUALITY.
AlphaLorde
AlphaLorde's Reviews
07-07-2013, 06:54 PM
Price: $145.00
Pros: Easy to install
Cons: Rear seal leaks had to buy a different seal
Recommended? No
Comments: I was happy at first with the price and everything.
But with the rear seal leaking, the speedo pinion housing seems to stick out some I would have spent more money on a different kit with no problems.
swissmike
swissmike's Reviews
02-17-2013, 12:37 AM
Price: $245.00
Pros: Have not installed yet
Cons: None yet
Recommended? Yes
Comments: Have not installed yet
Jims-87YJ
Jims-87YJ's Reviews
11-06-2012, 11:06 AM
Price: $240.00
Pros: Good kit for the price
Cons: Poor Instructions
Recommended? Yes
Comments: For the cost this seems to be a great kit so far. I was disappointed in the lack of instructions, Could have been more detailed and a few more "clearer" pictures. Definitely take the Transfer-case out I could not see trying to do this with it in.
martinbuilt
martinbuilt's Reviews
06-30-2012, 01:43 PM
Price: $225.00
Pros: this is the way to go with any lift 4" or more
Cons: none
Recommended? Yes
Comments: Excellent product easy to install, can be done without removing the transfer case.
MuscleHead
MuscleHead's Reviews
01-29-2012, 10:56 PM
Price: $150.00
Pros: Easy install
Cons: None
Recommended? Yes
Comments: Very easy to install but instruction included give vague pictures. Used a few writeups and a club member to install.
JohnnyFlyinRyan
JohnnyFlyinRyan's Reviews
09-02-2011, 05:59 PM
Price: $350.00
Pros: Its an SYE!
Cons: none yet
Recommended? Yes
Comments: Got the double cardigan drive shaft and SYE through Adams Driveshaft, waiting to install.
Trombly
Trombly's Reviews
08-17-2011, 03:02 PM
Price: $300.00
Pros: awesome
Cons: none
Recommended? Yes
Comments: sweetness easy to do
02tjsport
02tjsport's Reviews
05-08-2011, 05:39 PM
Price: $200.00
Cons: Needed a big set of snap ring pliers which I didn't know until I was already in to it
Recommended? Yes
Comments: Easy to install I have no problems yet
Erik87yj
Erik87yj's Reviews
04-21-2011, 03:05 PM
Price: $400.00
Pros: very easy to put in!
Cons: had to cut shift fork bar. I was a little uneasy to go cutting on a part like this but all went well!
Recommended? Yes
Comments: The rugged ridge sye kit also came with a custom fit Adams driveshast . Seems to be very heavy duty compared to factory. All in all seems well worth the money.
