Go Back JeepForum.com > Reviews > Transfer Case > SYE Kits > Rubicon Express Part #RE1807 (Hack and Tap)
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Rubicon Express Part #RE1807 (Hack and Tap) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product SYE Kits Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $156.54
Manufacturer: Rubicon Express
Recommended?
Yes: 13 / No: 0
The RE1807 SYE requires the modification of your stock output shaft. Drill and tap included for easy installation. Drive flange is machined from solid Stainless Steel for extreme strength and corrosion resistance.
APPLICATION:
1996 and newer NP231 transfer cases.
Components
DS 2-70-18X ~ SYE YOKE STRAP KIT
HW2020 ~ USS THRU HD 1/2 WASHER
HW5005 ~ INTERNAL RING 1 7/16
HWC10040 ~ BAG KIT # 14--RE1801-RE1807
RE-INSTRUCTIONS ~ INSTRUCTION SHEET
RM11510 ~ SYE CV FLANGE--4 BOLT STAINLES
dwharton
dwharton's Reviews
05-03-2011, 08:39 PM
Price: $100.00
Pros: ,
Cons: ,
Recommended? Yes
Comments: ,
Crusher16
Crusher16's Reviews
02-14-2011, 07:55 PM
Price: $180.00
Pros: Cheap, works
Cons: Leaks slightly
Recommended? Yes
Comments: Install is easy and instructions are very understandable. Once I got mine installed, after a few days of running it, it has developed a very very slow leak.
RCGJ
SoCal Lost Jeeps Member
RCGJ's Reviews
02-06-2011, 04:50 PM
Price: $430.00
Pros: Relieved the noise in the drive shaft after installing my 3.5 inch lift.
Cons: none
Recommended? Yes
Comments: None
Lyonsa80
Junior Member
Lyonsa80's Reviews
01-02-2011, 08:41 PM
Price: $115.00
Pros: Much less expensive than a full SYE kit. Simple and straight forward to install. Functional and tough. Long-lasting. Reasonably priced.
Cons: None.
Recommended? Yes
Comments: Another quality product by R.Express. I have had this hack and tap system installed on my XJ for 3 years now and have had NO issues with it whatsoever. It helped cure my driveshaft vibrations (plus a degree shim under leaves and a custom RE driveshaft), and has lasted through all my abuse. Great product. Solid construction. Would recommend to anyone that doesn't want to dump $400ish bucks on a SYE kit that they don't really need. Unless you're going to professionally crawl...buy this instead.
keaton
keaton's Reviews
04-03-2010, 02:31 PM
Price: $200.00
Pros: Its an sye..enough said lol
Cons: None.
Recommended? Yes
Comments: Does what an sye is supposed to do. Good quality stuff.
brand0nlp
brand0nlp's Reviews
12-15-2009, 11:51 AM
Price: $110.00
Pros: great overall pretty easy install
Cons: none yet
Recommended? Yes
Comments: i bought there product, it was the logical way to go for now i like how easy it was to install little bit of time but easy over all.
jeepmansro
jeepmansro's Reviews
10-15-2009, 07:34 PM
Price: $100.00
Pros: Easy to install
Cons: None
Recommended? Yes
Comments: Simplest SYE to install and just as strong!! Probably one of the best and healthiest mods you can do for your lifted Jeep.
XJdesertrider
XJdesertrider's Reviews
07-24-2009, 12:23 AM
Price: $200.00
Pros: -cheap and simple to install
Cons: -uses stock output shaft
Recommended? Yes
Comments: came with CV driveshaft, bits, and tap, and not to mention saved $$
just don't screw up while drilling/tapping and it should work just fine
Calvin9r
Come out and play.
Calvin9r's Reviews
09-12-2008, 03:58 PM
Price: $100.00
Recommended? Yes
Comments: Simple and easy to install. Clear instructions. 1st install of this type and had no problems.
mavrick480
mavrick480's Reviews
07-17-2008, 09:06 AM
Price: $100.00
Recommended? Yes
Comments: This was the easiest install i have ever done and the thing works great no vibes at all. Used a ZJ Front drive shaft.
UNCC_99XJ
UNCC_99XJ's Reviews
07-04-2008, 12:35 AM
Price: $200.00
Recommended? Yes
Comments: RE 1807 with a front shaft out of a 98 AW4. Lovin every minute of it! Price paid includes SYE Kit, Front Shaft, Spicer adapter, and new u-joints all the way around.
teamviper7242
teamviper7242's Reviews
06-30-2008, 07:58 PM
Price: $100.00
Recommended? Yes
Comments: Very Easy to Install. Product is still holding up after 6 months of abuse. If I had to do it all over again I would still buy this product
XTC Jpr13
XTC Jpr13's Reviews
05-08-2008, 09:36 PM
Price: $100.00
Recommended? Yes
Comments: Very easy install, and allows you to run a double carden shaft. A very inexpensive way to get and sye done!
ThreadForumRepliesLast Post
Jeep Rubicon NV241OR Transfer Cases 17 12-04-2009 01:50 PM
Rubicon Express SYE KIT, HEAVY DUTY NP231 ONLY RE:1811 SYE Kits 6 11-15-2009 11:47 PM
Glock Forum
