OMIX-ADA Mega Short SYE NP231J Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product SYE Kits Next Product
Rating: None
Product Information
Average Price: $224.50
Manufacturer: OMIX-ADA
Recommended?
Yes: 2 / No: 0
DESIGNED TO WORK WITH ALL WRANGLERS AND This kit is a MUST if you installed a 2" or taller XJ CHEROKEES WITH AN ELECTRONIC SPEEDOMETER suspension lift in your 1987-2006 Jeep« Wrangler (not needed for body lifted Jeeps«). The kit fits all newer production NP 231 transfer cases (1987- up). A Slip Yoke Eliminator Kit (SYE) will eliminate the need to drop your transfer case in order to avoid drive train vibrations that are caused by taller suspension lift. The purpose of this kit is to replace the slip yoke portion of the NP 231 with a fixed yoke and CV-style drive shaft assembly. This is the most complete and strongest kit available. The Mega Short SYE (18676.72) is designed to be used in the same lift applications as the other standard SYE kit (2" and up). The main advantage to the new Mega Short SYE kit is that it allows for a much longer drive shaft to be used (additional 3"). This reduces the angle of the dive shaft and in turn improved bearing and u-joint life, reduces driveline vibrations caused by lifted Jeeps« running short drive shafts. It also has a shorter and stronger main shaft design
None
92yjbeastjeep
92yjbeastjeep's Reviews
10-17-2013, 08:26 PM
Price: $250.00
Pros: Greatly reduced driveline angle and removed every drop of vibration
Cons: non yet
Recommended? Yes
Comments: This is a must have for lifted jeeps. if you have any driveline vibration save headache and time and money and just install a sye kit.
chopperkid2000
chopperkid2000's Reviews
06-23-2011, 03:47 PM
Price: $199.00
Pros: Shipped with Rc lift kit. All shipping was near nothing.
Cons: None so far.
Recommended? Yes
Comments: It is what it is.
ThreadForumRepliesLast Post
JB Conversions NP231J HD Super Short SYE SYE Kits 20 10-16-2015 11:31 AM
JB Conversions NP231J - HD Standard Length SYE SYE Kits 15 05-18-2015 11:32 AM
J.B. Conversions Inc. NP231 HD w Super Short SYE SYE Kits 10 04-26-2015 06:08 PM
