Go Back JeepForum.com > Reviews > Transfer Case > SYE Kits > Advanced Adapters/Tom Woods NP231 SYE Kit w/ drive shaft
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Advanced Adapters/Tom Woods NP231 SYE Kit w/ drive shaft Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product SYE Kits Next Product
Rating:
Product Information
MSRP: $875.00
Average Price: $499.09
Manufacturer: Advanced Adapters/Tom Woods
Recommended?
Yes: 53 / No: 0
This kit is a Slip Yoke Eliminator from Advanced Adapters and a new Tom Woods Drive Shaft.
None
Page 1 of 3 1 2 3 > Last »
justin89
justin89's Reviews
02-22-2013, 05:39 PM
Price: $600.00
Pros: Great Kit
Cons: Lack of intructions
Recommended? Yes
Comments: Tom woods DS are the **** comes with everything and fully greased to the max, AA SYE was great and pretty easy to install minus some set backs caused by my self
valco63
valco63's Reviews
09-15-2012, 11:10 PM
Price: $500.00
Pros: Easy to install in your garage, more solid connection from T-case to Diff.
Cons: none yet
Recommended? Yes
Comments: I broke my slip yoke on my first outing, cost me nearly $1500 between towing and repairs. Now I know I have a better system with the Advanced Adapters SYE and a Tom Woods CV Shaft, but I'm still cautious.
Rocker33
Rocker33's Reviews
08-16-2012, 12:35 PM
Price: $450.00
Pros: top quality parts, east install
Cons: make sure you have correst ds lenght
Recommended? Yes
Comments: I would recommend this set up as it is easy to install and is top quality
jonji01
jonji01's Reviews
05-18-2012, 11:45 AM
Price: $525.00
Pros: great service
Cons: none
Recommended? Yes
Comments: highly recommended
bmpage84
Junior Member
bmpage84's Reviews
04-14-2012, 01:08 AM
Price: $472.50
Pros: Eliminated all driveline vibrations created by the 4" lift. Eliminated the need for the T/C drop and relocation brackets and returned everything back to stock locations.
Cons: NONE
Recommended? Yes
Comments: Fairly easy install. I did remove the T/C from the Jeep to do it, was much eaiser out on the bench. Customer service from Tom Woods was A+++. Had a few questions on the driveshaft and he was very quick to respond with any help and answers needed!
offroadjunkie95
offroadjunkie95's Reviews
04-10-2012, 04:06 PM
Price: $1,000.00
Pros: Fixes driveline angle problems
Cons: ???
Recommended? Yes
Comments: Don't really know what to say about this product except no binding issues and no transfer case blowouts so it must do its job
JohnnieBulge
JohnnieBulge's Reviews
03-18-2012, 07:34 PM
Price: $500.00
Pros: none
Cons: none
Recommended? Yes
Comments: I really cant state anything about it just other than it keeping the angles correct and avoiding the transfer case drop. cost extra but I feel it was worth it.
ZHamashin
ZHamashin's Reviews
02-22-2012, 05:36 PM
Price: $460.00
Pros: No vibrations!
Cons: None so far.
Recommended? Yes
Comments: So far, I'm very impressed with the SYE/DS. Good quality and fixed my vibration problem. I have a Dana 44 from an old CJ that has the pumpkin off center to the passenger side about 3 inches. Also the brackets that were welded on were positioned for a different TJ which I believe had a higher lift than mine. Was causing some serious vibration problems (enough to break a universal joint). This kit fixed the problem.
brian0128
brian0128's Reviews
01-21-2012, 03:49 PM
Price: $505.00
Pros: Quality workmanship.
Cons: Expensive.
Recommended? Yes
Comments: I bought the kit directly from Tom Woods. He had it delivered in 3 days. Very happy with the product.
kphimself
kphimself's Reviews
01-02-2012, 12:08 AM
Price: $400.00
Pros: Easy upgrade to make.
Cons: The rear output seal went after a 1,000 miles. This was due to a rough spot on the yoke. It may have been damaged during shiping however it was easly repaired using sand paper and i have had no issues since then.
Recommended? Yes
Comments: Inspect the surface of the Yoke to ensure it is smooth. Mine was damaged however I do not think this was due to manufacturing. I think the cause was either shipping or me.
shredknar
shredknar's Reviews
11-01-2011, 01:30 PM
Price: $600.00
Pros: cheap, pretty strong, and easy to install.
Cons: rusty's gave me the wrong length shaft
Recommended? Yes
Comments: i've had it on for about 8 months and wheeled it all summer with no problems.
rear u joint is starting to go though, went through lots of water and mud though, so should be expected
Zakman
A locked & armored Sport
Zakman's Reviews
09-22-2011, 07:28 AM
Price: $495.00
Pros: Stout, easy to install, TW driveshaft
Cons: Just having to remove the skidplate to install
Recommended? Yes
Comments: Not difficult to install. Previously had adjustable UCAs to to dial in the pinion angle wasn't too hard. Eliminated my vibes.
rocknjeep
rocknjeep's Reviews
07-16-2011, 11:18 AM
Price: $600.00
Pros: proper angles are restored. The transmissions sits where it originally was and in turn shifts smoother. The tcase no longer leaks. a much smoother ride.
Cons: none
Recommended? Yes
Comments: I love this mod. I was able to return my trans to its original position and in turn the driveline angles have been restored to the proper orientation. A much smoother ride, smoother shifting, and much stronger parts. No more leaking transfer case and no more slip yoke. Everthing is on there tight and won't be falling off like my original shaft and slip yoke. Could not be more happy with this.
18Dmedic
18Dmedic's Reviews
04-27-2011, 07:13 AM
Price: $600.00
Pros: No Vibes. Drives Great.
Cons: Price
Recommended? Yes
Comments: This is a must have when you lift your Jeep over 3 inches. It eliminates the vibrations. I love it.
Meep97
Meep97's Reviews
03-16-2011, 08:02 PM
Price: $500.00
Pros: Straight forward, strong parts, great upgrade
Cons: none
Recommended? Yes
Comments: I bought this to fix my driveline angle and I needed it for my axle upgrade too. Got rid of all vibes with my 4" lift and got rid of the TC spacer. Well worth it!
Richd1963
Richd1963's Reviews
03-04-2011, 09:48 AM
Price: $490.00
Pros: Outstanding reputation.
Cons: can't think of any
Recommended? Yes
Comments: The kit was packaged well and the Tow Woods drive shaft was lubed up and ready to drop in.
The AA SYE shaft was nicely machined and all components fit perfectly and went together like they should.
Thank you Oconee Off Road for great service and speedy shipping as well as great price!!
JohnyPro
JohnyPro's Reviews
02-16-2011, 07:45 PM
Price: $525.00
Pros: Quick Install, easy to use
Cons: nada
Recommended? Yes
Comments: Its an easy to intall kit, especially with a buddy who knows his ins and outs of t-cases! Beefy shaft! Can't wait to get out an use it!
mmkcmoore
mmkcmoore's Reviews
02-06-2011, 08:09 PM
Price: $500.00
Pros: works great does everything it says and makes it much stronger and fixes driveline angles
Cons: intructions suck.
Recommended? Yes
Comments: easy to install and put together just have to look up a write up on it becuase intstructions suck but the product is amazing. i recomend buying this.
dlane2155
dlane2155's Reviews
11-24-2010, 05:13 PM
Price: $500.00
Pros: Allows for more lift, double cardon drive shaft
Cons: None so far
Recommended? Yes
Comments: This is a good product and easy to install. The directions are very thorough so someone who has never taken apart a t case can tackle a project like this with no problem. I bought this through Rusty's and it took them 10 weeks to get me the drive-shaft and I called the day after I got the SYE kit to give them the measurement. I would recommend buying this from someone else.
squibload
squibload's Reviews
09-10-2010, 09:43 PM
Price: $499.00
Pros: Good service from Tom Wood
Cons: AA SYE needed some minor trimming.
Recommended? Yes
Comments: The driveshaft is what you'd expect from Tom Wood...flawless.
The SYE kit needed some trimming on sharp edges...the area where the oil pump fits into the outer housing needed to be Dremeled, along with the shift mode rod's recess. Minor, but this stuff should be right from the factory.
ThreadForumRepliesLast Post
Advance Adapters Drive Shaft Angle Reduction Kit (Slip Yoke Eliminator) SYE Kits 104 04-21-2013 03:33 AM
advance adapters atlas 2/II 5.0 Transfer Cases 11 12-10-2012 05:43 PM
Advanced Adapters Transfer case Linkage bracket Transfer Cases 10 11-27-2012 06:54 PM
Advanced adapters Atlas II Transfer Cases 16 07-12-2012 03:11 PM
Tom Wood's Custom Drive Shafts 231 Super-Duty Tail Shaft Conversion SYE Kits 21 01-18-2012 09:54 AM
Jeep Parts at Andy's
