Go Back JeepForum.com > Reviews > Transfer Case > SYE Kits > Advance Adapters Drive Shaft Angle Reduction Kit (Slip Yoke Eliminator)
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Advance Adapters Drive Shaft Angle Reduction Kit (Slip Yoke Eliminator) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product SYE Kits Next Product
Rating:
Product Information
MSRP: $57,567.00
Average Price: $872.59
Manufacturer: Advance Adapters
Recommended?
Yes: 104 / No: 0
Reduce driveline vibration on lifted vehicles with this Heavy Duty Slip-Yoke Eliminator Kit for Jeep's NP231J transfer case. Transfer case tailshaft length is reduced by 6.5" on '97-'01 Wranglers and 4.25" on '88-'95 models resulting in improved driveline angles. Kit includes a redesigned transfer case mainshaft which is not only shorter but has an 18% larger spline diameter, a 54% increase in torque capacity.
None
Page 4 of 6 1 2 3 4 5 6 > Last »
cj847
cj847's Reviews
09-13-2008, 10:51 PM
Price: $150.00
Recommended? Yes
Comments: No problems with the install. Follow the instructions and you'll be OK. You definately need some long arm tools to torque down the yokes.
GzrGlide
GzrGlide's Reviews
08-15-2008, 07:36 PM
Price: $1.00
Recommended? Yes
Comments: Nice kit. Instructions could be better and the rings used to hold the speedo gear easily stretch and end up being loose on the shaft. They'll stay on, but why not use better quality rings?
Oil pickup tube should be attached to pump BEFORE the pump is put in place.
93jeepREDSOX
93jeepREDSOX's Reviews
07-19-2008, 01:41 PM
Price: $200.00
Recommended? Yes
Comments: This was a must after the lift and for my first real work with my t-case it was surprisingly simple. Very tough and great quality.
AlexTJ
AlexTJ's Reviews
07-11-2008, 02:15 PM
Price: $200.00
Recommended? Yes
Comments: Works great. I installed it myself in a few hours. Couldn't ask for any better.
TJGIP
TJGIP's Reviews
07-11-2008, 09:10 AM
Price: $500.00
Recommended? Yes
Comments: Easiest install ever. Most difficult part is getting that damn harmonic damper off the stock housing. Very satisfied with the results. Ordered from Tom Woods with double cardan CV driveshaft. Rides excelent.
chupacabrah
chupacabrah's Reviews
07-10-2008, 04:21 PM
Price: $200.00
Recommended? Yes
Comments: one of the best mods i have done. this is great
and the install was not very bad, either. (also replaced the chain while I was in there)
75 char
75 char
75 char
alvinl
alvinl's Reviews
07-10-2008, 11:40 AM
Price: $300.00
Recommended? Yes
Comments: I installed this with the TC under the Jeep. It was a fairly easy install, with good instructions that were easy to follow and understand.
Socaljeep1
Socaljeep1's Reviews
07-02-2008, 11:45 PM
Price: $275.00
Recommended? Yes
Comments: have had this for two years now and haven't had any issues yet. performs as promised.
like24by
like24by's Reviews
06-28-2008, 02:45 PM
Price: $250.00
Recommended? Yes
Comments: .................................................. .................................................. ..................................
yjrush
yjrush's Reviews
06-08-2008, 12:31 AM
Price: $260.00
Recommended? Yes
Comments: The installation was easy, especially for my first time to ever break into a transfer case. Instructions where straight forward, only thing I recommend is having an AIR compressor. Would make things a TON easier, but AIR will help on most things.
Do Work 93Yj
Do Work 93Yj's Reviews
06-06-2008, 09:19 AM
Price: $230.00
Recommended? Yes
Comments: Has worked great so far. Was really easy to install by just following the instructions. And the people at Tom Woods were a real help when it came to purchasing it.
-sean-
-sean-'s Reviews
06-04-2008, 02:13 AM
Price: $100.00
Recommended? Yes
Comments: .................................................. .................................................. ................................................
FiveHundredMJ
FiveHundredMJ's Reviews
06-03-2008, 04:26 PM
Price: $220.00
Recommended? Yes
Comments: Awesome Kit! Now I can do 70 mph without vibrations like before. Cheap enough that you can afford and EASY to install with the t-case removed from the vehicle.
Fred007
Fred007's Reviews
06-02-2008, 11:43 PM
Price: $300.00
Recommended? Yes
Comments: Went together real easy, no problems. Doing it while the transission is out is pretty straightforward.
offroad95xj
offroad95xj's Reviews
05-18-2008, 04:28 PM
Price: $240.00
Recommended? Yes
Comments:
jpgirl
jpgirl's Reviews
05-16-2008, 08:34 PM
Recommended? Yes
Comments: Slip yoke no more!! Totally necessary for my jeep. Pretty darn easy to install, and I have no complaints!
Was purchased as part of a combination of stuff, to which I can't recall the price paid
supersixfour
supersixfour's Reviews
05-14-2008, 02:41 PM
Recommended? Yes
EvilSpock
EvilSpock's Reviews
05-14-2008, 01:17 AM
Price: $300.00
Recommended? Yes
Comments: Gotta have it!
jpoe
jpoe's Reviews
05-08-2008, 09:01 AM
Price: $210.00
Recommended? Yes
Comments: Seems like a very good product
BlueButton
BlueButton's Reviews
05-03-2008, 11:55 PM
Price: $250.00
Recommended? Yes
Comments: I had a local shop install it for me so I don't have much to review. Other than it was highly recommended by my friends and the local 4WD shop. It has been in the jeep for one year now with no problems.
ThreadForumRepliesLast Post
Advanced Adapters/Tom Woods NP231 SYE Kit w/ drive shaft SYE Kits 53 02-22-2013 03:39 PM
advance adapters atlas 2/II 5.0 Transfer Cases 11 12-10-2012 05:43 PM
Tom Wood's Custom Drive Shafts 231 Super-Duty Tail Shaft Conversion SYE Kits 21 01-18-2012 09:54 AM
PORC Slip Yoke Kit PORC52231 SYE Kits 17 07-30-2010 03:49 PM
slip yoke elimination kit 111 Transfer Cases 0 07-31-2008 06:36 PM
Jeep Parts at Andy's
