Go Back JeepForum.com > Reviews > Transfer Case > SYE Kits > Advance Adapters Drive Shaft Angle Reduction Kit (Slip Yoke Eliminator)
Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Advance Adapters Drive Shaft Angle Reduction Kit (Slip Yoke Eliminator) Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product SYE Kits Next Product
Rating:
Product Information
MSRP: $57,567.00
Average Price: $872.59
Manufacturer: Advance Adapters
Recommended?
Yes: 104 / No: 0
Reduce driveline vibration on lifted vehicles with this Heavy Duty Slip-Yoke Eliminator Kit for Jeep's NP231J transfer case. Transfer case tailshaft length is reduced by 6.5" on '97-'01 Wranglers and 4.25" on '88-'95 models resulting in improved driveline angles. Kit includes a redesigned transfer case mainshaft which is not only shorter but has an 18% larger spline diameter, a 54% increase in torque capacity.
None
Page 2 of 6 1 2 3 4 5 6 > Last »
cbossio
cbossio's Reviews
08-09-2010, 11:56 AM
Price: $200.00
Pros: Cheap, Straight forward instructions, Decent write-ups on the net.
Cons: Made in Taiwan, Vietnam, or one of those other countries that are not America.
Recommended? Yes
Comments: Save yourself some time and buy a stubby ratcheting 14 millimeter wrench (pretty sure it was a 14. verify with write-ups before you buy) to remove the very top bolt holding the t-case to the trans. You can make this swap by either removing the t-case or leaving it installed. I found it much easier to remove the case. It's much easier to reassemble while out. Especially if you are unfamiliar with the inner workings of the t-case. While you are doing this swap, you might as well change the speed-o gear. You have to remove it anyways and it's probably worth the $1.99 to correct your speedometer.
RaggedOleMan
RaggedOleMan's Reviews
08-05-2010, 10:34 AM
Price: $250.00
Pros: Never given me a problem
Cons: none
Recommended? Yes
Comments: I used the kit in conjunction with Rubicon Express RUCA's to minimize D/L vibes. I still have some vibes at 0-10mph that we never could get rid of.
slpv09
slpv09's Reviews
07-29-2010, 01:01 PM
Price: $225.00
Pros: reduces vibration, driveshaft wont fall out
Cons: none
Recommended? Yes
Comments: good product good price
failure2stop
failure2stop's Reviews
05-21-2010, 12:46 AM
Price: $340.00
Pros: does the job
Cons: none yet
Recommended? Yes
Comments: INstalled it and noting bad as of yet. it is doing it's job.
Hailchief
Hailchief's Reviews
03-03-2010, 08:59 AM
Price: $175.00
Pros: Easy to install
Cons: None
Recommended? Yes
Comments: Very good and very easy to install. Make sure you get yourself a good pair of lock ring pliers. You will need them
davidkaiser05
davidkaiser05's Reviews
02-28-2010, 04:19 PM
Price: $250.00
Pros: Easy to install.
Cons: None
Recommended? Yes
Comments: Just finished installing it and it was a breeze. It only took about two hour maybe three with the driveshaft.
SolidBrass
SolidBrass's Reviews
02-28-2010, 01:49 AM
Price: $500.00
Pros: you know
Cons: none
Recommended? Yes
Comments: I don't know what brand my SYE is but is required for 4" lifts. If you don't your are NOT KEWL!
jeepinmichguy_
No longer a Jerk....
jeepinmichguy_'s Reviews
01-15-2010, 10:26 AM
Price: $250.00
Pros: its a sye
Cons: none
Recommended? Yes
Comments: I have had this on for 7 years, 2 transfercases and no issues. I would highly recommend when looking for a SYE.
OCsurfin
OCsurfin's Reviews
01-12-2010, 07:32 PM
Price: $666.00
Pros: eliminates need for t-case drop
Cons: housing casting was off
Recommended? Yes
Comments: great product once you get past the vague instructions and troubleshoot the odd problem i had. the casting they used on the housing must have been off, when i finished the installation and went to test it out the shift rod was bottoming out on the rod channel in the housing, i wobbled it out with a drill bit and everything is kosher.
gecko5
gecko5's Reviews
01-03-2010, 10:24 PM
Price: $250.00
Pros: Reduced Driveline bind
Cons: Bought Used. One of the bushings were toast
Recommended? Yes
Comments: Great setup and a must to have if you are lifting over 3"'s or are doing any other kind of changes to the driveline.
Douglas S.
Douglas S.'s Reviews
12-27-2009, 12:24 AM
Price: $200.00
Pros: Easy intall, high quality
Cons: Snap rings without holes
Recommended? Yes
Comments: Was needed when I installed my lift and was very easy to install (other than none of the snap rings had holes for the pliers- made things a little difficult). Took about four hours total (first time). Nothing more to say really.
YJNot
YJNot's Reviews
12-22-2009, 07:59 PM
Price: $499.00
Pros: Great instructions, except to the speedo indexing. INCLUDED A TOM WOODS CV DRIVESHAFT!!!!!
Cons: Should cover the pinion angle in more detail and maybe shims?
Recommended? Yes
Comments: The installation was real easy. There are no vague instructions. The hardest part was pressing out the two caged needle bearings if you have them. My Cheapese press couldn't do it, so a freind did.
The driveshaft included price was pretty good, saved some buck there.
Boodyrider
Boodyrider's Reviews
11-01-2009, 01:09 AM
Price: $100.00
Pros: got a great deal, works great
Cons: Not as short as JB Conversions ultra short
Recommended? Yes
Comments: I like this SYE. It's solid, got a great deal when I bought it used already installed, and it works. Now that I've done a bellyup and about to do a lift, I would go with a shorter SYE (the JB Conversions ulta short one) if I were to do it again, as my DS angles are getting a little silly, and I'd like a longer rear DS. But it's a good option for many.
GregB_00XJ
GregB_00XJ's Reviews
10-18-2009, 01:32 AM
Price: $1.00
Pros: Free to me from AA in Vendor Giveaway
Cons: None?
Recommended? Yes
Comments: Great product, well made, great support, good instructions and a superb company!
wilco12rs
wilco12rs's Reviews
10-17-2009, 01:22 AM
Price: $250.00
Pros: with it on it's shorter than an atlas
Cons: Transfer case shifting is really stiff now.
Recommended? Yes
Comments: Transfer case shifting is really stiff now. Probably just user error though i let it hang for about a min during the install by the shifter. With it on it's shorter than an atlas.
mobyjeep
mobyjeep's Reviews
06-20-2009, 09:41 AM
Price: $199.00
Pros: easy install, complete kit
Cons: need good snap ring pliers
Recommended? Yes
Comments: excellent product
mobyjeep
mobyjeep's Reviews
06-20-2009, 09:36 AM
Price: $199.00
Pros: very complete kit
Cons: none
Recommended? Yes
Comments: Went together easily. Use a good set of snap ring pliers!
MelloYello32
MelloYello32's Reviews
06-16-2009, 09:34 PM
Price: $250.00
Pros: No noise line vibrations.
Cons: installation is mildly complicated.
Recommended? Yes
Comments: Highly recommended.
Dmax5er
Dmax5er's Reviews
05-17-2009, 11:08 AM
Price: $3,000.00
Pros: great for hard angles
Cons: none yet
Recommended? Yes
Comments: ordered mine with trans and transfer case.............................................. ............
Kandyman
Kandyman's Reviews
03-25-2009, 03:56 PM
Price: $300.00
Recommended? Yes
Comments: definite do for lifted jeeps☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆ ☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆ ☆☆☆☆☆☆☆☆☆☆☆
ThreadForumRepliesLast Post
Advanced Adapters/Tom Woods NP231 SYE Kit w/ drive shaft SYE Kits 53 02-22-2013 03:39 PM
advance adapters atlas 2/II 5.0 Transfer Cases 11 12-10-2012 05:43 PM
Tom Wood's Custom Drive Shafts 231 Super-Duty Tail Shaft Conversion SYE Kits 21 01-18-2012 09:54 AM
PORC Slip Yoke Kit PORC52231 SYE Kits 17 07-30-2010 03:49 PM
slip yoke elimination kit 111 Transfer Cases 0 07-31-2008 06:36 PM
Jeep Parts at Andy's
