Go Back JeepForum.com > Reviews > Axles > Steering > Rugged Ridge Heavy Duty Steering Crossover TJ, XJ,and ZJ
Rugged Ridge Heavy Duty Steering Crossover TJ, XJ,and ZJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Next Product
Rating:
Product Information
MSRP: $150.00
Average Price: $162.00
Manufacturer: Rugged Ridge
Recommended?
Yes: 3 / No: 4
Beef up your ride with Rugged Ridge steering components. This is a bolt-on solution for preventing bent tie rods from wheeling with larger tires. The tubes are 1.25" ID SAE 1018 that is cold rolled, pierced, and drawn through dies to produce wall thickness of .25". this true DOM tubing with no seams or welds to fail. Heavy-duty 7/8" rod ends feature standard tapered ends to fit stock knuckle applications. You get one ton strength without any modifications to your steering knuckles.
letitloose06
letitloose06's Reviews
05-05-2011, 05:39 PM
Price: $170.00
Pros: Beefy steering links. Thats about it.
Cons: Tie rod ends suck. Replacement ends only available from RR. Odd tie rod end size (M22x1.5)
Recommended? No
Comments: Tie rode ends are junk. They also aren't available at parts stores, so you have to buy them from RR. Has the "dead spot" from tie rod end roll. Also TRE's are not 7/8" as advertised. The are actually M22x1.5, which makes upgrading to actual 1-ton ends not possible. Do yourself a favor and don't waste the money.
Cavguy1965
Old Cavalry Trooper
Cavguy1965's Reviews
03-04-2011, 02:12 AM
Price: $175.00
Pros: Much better than stock! Easy to install.
Cons: none
Recommended? Yes
Comments: Controls my 35's with ease and made the steering much more solid. I'm not sure what I paid for it though as I bought it a year or more ago.
abnormal
Platinum Member
abnormal's Reviews
10-03-2010, 10:05 AM
Price: $150.00
Pros: rods are strong
Cons: everything else.
Recommended? No
Comments: Because I have a 6.5" lift I had issues from day one with this kit. I ended up putting the iron rock offroad OTK setup on and the steering is perfect now. If you have more than 3" I wouldnt bother with this setup since its an inverted t design and you will have tons of play.
Sterner09
Sterner09's Reviews
03-19-2010, 12:14 PM
Price: $150.00
Pros: Solid rod, have yet to wheel with it.
Cons: none so far
Recommended? Yes
Comments: Installed without drilling or reaming, fairly cheap.
Boyjeepin
Boyjeepin's Reviews
03-11-2010, 06:14 PM
Price: $170.00
Pros: Very beefy design. Easy to install. Would make very hard to bend.
Cons: Will not work on XJ with stock wheels as the tierod rubs and prevents you from turning. Also, will not work without a lift as the steering stabilizer will smash into the oil pan and cause it to break open....ask me how I know!
Recommended? No
Comments: If you are driving a stock height and stock wheeled XJ I would not buy this product. I got this after my original setup got bent up and I didn't want to pay for the Currie. I can no longer run a stabilizer, and have horrible front end wobble. I would only buy this product for a non daily driver.
JeepDoo
JeepDoo's Reviews
12-18-2009, 11:24 PM
Price: $169.00
Pros: Beefy, seems indestructible
Cons: Horrible DEATH WOBBLE on the highway. I strongly suggest this steering for offroad use only. I am replacing this with a stock-like y setup instead.
Recommended? No
Comments: Like i said, if you drive your Jeep at speeds over 35 mph, dont get this setup. It is for offroad use only, as they advertise on the web site (i didnt listen).
For offroading i dont think there is a better bolt on solution. It has tons of play, i dont ever see it binding up. The play is what causes the death wobble on the road.
CalebsXJ
CalebsXJ's Reviews
12-18-2008, 05:18 PM
Price: $150.00
Recommended? Yes
Comments: Awesome Setup for the price! Very beefy and well worth the Dough! Makes steering feel alot tighter then OEM... Well not bend (unless you smack a rock on a 4foot drop, inwhich anything would bend lol) Great alternative to a Currie!
ThreadForumRepliesLast Post
Iron Rock Off-Road Heavy Duty Tie Rod Jeep XJ/TJ/ZJ Off Road Extreme Duty Steering 3 01-07-2012 07:40 AM
Rugged Ridge Heavy-Duty Steering Linkage Kit - YJ Steering 5 01-16-2011 12:29 AM
Currie Currectlync® - TJ/LJ/XJ/MJ HD Steering System Steering 23 04-21-2010 09:32 PM
Rustys Steering Box Brace Steering 3 10-15-2009 07:50 PM
JCR Offroad 1-Ton Steering Upgrade Steering 1 12-29-2007 11:01 PM
Glock Forum
