Product Information
Off Road Only is pleased to announce the return of SwayLOC™, the original and the only true dual rate off road anti-swaybar currently available for the Jeep TJ's.
The SwayLOC dual rate anti-sway bar system improves balance and control while providing full articulation during off-road use and delivers near OEM on-road ride quality without having to struggle with disconnect links. SwayLOC is now available with either the proven air operated remote controlled latching mechanism or the new "Flip-a-Lever" simple manually controlled latch. With the air operated control the rate is selected by either a switch inside the Jeep or automatically selected if the Jeep equipped with AiROCK™.
Features of the SwayLOC anti-sway bar system:
• Low resistance rate reduces body lean, enhancing off-road performance.
• High resistance rate provides great on-road handling.
• Simple manual operation or optional remotely controlled latching system.
• Automatic rate control when utilized with AiROCK™.
• Keyed cam system ensures latch engages when vehicle is at proper position.
• Heavy-duty steel and anodized aluminum construction.
• Graphite impregnated polyurethane mounting bushings.
• All wear components are serviceable.
• Integrates into frame cross member on Jeep® Wrangler™ TJs.
Average Price | $364.5 |
Manufacturer | Off Road Only |
Recommended | Yes: 2 / No: 0 |
