Go Back JeepForum.com > Reviews > Axles > Steering > JKS JKS Quicker Disconnects
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
JKS JKS Quicker Disconnects Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Next Product
Rating:
Product Information
MSRP: $160.00
Average Price: $113.64
Manufacturer: JKS
Recommended?
Yes: 11 / No: 0
Adjustable Quick Disconnect Sway Bar Links
yellow_xj
yellow_xj's Reviews
02-14-2011, 09:08 AM
Price: $159.99
Pros: Heavy duty, Easy to disco
Cons: None
Recommended? Yes
Comments: The unique design of JKS Quicker Disconnects enables the user to quickly and easily fine tune the length to compensate for vehicle changes.The easiest to operate, due in part to tapered stainless steel mounting posts and floating, spherical polyurethane bushings. With the lengths adjusted properly for the vehicle, the user can even operate our Quicker Disconnects when parked on uneven surfaces
Lyonsa80
Junior Member
Lyonsa80's Reviews
01-09-2011, 09:10 PM
Price: $125.00
Pros: Super fast and no tools to disconnect and connect, durable, long life bushings, greasable, adjustable, very little noise transmission, quick and easy install, reasonable in price for a quality product.
Cons: Not that big of deal, but they use TORX fasteners...boo.
Recommended? Yes
Comments: Purchased a set of these with my lift 3 years ago based on advice from EricsXJ's book, and I am ever so glad that I did. I am still on the original bushings. They are tough as nails, adjustable, super fast to connect and disconnect, no tools needed to do so, and all things mentioned in "product pro's" that I listed. I see my friends out at the trail jacking around again, again, and again with their "good deal" disconnects after I've recommended these and all I can do is laugh as I wait for them at the trail head. If you'd like a high quality, reliable, functional, QUICK disconnect, do yourself a favor...spend the extra $25 bucks and purchase a pair of these. You won't be sorry.
DustPuppy
DustPuppy's Reviews
06-02-2010, 11:33 PM
Price: $120.00
Pros: Professional, well designed.
Cons: Installation instructions could have been more robust.
Recommended? Yes
Comments: These work very well. Just remember to park on level ground to reconnect them. On an XJ, the existing pin on the axle needs which is removed to install these needs to be driven out, despite having torqs hex slot; the instructions do not mention this and should to reduce installation frustration.
spicymike
spicymike's Reviews
04-07-2010, 04:15 AM
Price: $45.00
Pros: Disconnect or die, That front stab will roll you Jeep down a hill faster than Rosie chasing a doughnut down a flight of stairs. If you don't buy the quickie bring the allen and the vice grips.
Cons: I think I broke a nail pulling the pin ... WHAAAAAA !!!
Recommended? Yes
Comments: I would say besides a lift, Tires, Wheels this mod is a must. Cheap and easy to install.
Sterner09
Sterner09's Reviews
03-19-2010, 12:15 PM
Price: $75.00
Pros: Easy to disconnect, always done before the guys who do not run them
Cons: pins sometime pop out.
Recommended? Yes
Comments: Got them used, there duraable, would buy brand new.
Yellowhammer
Yellowhammer's Reviews
03-17-2010, 11:21 AM
Price: $145.00
Pros: Easy to install, well made, tough
Cons: You can easily round-out the hex-head bolts if you are not careful.
Recommended? Yes
Comments: These are easy to install and they work perfectly. They are heavy-duty and well made. Disconnecting takes seconds and they are easy to adjust. Excellent product overall.
jeepinmichguy_
Resident *** Hole
jeepinmichguy_'s Reviews
01-15-2010, 05:47 PM
Price: $125.00
Pros: go back together better than most other discos
Cons: none
Recommended? Yes
Comments: for a nice disconnect and not replacing the whole swaybar with an antirock these are the way to go. easy to install yourself just make sure you have some PB Blaster available!!! i would recommend these to anyone still running a 2 piece disco or no disco.
* do your self a favor and purchase a tie rod end remover, makes install go much easier.
** unlike the guy below mine came with mounts to keep the disco out of the way you drill into the frame. it is for TJ's, XJ's, and ZJ's (ZJ with a front skid).
tacweapon
tacweapon's Reviews
11-04-2009, 01:58 AM
Price: $40.00
Pros: easy to use
Cons: does not come with a way to mount the sway bars when disconnected
Recommended? Yes
Comments: They are very easy to use, putting the sway bars back in place might take a little force, I have had to find a level spot and a mallet to put them back in place.
The only con is that it does not come with a way to mount the disconnect when it is disconnected so on the XJ I am holding them in place with cable ties.
jim_bert
jim_bert's Reviews
07-08-2009, 11:48 PM
Price: $125.00
Pros: easy, perfect
Cons: none, maybe price if you cant find a deal
Recommended? Yes
Comments: like everyone else says...go with these..
fireball27190
fireball27190's Reviews
03-07-2009, 08:00 PM
Price: $160.00
Recommended? Yes
Comments: Great product. Easy to install. Grease able joints.Comes with pins to keep link out of way when disconnected. Absolutely worth the money. This is that kind of product when people say you get what you pay for you are really getting it.
cliffbong732
cliffbong732's Reviews
02-12-2009, 05:52 PM
Price: $130.00
Recommended? Yes
Comments: Great product. Definitely worth the money. It really comes in handy when you get stuck, or just need more flex. Adjustable for different lift heights.
Glock Forum
