Go Back JeepForum.com > Reviews > Axles > Steering > Currie Currectlync® - TJ/LJ/XJ/MJ HD Steering System
Truck-Lite's New LED Headlamp SeriesTJ 5.25" Speaker Adapters - NalinMFGCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!
Currie Currectlync® - TJ/LJ/XJ/MJ HD Steering System Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Next Product
Rating:
Product Information
MSRP: $550.00
Average Price: $365.38
Manufacturer: Currie
Recommended?
Yes: 35 / No: 2
Description: The Currie Currectlync® heavy duty tie rod and drag link system for TJ, LJ, XJ, and MJ vehicles features a 1 1/4" diameter forged chrome moly drag link, 1 1/4" chrome moly bar stock tie rod that is bored and threaded on the ends. All 7/8" thread tie rod ends with urethane boots, and jam nuts are includeds, as well as the new heavy duty steering stabilizer bracket. This unit is a direct replacement for the stock unit - no modifications or machining to any part of the vehicle is necessary.
Page 1 of 2 1 2 > Last »
grininmonkey
grininmonkey's Reviews
12-21-2011, 10:07 AM
Price: $200.00
Pros: Solid
Cons: Rubs against my axle track bar bracket and difficult to get perfect alignment due to bolts need to point down to prevent bad rubbing.
Recommended? Yes
Comments: My issue with the rubbing against the track bar bracket is due to my lift size at 2.5". A higher lift would clear the bracket better.
famousstar1026
famousstar1026's Reviews
11-19-2011, 04:19 AM
Price: $399.99
Pros: super beefy install wasnt bad tre's are huge all around pretty nice
Cons: zerks, cotter pins
Recommended? Yes
Comments: cotter pins are a ***** to install watch the grease zerk where the drag link connects to the tie rod it can be broken off at full flex
irocz3489
irocz3489's Reviews
10-05-2011, 08:09 AM
Price: $385.00
Pros: Beefy!
Cons: None
Recommended? Yes
Comments: Great Product, order through Gerald at Savvy! He's the man. Steering feels very solid. I don't worry about bending tie rod or drag link anymore.
91JamesXJ91
91JamesXJ91's Reviews
07-26-2011, 05:51 PM
Price: $417.05
Pros: Way stronger than the pictures show
Cons: Not cheap
Recommended? Yes
Comments: Well worth the money. It is not a cheap piece but I bought from Frankenstein Offroad who seems to have the best Currie prices currently. I paid 417.05 Shipped.
weidmaier
weidmaier's Reviews
04-24-2011, 10:12 PM
Price: $417.00
Pros: beefy
Cons: pricey
Recommended? Yes
Comments: solid.
dayriesw
dayriesw's Reviews
04-11-2011, 11:18 AM
Price: $1.00
Pros: cant remeber how much it was..... Currie was very helpful with this. Great customer service
Cons: slow shipping
Recommended? Yes
Comments: Heavy duty equipment that can take a beating
Weelz
Weelz's Reviews
02-16-2011, 04:28 PM
Price: $380.00
Pros: Very tough stuff. Easy install.
Cons: Made for 4" of lift.
Recommended? Yes
Comments: As I'm sure many on this forum have noted, this linkage is the real deal. Very heavy duty. Relatively easy to install.
TigerSpeed
TigerSpeed's Reviews
01-28-2011, 11:39 AM
Price: $390.00
Pros: Very easy install minus one detail, very strong build,
Cons: price, one engineering flaw described below
Recommended? Yes
Comments: Overall this is an excellent product, cured my death wobble.
The one engineering flaw I am referring to is where the drag link meets the tierod and there is a recessed hole so that the tierod end's stud/nut are not exposed. Well there is only one little slit that Currie put in there to enter the clevis pin through so you have to line the hole on the stud up perfect with this slit.....Only they gave you no way to rotate the stud so when tightening the nut it would always just rotate until the hole wouldn't line up.
We solved it by simply flattening two edges of the stud so we could rotate it ourselves with pliers to line it up instead of fighting all the guess work and luck.
TennesseeTJ02
TennesseeTJ02's Reviews
01-25-2011, 06:20 PM
Price: $400.00
Pros: It's beefy
Cons: none yet
Recommended? Yes
Comments: It is huge and beefy. I wish i would have done this a long time ago.
Nicho
Nicho's Reviews
12-30-2010, 06:07 PM
Price: $399.00
Pros: Currie Brand and tested durability
Cons: None so far
Recommended? Yes
Comments: So far so good
ghndrcks
ghndrcks's Reviews
11-01-2010, 04:07 PM
Price: $300.00
Pros: BEEFY
Cons: weight
Recommended? Yes
Comments: Big, beefy system. Only true down fall is having to buy parts from currie.
theducksguts
no whiners!
theducksguts's Reviews
10-07-2010, 10:32 AM
Price: $348.00
Pros: Complete replacement of stock steering linkage, Huge tie-rod ends, solid chomolly tie-rod and drag link. All hardware included. Easy install.
Cons: have to purchase replacement parts from Currie, not sure of any parts store comparables.
Recommended? Yes
Comments: I wish I would have done this upgrade sooner. The steering is tighter, I have more confidence on the trail, it is just a wonderfully designed system. Buy it now! I am saving up to put this same system on another one of my rigs. It is so worth it.
akordboy
Junior Member
akordboy's Reviews
05-07-2010, 10:43 AM
Price: $350.00
Pros:
Cons:
Recommended? Yes
Comments:
BlackRuby06
BlackRuby06's Reviews
04-25-2010, 11:00 AM
Price: $335.00
Pros: Beefy, easy to install
Cons: none
Recommended? Yes
Comments: The currie system is huge compared to the stock steering. The install is easy and the system works great.
RockMonster
RockMonster's Reviews
04-21-2010, 09:32 PM
Price: $390.00
Pros: easy to install and maintaine tough and durrable
Cons: none so far
Recommended? No
Comments: sooo beefy! i feel like i could bounce this thing off rocks all day and not have to worry about a thing! it was super easy to put on and is deffinatly worth the $$$ for the peace of mind
ericson89
ericson89's Reviews
03-16-2010, 10:41 AM
Price: $349.00
Pros: Easy install Beefy over stock great for 33s
Cons: none
Recommended? Yes
Comments: Great system for someone running 33s. I'm in South Jersey so not much crawling here and don't have to worry about bending the tie rod too much.
ericson89
ericson89's Reviews
03-16-2010, 10:38 AM
Price: $349.00
Pros: Great over stock steering. Beefy and great for 33s Easy install
Cons: none
Recommended? Yes
Comments: This system puts the stock steering to shame. I'm running 33s and its perfect for my setup.
asearle
asearle's Reviews
01-18-2010, 08:18 PM
Price: $395.00
Pros: Direct bolt on--very easy installation, retains factory steering geometry, huge.
Cons: Price and the fact that the tie rod is grooved where the rod end clamps go.
Recommended? Yes
Comments: I've had this on my Jeep for about a month now and have been very satisfied with it. The quality and strength were apparent from the moment I opened the box.
There are grooves in the tie rod where the rod end clamps go and these were annoying since they make it so the clamps will only fit on the tie rod in a certain way...this causes problems on the passenger side when trying to dial in the toe-in because unless the clamp, and subsequently the tie rod are turned to a specific position, the clamp interferes with the steering stabilizer and drag link.
This is nothing a Dremel tool and about thirty seconds didn't solve (in order to make the bolt hole on the clamp slightly larger so the clamp could be tightened in any position), but after paying nearly $400, I didn't expect to have to modify the product to get it to work properly...no mater how slightly. This groove might serve a purpose, but none that was outlined in the installation instructions nor one that my alignment guy could figure out.
Nonetheless, it's a good product and hands down better than stock and just about any other after market product out there.
goldswim5
goldswim5's Reviews
10-11-2009, 11:52 PM
Price: $340.00
Pros: It's huge. That's the only thing you need to know.
Cons: None
Recommended? Yes
Comments: So far, I love this steering. It's huge, and I'm pretty sure you'd have to be doing something idiotic to mess it up.
DeconsTructionJ
DeconsTructionJ's Reviews
10-09-2009, 01:57 AM
Price: $389.99
Pros: Everything looks good
Cons: replacement parts seem pricey
Recommended? Yes
Comments: Looks beefy
Double boots a cool feature
ThreadForumRepliesLast Post
Currie HD Tie rod Steering 6 12-03-2009 11:40 PM
Rustys Steering Box Brace Steering 3 10-15-2009 07:50 PM
Currie Enterprises Currectlync® Steering System Steering 1 05-04-2008 05:40 PM
Rock Krawler TJ X-Factor HD Steering Upgrade Steering 2 04-23-2008 09:44 PM
JCR Offroad 1-Ton Steering Upgrade Steering 1 12-29-2007 11:01 PM
Glock Forum
