Crown - Crown Rough Trail HD Steering Kit Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $139.00
Manufacturer: Crown
Recommended?
Yes: 3 / No: 1
Company Website: http://www.crownautomotive.net/category/Rough-Trail-Performance-Steering.html
HD Steering Kit by Crown.
None
Blakerall90
Blakerall90's Reviews
09-16-2016, 10:46 PM
Price: $1.00
Pros: Great Product! very well built
Cons: N/A
Recommended? Yes
Comments: My old stock steering kit was shot and it was time for it to be replaced. This kit was very simple to hook up and set in place! Took my jeep to the trails after installing it, and it handled great.
Tewing04
Tewing04's Reviews
07-30-2011, 12:29 PM
Price: $180.00
Pros: Stronger 1" solid tie rod, is strong and hasn't bent yet.
Cons: Cheap, drag link is same as stock.
Recommended? No
Comments: The tie rod ends were completely rusted in 3 months, the bolts on the adjustment sleeve on the tie rod stripped out on me after 6 months and it almost killed me. After 7 months both ends of the drag link were completely shot and gave me horrible steering slop. This is pretty much just a ZJ steering upgrade. I do pretty tough wheeling but I don't abuse my stuff, this steering really let me down, plus it looks like crap because it has natural bends in it. My recommendation is save the extra 50-100 bucks and buy the good stuff.
P.S. It's about a month later now and now I have managed to strip out the drag link adjustment sleeve bolts and also, an entire tie rod end. The hardware with this steering, including the tie rod ends are absolute crap. I highly DO NOT RECOMMEND.
greenglazier
greenglazier's Reviews
05-16-2011, 08:20 PM
Price: $200.00
Pros: 1 inch solid tube,they use poly bushings,easy install
Cons: none so far
Recommended? Yes
Comments: 1 inch solid tube tierod and they use poly bushings so they wont crack compared to there 1st. generation product im happy so far with it
phantom01231
phantom01231's Reviews
10-05-2010, 02:57 AM
Price: $175.00
Pros: Stronger Tie Rod over stock. You can see the difference. Cheep and afordable. Easy to install. Took about 2 hours along with doing a new 5th shock.
Cons: Drag Link and Tie Rod seemed as if they were from the junk yard and had been reconditioned. (The links had some small specks of rust on them. Could have just been sitting in a humid where house for a while.) All the TRE's looked brand new but had after market type boots on them but the one on the passenger side knuckle. The adjuster sleeve on the Tie Rod seems like it’s to close to the wheel and looks as if it were to be hit hard enough it would buckle. May need a spare just in case. Cheep Castle Nuts come with it. So you will want to go to the store and get better ones.
Recommended? Yes
Comments: I found that all my TRE's had blown boots and the stock system was covered in rust so I decided to upgrade. With having done my rear axle and regearing and going to a Clayton Lift my funds were kind of gone so a Currie was out of the question and seeing some of the reviews from the others I keep looking. This seems to be about the same as doing the ZJ upgrade and it was kind of cheep from Rompalicious (175.00) plus free shipping. So I ran with it. Did the first road test and it seems to be just fine. Trail test will be shortly. All in all it seems ok.
ThreadForumRepliesLast Post
Currie Currectlync® - TJ/LJ/XJ/MJ HD Steering System Steering 45 07-21-2015 01:06 PM
Crown Dana 35 Chromoly 27 Spline Axle Kit Axle Shafts 11 06-24-2015 08:44 AM
Rustys Steering Box Brace Steering 4 04-18-2013 02:45 PM
JCR Offroad 1-Ton Steering Upgrade Steering 3 08-15-2011 11:11 AM
