Go Back JeepForum.com > Reviews > Axles > Axle Shafts > Alloy USA Aluminum Axle Seals
3/8" Amsteel Blue Winchline Available in Blue, Green,Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent Prices
Alloy USA Aluminum Axle Seals Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Axle Shafts Next Product
Rating:
Product Information
MSRP: $300.00
Average Price: $85.23
Manufacturer: Alloy USA
Recommended?
Yes: 13 / No: 1
Billet Aluminum Axle Tube Seals in Black, Red, or Silver - by Alloy USA Super value price! Keep water, mud and debris from entering your front axle housing. These CNC machined Aluminum housings feature two seals to provide double protection from the crud. Available in red, black and silver anodized finishes. Sold in pairs
Mike
no radiator req'd
Mike's Reviews
10-07-2011, 12:24 PM
Price: $80.00
Pros: easy install and maintenence.
Cons: none
Recommended? Yes
Comments: a must have for Dana 30 axles, easy install and has grease fittings for maintenence.
provinT13
provinT13's Reviews
07-04-2011, 12:08 AM
Price: $80.00
Pros: Great solid seal
Cons: Driver side zerk grease fitting didn't fit
Recommended? Yes
Comments: These were easy to install and a huge upgrade from the factory plastic seals. They installed easy, but I had a slight problem on the drivers side. The grease fitting is totally butted up against the axle housing once the seal is all the way set, making it impossible to get a grease gun on it. I did not have this problem on the passenger side, and both seals are fully installed and flush. I had to remove the zerk fitting and install a longer fitting so the gun could get grease in there. Aside from that little problem these seals are great.
skifreek
skifreek's Reviews
05-26-2009, 09:54 AM
Price: $49.00
Pros: no leaks yet.
Cons: nothing negative to say.
Recommended? Yes
Comments: Let's see how then hold up.
jerseyjeep2003
jerseyjeep2003's Reviews
05-07-2009, 10:00 AM
Price: $85.00
Pros: Protects differential from water and mud
Cons: Will not work with vacuum disconnect axle.
Recommended? Yes
Comments: I installed the seals about a year ago and haven't had any problems with "milked" a diff since then.
BlackBellamy
BlackBellamy's Reviews
04-01-2009, 12:06 PM
Price: $50.00
Recommended? Yes
Comments: Great product and easy install. No more nasty crud and dirt inside my tubes.
ajeepcreep
ajeepcreep's Reviews
12-25-2008, 03:47 AM
Price: $300.00
Recommended? Yes
Comments: 30 spline axel shafts in the Dana 35.
DeconsTructionJ
DeconsTructionJ's Reviews
12-06-2008, 11:13 PM
Price: $60.00
Recommended? Yes
Comments: I wish I would have had them earlier there is a large amount of mud in my axle tubes
GREASEMONKEY
GREASEMONKEY's Reviews
08-30-2008, 01:19 AM
Price: $30.00
Recommended? No
Comments: I do a fair amount of soft mud, and 3-4ft water crossings. I decided when I replaced my axles it was a good idea to try a set of these. I was initally happy with the product. The seal on the driver side tore, and failed after about 2k miles, and the passenger side seal tore, and failed after about 2500mi. I did make sure to keep them greased, and sand & mud cleaned off of them, but still had a failure. I had purchased the set from Northridge 4x4, and called them to get a warranty. The seal sets were on backorder! I was put intouch with a rep. at Alloy USA. I was assured that the failure was a fluke, and that I would be shipped a new set directly from the factory after the backorder was lifted, or possibly before! Here we are 2yrs later and numerous emails later. NO replacements! I finally gave up, and just accepted the loss, and a lesson!
If you buy these, and never have a problem-good for you. If you ever have a failure of this product-good luck!!!
Rafikie
Rafikie's Reviews
07-30-2008, 09:29 AM
Price: $69.00
Recommended? Yes
Comments: Nice quality and good fit. Very easy to install and seem to keep everything out of the axle tubes
05moabTJ
05moabTJ's Reviews
07-28-2008, 10:02 PM
Price: $50.00
Recommended? Yes
Comments: Alloy USA is a great product, easy installation, highly recommend this product
Rubikahn
Rubikahn's Reviews
03-16-2008, 09:04 PM
Price: $75.00
Recommended? Yes
Comments: Haven't gotten around to installing these yet, but the instructions appear to be straightforward.
jeeperkt
jeeperkt's Reviews
03-03-2008, 05:02 PM
Price: $100.00
Recommended? Yes
Comments: Keeps the nasty stuff out
JeepRocks86
Some Call me RockDog
JeepRocks86's Reviews
10-12-2006, 11:05 AM
Pros: Keeps the bad stuff out.
Cons: none
Recommended? Yes
Comments: I haven't checked the shaft's lately on the inside but the rocks and other bad stuff can't get in.
Leroux
Leroux's Reviews
08-14-2006, 02:59 PM
Price: $80.00
Pros: Easy to install, Works as adverti
Recommended? Yes
Comments: Installed Alloy USA shafts and used these with it to keep crap from getting into my axle tubes. Seems like a good idea.
ThreadForumRepliesLast Post
Alloy Dana 30 27 Spline axle shafts Axle Shafts 11 02-03-2011 01:15 PM
Alloy USA 4.88 Ring and Pinion Gears 5 07-30-2010 12:55 PM
Alloy USA Chromemoly Front Axle Shaft Kits Axle Shafts 28 05-21-2010 01:56 AM
Alloy USA D30 4:10 Ring and Pinion Gears 8 01-07-2009 08:43 AM
Alloy USA-8.8" Grande Axle Kit Axle Shafts 1 03-28-2007 02:51 PM
Glock Forum
