EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Reviews > Axles > Gears > Quaker State 75w-140 synthetic gear oil
Quaker State 75w-140 synthetic gear oil Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Gears Next Product
Rating:
Product Information
MSRP: $20.00
Average Price: $9.00
Manufacturer: Quaker State
Recommended?
Yes: 3 / No: 0
QUAKER STATE® FULL SYNTHETIC SAE 75W-140 GL-5 GEAR LUBRICANT is a thermally stable gear oil engineered to exceed the most severe performance requirements for passenger cars, sport utility vehicles and light-duty truck differentials (including limited slip), manual transmissions and transaxles calling for an API GL-5 lubricant. It protects against gear wear and spalling, even during heavy loading. It is ideally suited for use where extreme conditions exist or where an extended service interval may be encountered.
Because it is made entirely with synthetic base stocks, QUAKER STATE® FULL SYNTHETIC SAE 75W-140 GL-5 GEAR LUBRICANT offers excellent performance when subjected to temperature extremes – both high and low – for year-round protection under a variety of conditions. It is especially effective in vehicles operating under severe conditions, such as towing a boat, trailer or other vehicles. It is also effective in promoting smooth shifting of manual transmissions and transaxles where extreme low temperatures are a concern. The synthetic base, combined with advanced additive technology, offers outstanding resistance to oxidation for long lubricant life and minimal deposit formation for clean gear operation.
FEATURES
• Exceeds requirements of API Service Designation GL-5
• Meets major vehicle manufacturers’ specifications
BENEFITS
This product contains special additives to:
• Reduce bearing and gear distress under extreme operating conditions
• Protect at both high and low temperature extremes
• Resist oxidation to retard deposit formation
• Guard against “chatter” in limited slip axles
• Protect against rust and corrosion
• Minimize foaming
July, 2002 Stock 5040854
socaltj
socaltj's Reviews
03-20-2008, 06:30 PM
Price: $6.00
Recommended? Yes
Comments: Works smoothly
KEITH TEST
Newbie
KEITH TEST's Reviews
02-18-2008, 10:50 AM
Price: $1.00
Recommended? Yes
Comments: test test
gpJeep
gpJeep's Reviews
08-17-2006, 12:04 AM
Price: $20.00
Pros: east to work with low odour , easy flowing
Cons: bottle top tip not much help used pump
Recommended? Yes
Comments: I tow a boat with my JGC, so the manual staes to use a heavy duty 75w-140 in the rear differential. The only one around was this quaker state stuff.
It is clear in colour and can be loaded into the rear differential with one of those boat outdrive pumps , about $10 at your local car or boat dealer.
The differnetial was easy to open , with only a rubber plug to open the thing up.
Took out the old fluid and then pumped in this stuff , about 1 3/4 liters before the fluid started to come out , oh and one thing I did not know -- add the friction modifier a 4oz bottle 120 ml from your dealer $5 mopar so as to make the LSD limited slip differential work --- back differential only unless you have quada drive then in both difs. The front diff uses 75w-90 synth by motomaster
mine is selcta drive with lsd rear.
So far it's worked great , towed my boat with no problems and am quite happy with the product -- I'll report back in about a year with an update
June 2008 -- stuff still running good in the diff, maybe I'll do a second time , if I get round to it
ThreadForumRepliesLast Post
Richmond Gear Powertrax Lockrite Lockers 4 10-09-2011 07:43 PM
Richmond Gear Powertrax No Slip Locker Lockers 9 09-04-2010 05:37 PM
Richmond Gear Powertrax No-Slip Lockers 9 03-03-2010 03:53 PM
Royal Purple Max-Gear Synthetic 75W90 Gears 2 12-07-2008 01:34 PM
Yukon gear D44 Mini-spool YP MINSD44-30 Lockers 0 10-24-2007 10:09 PM
Glock Forum
