Lube Locker - Lube Locker Differential Gasket Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Gears Next Product
Rating:
Product Information
MSRP: $21.95
Average Price: $23.49
Manufacturer: Lube Locker
Recommended?
Yes: 4 / No: 0
Company Website: http://lubelocker.com/
Designed for uncompromising quality and performance in high demand motorsports, LubeLocker Gaskets are without equal. Rock crawlers, drag racers, and circle track, and desert race patrons will recognize the quality of the rubber coated, steel core construction. LubeLocker’s signature orange elastomer beading emphasizes our single-minded purpose: to be the best differential gasket.
Tired of scraping the mess silicone sealant leaves behind on the differential cover? Ever had to wail on the cover with a hammer to break it free? Service shops will save time on installs, and shade-tree mechanics will get the job done quicker and with less hassle. In addition, customers are less likely to return with leaky differentials. All vehicles deserve clean, grit free differentials with no oil seepage. And racers deserve quick, leak free access to the inside of their axles. LubeLocker Gaskets can retain their seal even if the differential cover shifts, while the orange elastomer beading delivers superior sealing through a wide range of temperatures. Keep the paper in the desk drawer and throw away your RTV—LubeLocker Gaskets are the only differential seal you need
None
Konstadin
Konstadin's Reviews
10-13-2013, 01:43 PM
Price: $30.00
Pros: reusability fast procedure proper sealant
Cons: none
Recommended? Yes
Comments: been using them for 6 years now...
done 6 lube changes so far with no drop leaking yet...awesome product ,makes the procedure superfast .
4whelin
4whelin's Reviews
09-29-2012, 08:00 AM
Price: $21.95
Pros: Great gaskets for the money.
Cons: none
Recommended? Yes
Comments: Put on front and rear, they work great!!!
kyle_craig
kyle_craig's Reviews
10-16-2011, 03:16 AM
Price: $20.00
Pros: No mess, no fuss, easy as pie.
Cons: None yet.
Recommended? Yes
Comments: The lube locker gasket is the only way to go as far as I'm concerned. No spreading or scraping RTV. No mess to deal with...just line it up and go. It seals well and you just use it again when you change diff fluid. If you're installing a locker or gears, you're going to go through a tube of RTV upon install, and another tube when you do your first lube change. By the time you buy a couple tubes of RTV the cost is the same as a lube locker. Save yourself the fuss.
Two thumbs way up on this product!
briguy3030
briguy3030's Reviews
08-01-2011, 07:01 PM
Price: $21.99
Pros: Reusable. Simplicity. No mess
Cons: None!
Recommended? Yes
Comments: AMAZING product! No more scraping old RTV sealant. No more banging on the diff cover to get the cover to release. No fuss!! WELL worth the meager price! Why did it take so long for me to try these?!?!
ThreadForumRepliesLast Post
ARB Air Locker Lockers 101 06-23-2016 03:30 PM
Aussie Locker auto locker Lockers 117 03-13-2015 09:20 PM
Ox locker OX locker Air actuated Lockers 1 01-03-2013 12:20 PM
Ox locker OXD44C392H-30 Lockers 10 12-27-2012 02:11 PM
lincoln locker idk Lockers 1 07-12-2012 03:08 PM
