Go Back JeepForum.com > Reviews > Axles > Lockers > Richmond Gear (Lock-Right) Powertrax No Slip Locker
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Richmond Gear (Lock-Right) Powertrax No Slip Locker Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lockers Next Product
Rating:
Product Information
MSRP: $250.00
Average Price: $224.38
Manufacturer: Richmond Gear (Lock-Right)
Recommended?
Yes: 10 / No: 1
For traction output, strength and durability, the POWERTRAX LOCK-RIGHT Locker. rivals much more expensive competitive lockers sold only as complete case replacement assemblies. It is a leading product because the LOCK-RIGHT delivers as much traction output, its end assembly is exceptionally strong, is much less expensive, and does not require professional installation (because the complete case assembly does not have to be replaced and realigned with precision calibration equipment). An excellent choice for off-road vehicle applications, performance enthusiasts also began using the LOCK-RIGHT LOCKER to satisfy their extreme traction requirements for racing, hot-rods and muscle cars.
The LOCK-RIGHT's operation is fully automatic. Designed to send the engine power to the wheels with the most traction, the LOCK-RIGHT will help get you where you want to go. While traveling straight the LOCK-RIGHT will lock the axles together similar to a spool. However, when the wheels need to differentiate in a turn, the LOCK-RIGHT will allow the outside wheel to rotate faster to complete the turn. The internal gears on the LOCK-RIGHT will overrun each other to allow this differentiation.
When operating off-road, the LOCK-RIGHT will always send the engine power to the wheels that need it most. For example, if you are rock crawling and one wheel is in the air (complete loss of traction), the wheel on the ground will receive the engine power and keep you going. Whether it be snow, sand, mud, ice, etc... the LOCK-RIGHT will give you the traction you need.
Although smoother than other competitive locking differentials, the brute force characteristics of the POWERTRAX LOCK-RIGHT Locker limit general application in less tolerant and more mainstream applications. In some vehicles, you will hear a light clicking noise as the gears are overrunning themselves and allowing the wheels to differentiate in a turn. This is normal of most lockers on the market today. We recommend the LOCK-RIGHT for vehicles that are primarily driven in severe driving conditions or are used for recreational off-road. For vehicles that are driven daily or require more mainstream application, the POWERTRAX TRACTION SYSTEMS offer a quieter and smoother performance
KennYJ
Junior Member
KennYJ's Reviews
07-17-2011, 10:56 AM
Price: $275.00
Pros: cheap
Cons: very loud
Recommended? No
Comments: I installed one of these in my 8.8 and was amazed at how much driveline slack it created. Since by design there is so much play between the locker and the cross pin every time you are on or off the gas there is a loud clunk. When trying to go slow sometimes all that slack will cause the jeep to start to lurch and buck making an unbelievable racket.
Drive line slack = shock loading = broken parts.....
I am going to put my lock right back in the box and order an ARB, should have just done that to begin with
wayno32m
wayno32m's Reviews
06-08-2011, 09:17 PM
Price: $234.00
Pros: somewhat easy install (for novice)
Cons: instructions could be more specific to applications and photo`s are copies of copies in b&w (waste)
Recommended? Yes
Comments: I just installed the lockrite (i`m a novice) in my dana 30 and i thought i was over my head at first (damn seals gave me a headache) but i got it in and so far it works great, the directions could be better.
josh9465
josh9465's Reviews
04-07-2011, 08:28 PM
Price: $430.00
Pros: great locker.
Cons: can be harsh on axle splines
Recommended? Yes
Comments: these twisted by stock axle splines. upgraded to alloy axles and seem to be good so far. this was my only locker in the TJ for a few years before i got an eaton elocker in the rear and it got me through most obstacles.
broncofire75
broncofire75's Reviews
05-21-2009, 10:03 PM
Price: $220.00
Pros: Locks them down good. Crazy traction
Cons: Kinda hinder U-turns
Recommended? Yes
Comments: Love mine!
Got it from alljeep.com for $220. Best price Ive found.
Fire-XJ
Fire-XJ's Reviews
12-22-2008, 07:21 PM
Pros: Awesome off road traction
Cons: Very clunky on dry pavement
Recommended? Yes
Comments: I got this about 4 months ago and installed into my D35C rear. Installation was not too hard. It took about 2.5 hours, including jacking the Jeep up, etc. Instructions were very straightforward and easy to follow. First trip around the block after the installation scared me to death. It sounded like the hole rear end was coming apart. I thought I screwed something up. But the wheels kept turning so I kept going. After a few miles things quieted down a bit.
Four months later I am not certain I will keep this thing installed. Traction in mud and sand is great. But backing out of the driveway it sounds like the rear end is falling apart. Sometimes on corners, the inside wheel will spin about a half a turn and then suddenly the locker engages and the Jeep launches into the corner. Occasionally it will do the same thing when taking off in a straight line from a dead stop. I am curious to see what this acts like if and when we get some snow or ice. I think that will determine if I keep it or not.
erickpl
erickpl's Reviews
11-24-2008, 11:30 AM
Price: $150.00
Recommended? Yes
Comments: Why do I need 75 characters to provide a review? I Just want to list em. Adding characters to shut this thing up.
hyperboarder
hyperboarder's Reviews
11-18-2008, 09:17 PM
Recommended? Yes
Comments: I like it. It locks well. And it's easy to install. And it came free with my D30.
odwaud
odwaud's Reviews
09-29-2008, 07:12 AM
Recommended? Yes
Comments: ha dont take that offroad. i destroyed mine on a hill climb in about 10 minutes.
thomasj7186
thomasj7186's Reviews
06-12-2008, 10:15 PM
Price: $96.00
Recommended? Yes
Comments: awesome cheap and works good too!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
JOJ 91 xj
JOJ 91 xj's Reviews
04-29-2008, 02:47 AM
Price: $250.00
Recommended? Yes
Comments: This is good when you need it but sometimes it makes your *** end walk when you don't want it to in the snow and there is no way to disengage which sucks...kills the on road performance and the clicking sound makes it sound like something is wrong with your rig
cj847
cj847's Reviews
04-14-2008, 09:11 PM
Price: $140.00
Recommended? Yes
Comments: Works great. Love it.
ThreadForumRepliesLast Post
Aussie Locker auto locker Lockers 89 01-21-2012 10:09 PM
Richmond Gear Powertrax Lockrite Lockers 4 10-09-2011 07:43 PM
Richmond Gear Powertrax No Slip Locker Lockers 9 09-04-2010 05:37 PM
Richmond Gear Powertrax No-Slip Lockers 9 03-03-2010 03:53 PM
Richmond Gear (Lock-Right) Powertrax No Slip Locker Lockers 25 10-03-2009 09:12 AM
Glock Forum
