Go Back JeepForum.com > Reviews > Axles > Lockers > OEM Jeep Limited Slip Differential
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
OEM Jeep Limited Slip Differential Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lockers Next Product
Rating:
Product Information
MSRP: $75.00
Average Price: $87.75
Manufacturer: OEM Jeep
Recommended?
Yes: 9 / No: 1
Any OEM Jeep LSD available from the factory.
TJJeepGirl
TJJeepGirl's Reviews
04-07-2011, 04:04 PM
Price: $1.00
Pros: good street performance
Cons: not a locker
Recommended? Yes
Comments: Didn't know I had it till I changed the diff oil. Seems to work good on the trail.
johnanas
johnanas's Reviews
08-15-2010, 11:37 PM
Price: $175.00
Pros: doesnt eat up my tires on the pavement....
Cons: none yet
Recommended? Yes
Comments: just got it it put in cuz my stock carrier and gears were toast. i bought an axle from junkyard to use internals and found that it had trac loc in it..... so it was kind of a surprise upgrade when i redid my gears.. i havent really had a chance to test it good but i drive on the highway to work and is a constant dd while also my toy so cant lock it alll the way and this works good so far...
Planetcat
Planetcat's Reviews
02-02-2010, 06:11 PM
Price: $129.00
Pros: Fits a variety of applications using Dana Spicer axles and diffs.
Cons: Useless, barely engages, clutch packs wear out.
Recommended? No
Comments: I installed a new one 7 years ago in my XJ (Dana trac-lok) and a detroit true-trac in the front. I wish I hadn't even wasted the money on it as it is useless, even from the beginning when the clutch packs were new. The true trac does all the work. I'm not sure I've even seen both tires spin with this LSD on gravel. I would rather run an open diff than put this thing in again.
evan1395
evan1395's Reviews
11-15-2009, 11:33 PM
Price: $220.00
Pros: The trac lok is an awesome limited slip. A little pull on the emergency brake in the snow or mud and it practically locks itself. Smooth operation, and just as good as a Detroit true Trac
Cons: IT LOVES THE LIMITED SLIP ADDITITVE!!!! ($$$)
Recommended? Yes
Comments: Great Factory Limited Slip id say. and no side effects of a locker, but almost as good with the right throttle play
mtnmarc
mtnmarc's Reviews
11-06-2009, 01:40 PM
Price: $1.00
Pros: came in stock! helped when i needed it (hanging a tire)
Cons: none
Recommended? Yes
Comments: it camestock, so i cant say anything bad about it. if i ever wanted to get a new locker, selling it would make a lil money
Luke94XJ
Luke94XJ's Reviews
09-28-2009, 12:58 AM
Price: $100.00
Pros: it works!! both tires spin. Rooster tails on gravel roads.
Cons: definitely gives more torque to one side, but barely
Recommended? Yes
Comments: I got this LSD axle for free, because I helped a friend transfer his built up lift onto another Jeep shell. That shell was on supposedly "junk" axles, when he bought it. We took the axles off and noticed that the rear tires spun the same direction, after pulling the cover, I realized it was posi!! I bolted the feller up and Its been working out great. I definitely have more grip in slippery conditions. I would highly recommend this, if you can find a cheap one. Jys tend to charge too much for axles nowadays.
cglez81
cglez81's Reviews
03-16-2009, 09:10 AM
Recommended? Yes
Comments: Let you know once I really get to use them have not heard to much negatives about them
cdsmith_2002
cdsmith_2002's Reviews
02-14-2009, 07:21 PM
Price: $75.00
Recommended? Yes
Comments: Better than nothing, I don't care what you guys say!
peeweeXJ
peeweeXJ's Reviews
01-26-2009, 01:50 PM
Pros: Automatic action, OEM
Cons: Consumable parts (friction materials)
Recommended? Yes
Comments: I have a fresh rebuilt D44 with 3.73's and trac-loc in the rear end of my Jeep. Not too sure the friction materials will stay together for that long, but I am happy with the performance of it. Very nice to have. Spins awesome donuts
abeshures
abeshures's Reviews
11-11-2008, 07:27 PM
Price: $1.00
Recommended? Yes
Comments: i love the rubicons stock lockers and limited slip. I did the 4wd bypass and was the best mod i ever did. having lockers in any range is awesome
ThreadForumRepliesLast Post
Richmond Gear (Lock-Right) Powertrax No Slip Locker Lockers 9 07-17-2011 10:56 AM
Richmond Gear Powertrax No Slip Locker Lockers 9 09-04-2010 05:37 PM
Richmond Gear Powertrax No-Slip Lockers 9 03-03-2010 03:53 PM
Auburn Gear ECTED (Electronically Controlled Traction Enhancing Differential) Lockers 16 12-04-2009 10:30 PM
Richmond Gear (Lock-Right) Powertrax No Slip Locker Lockers 25 10-03-2009 09:12 AM
Glock Forum
