Notices
Detroit TrueTrac Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Lockers Next Product
Detroit TrueTrac
Rating:
Product Information
MSRP: $1,400.00
Average Price: $472.49
Manufacturer: Detroit
Recommended?
Yes: 49 / No: 2
helical, gear-driven limited slip.
None
Page 2 of 3 1 2 3 > Last
89wangler
89wangler's Reviews
12-01-2010, 01:17 AM
Price: $500.00
Pros: rear locks when it is supposed to . Doesn't chew up tires
Cons: none that i have found yet
Recommended? Yes
Comments: I paid to have it installed because i have been in a couple of trucks / cars where people who said they knew what they were doing did their own and then they howl or just lock up and slide off the road at 35 mph not fun worth the dough imho i also spent a little extra and had new bearings races and seals done on my 8.8 should last forever lol ill probably get hit by an old lady in a parking lot as soon as i get out on the road .
smokinlib1
smokinlib1's Reviews
09-27-2010, 08:01 PM
Price: $499.99
Pros: Works great no slip
Cons: Lots of noise after it warms up
Recommended? Yes
Comments: Works as advertised. Not very noisy when turning but after it warms up it clunks hard when going into gear. Am told this is normal operation though.
Ripper3494
Ripper3494's Reviews
09-22-2010, 11:52 PM
Price: $350.00
Pros: easy on the road
Cons: doesnt lock up very quickly offroad, takes awhile
Recommended? Yes
Comments: its great for light offroading, but once you get one tire completely off the ground it does nothing, and even sometimes when they're both down it wont lock untill its been spinning for a long time
TurdyFive
TurdyFive's Reviews
08-01-2010, 10:16 PM
Price: $500.00
Pros: Great traction. Always on. No friction discs. No additives needed.
Cons: A little squirrelly on asphalt at first.
Recommended? Yes
Comments: I have True-trac's front (D44) and rear (D60) in my TJ. Great traction. I thought I might regret not putting a locker in the rear but the True-trac has proven me wrong.
FireJeep540
FireJeep540's Reviews
07-30-2010, 02:07 PM
Price: $450.00
Pros: Quality product
Cons: has helped one tire in the front wear away faster then all others
Recommended? Yes
Comments: Great in the dana 30 in the front of my jeep would recommend adding switch able hubs and frequent rotation of tires. awesome off road performance.
acompgeek
acompgeek's Reviews
06-30-2010, 03:30 PM
Price: $450.00
Pros: Transfers power great.
Cons: It's never going to be the same as a locker.
Recommended? Yes
Comments: If i had a lower fist gear i could get away with not using 4wd most of the time, it's really amazing how far i can get in 2wd now. My first test was to start one wheel on pavement and one in gravel then floor it and the tire in the gravel barely lost traction, i could feel the power transfer almost instantly.
rednecknguy
rednecknguy's Reviews
04-17-2010, 09:24 PM
Price: $348.00
Pros: Great product havent broke it yet
Cons: none
Recommended? Yes
Comments: If want to get where you want i would buy a locker
crawler86
crawler86's Reviews
03-23-2010, 01:20 PM
Price: $200.00
Pros: Great upgrade
Cons: haven't had any yet
Recommended? Yes
Comments: This is a great addition to the D35 w/ 4.10's. I'm able to rock crawl on fairly intermediate stuff. The pic in my profile is from the PA Jeep show and it came in handy. I have yet to have problems with the locker yet. Makes a huge difference.
Planetcat
Planetcat's Reviews
02-02-2010, 07:06 PM
Price: $475.00
Pros: Long lasting, clutchless, limited slip. Aggressive and reliable engagement.
Cons: Whines sometimes in front diff on road.
Recommended? Yes
Comments: This is an amazing limited slip. Had it on front Dana 30 in my XJ for 7 years. Continues to work flawlessly in low traction surfaces. Not quite as tight as a locker, but you know it's kicking in when it needs to. The gear driven design is bullet proof and flawless. Kicks butt on factory LSD's. Put one on my WJ too. Same results.
Netpackrat
Netpackrat's Reviews
12-15-2009, 07:44 AM
Price: $1.00
Pros: Works good, lasts long time, no clutches to wear. No price because I received it as a gift.
Cons: With the truetrac in the front, the Jeep requires a firm hand at the wheel when driving on slippery roads. It's perfectly safe, you just have to stay on top of it when you are on the throttle on the ice.
Recommended? Yes
Comments: If you live where the roads get nasty, and want to enhance your front axle, this is the differential to buy. Lockers are not safe on winter roads, and clutch pack LSDs are no good in the front because of the pre-load. Selectable lockers like the ARB or the Ox are fine off-road, but you won't derive any on-road benefit from one. The Truetrac is great off road, and also helps on slippery roads, while still being controllable under street/highway conditions. Yes, you will know it is there, and yes, you have to stay on top of it, but it's safe and easily controlled. It's really only noticeable when changing lanes with snow and/or ice bermed up between the lanes, especially if you are on the throttle.
Mine's been working flawlessly for over 8 years, and well over 80,000 miles.
SjT2107
SjT2107's Reviews
11-17-2009, 01:42 PM
Price: $200.00
Pros: Better than an open rear
Cons: Terrible under stress
Recommended? No
Comments: Its good for light wheeling but when its put against something & torqued or the JEEP is flexed right out it wont work like it should
JeeperFound
JeeperFound's Reviews
11-08-2009, 07:39 PM
Price: $1.00
Pros: Works excellent! Bullet proof product!
Cons: None so far!
Recommended? Yes
Comments: I don't know if it is the product or just my Jeep but it ever since it was installed I get a pretty big pop coming from the rear end of the Jeep during acceleration. The pop ether comes from the left or the right side of the rear end.
sracer2005
sracer2005's Reviews
10-06-2009, 03:46 AM
Price: $800.00
Pros: Awesome traction
Cons: no option to have open 4wd
Recommended? Yes
Comments: Great traction. Awesome price
mtxbigtruckin
mtxbigtruckin's Reviews
03-30-2009, 01:16 PM
Detroit TrueTrac
Price: $1,400.00
Recommended? Yes
Comments: Great lockers, had them professional installed which I think is actually the key!
gabriel05
gabriel05's Reviews
03-12-2009, 02:53 PM
Detroit TrueTrac
Price: $425.00
Recommended? Yes
Comments: Works great in the snow. You don't even notice that it's there during daily driving. When you put it in 4WD you can for sure feel the added traction. Highly recommended for someone that needs better performance but still wants a very streetable rig.
shaggyjim
shaggyjim's Reviews
03-11-2009, 09:12 PM
Detroit TrueTrac
Price: $400.00
Recommended? Yes
Comments: The True Trac is a great half way point. Not a locker but not a clutch LS. Works great in the road in the front or back. But works best with a auto trany.
voodo3184
voodo3184's Reviews
03-04-2009, 05:43 PM
Detroit TrueTrac
Recommended? Yes
Comments: how can you go wrong with a locker? works great no problems easy install. great product
MyBrokenJeep
MyBrokenJeep's Reviews
02-13-2009, 12:24 AM
Detroit TrueTrac
Price: $1,150.00
Recommended? Yes
Comments: Highly recommended! Has not let me down yet! Taken me anywhere I have wanted to go!
hoghandler
hoghandler's Reviews
02-11-2009, 02:21 PM
Detroit TrueTrac
Price: $850.00
Recommended? Yes
Comments: Fantastic locker, i can't imagine wheeling without it anymore. came with the super 35 kit, 30 spline axle shafts
eastin82
eastin82's Reviews
02-01-2009, 07:12 PM
Detroit TrueTrac
Price: $1,000.00
Recommended? Yes
Comments: made a huge difference
ThreadForumRepliesLast Post
Tractech Detroit Locker Lockers 34 08-07-2015 08:26 AM
Detroit Soflocker Lockers 26 08-19-2013 09:47 PM
Eaton Truetrac Lockers 7 09-09-2012 10:58 PM
Tractech Detroit Truetrac Lockers 6 07-18-2012 07:10 AM
Tractech Detroit Truetrac Lockers 4 04-03-2010 09:50 AM
