Go Back JeepForum.com > Reviews > Interior > Misc > U-Pol Raptor
Official Chassis Saver Rust Preventive Truck & Auto UnIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineTJ 5.25" Speaker Adapters - NalinMFG
U-Pol Raptor Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Misc Next Product
U-Pol Raptor
Rating:
Product Information
MSRP: $100.00
Average Price: $102.62
Manufacturer: U-Pol
Recommended?
Yes: 16 / No: 0
tub liner
SirCrisp
SirCrisp's Reviews
12-06-2011, 08:47 PM
Price: $100.00
Pros: strong, looks good, easy and affordable
Cons: 3rd bottle got sealed on gun while spraying, i was unable to remove it and it left me without enough spray.
Recommended? Yes
Comments: Other than what was probably a user error this stuff is fantastic
owp3
owp3's Reviews
10-28-2011, 03:42 PM
Price: $109.99
Pros: Easy to apply. Durable. Looks great
Cons: Smells. The included gun has a little hole in the top and it is easy to spill a little out on your project if you aren't careful. Difficult to know which product includes the gun and which does not.
Recommended? Yes
Comments: I put this on my grill, headlight bezels and interior. It was very easy to apply and appears to be quite durable. I let it cure for 48 hours before I attempted to reinstall my interior. Also, it is important to remove and masking tape within an hour of applying your last coat.
It took me one box and one extra bottle to do the complete project.
Spend double the amount of time prepping that you think you will need.
kornonthekob99
Junior Member
kornonthekob99's Reviews
10-25-2011, 08:54 AM
Price: $100.00
Pros: STRONG METAL PROTECTION
Cons: NEED TO REALLY PREP WELL
Recommended? Yes
Comments: MY FRIEND HAD A LEFTOVER CAN AND SPRAYED A COAT ON THE INSIDE OF MY YJ... EVEN A DECENTLY QUICK PREP JOB LEFT SPECTACULAR RESULTS... REALLY STRONG LINER
Ziggy43
Ziggy43's Reviews
09-16-2011, 09:02 AM
Price: $70.00
Pros: Great blue lcd screen excelent cell speakerphone
Cons: none
Recommended? Yes
Comments: Installed a Dual CD/MP3 USB player that fits perfect into the dash, great 200 watt power with Bluetooth function, great speakerphone fuction. Has bluee lcd light with mactches overhead light set up.
StuddMuffinz
StuddMuffinz's Reviews
07-25-2011, 10:53 AM
Price: $111.00
Pros: Ease of use, great end result, deec price
Cons: you need to have an air compressor capable of maintaining at least 40 psi
Recommended? Yes
Comments: With all of the DIY liners out there, its hard to tell the difference between the great, and the not so great. After seeing Herculiner, Monstaliner, Duplicolor, and U-Pol Raptor each in person, I knew that Raptor was the way to go. It doesnt fade, looks consistent, and has a great texture. Although the end result is 90% dependent on prep work, it doesn't hurt to have an awesome product. Props guys
MontesXJ
MontesXJ's Reviews
10-19-2010, 05:12 PM
Price: $100.00
Pros: Easy to apply with the included spray gun Novice painters can provide a professional-looking finish Appears to be durable, but not yet time-tested
Cons: Hardens quickly inside the bottle; must apply entire bottle in single application or material will gunk up and block your spray gun
Recommended? Yes
Comments: Product applied easily and covered well on the first coat. You would have to try real hard to mess up the application. This was my first attempt with a spray gun and I got a very nice professional finish. So good, in fact, I didn't reinstall the carpet. It dried quickly and was ready for additional coats within about 30 minutes. It looks great and appears to be durable, but you'll need to ask me in a year to see how it held up. One word of caution...once mixed with the hardener, the material thickens quickly. I had about half a bottle left after my second coat and let it sit for about 30 minutes to dry. When I tried to reapply to touch up some areas, the gun failed to work. The material had already gunked up in the bottle and clogged my spray gun. The remaining material was totally wasted and I have to dismantle the gun and clean with solvent before I could start again.
MDEnce
MDEnce's Reviews
08-12-2010, 02:47 PM
Price: $125.00
Pros: durable, looks good, easy to apply
Cons: pain to prep for spray in. Also be prepared for more road noise and heat from the floor after you do this.
Recommended? Yes
Comments: Raptor liner spray in bed liner is everything the other threads on this forum say it is. Sure it's a pain to prep for spray in - but the more prep you do the better the end result. My biggest problem was getting the trox screws out of the roll cage mounts. Ended up grinding about 1/2 of them down on the sides and using vise grips on the sides. Spray in was easy with the included undercoating gun, but you do NOT want to get this stuff anywhere other than the tub of your jeep. Of course, the floor is now hotter and louder than with the carpet and pad, but it's a Jeep Plus is sure is easier to clean now
BM20
BM20's Reviews
05-15-2010, 09:06 PM
Price: $100.00
Pros: looks better, protects the tub when the carpet is out
Cons: prep is the key, take your time
Recommended? Yes
Comments: Much better looking than the bare tub when I take the carpets out in the non-winter months. Prep work is important. I didnt do it as well as I should have so I occasionally need to touch up spots that chip off after a hard hit. Dont tip the gun when spraying with a full bottle, it will spill out.
Overall, I love it.
sgttaylor83CJ7
Junior Member
sgttaylor83CJ7's Reviews
03-24-2010, 08:35 AM
Price: $104.00
Pros: Easy install, great finish
Cons: None.
Recommended? Yes
Comments: I love this product. I made the mistake of trying to use up the left over by thicking up some high traffic areas (mostly the floor pans). I dont think that was a good idea. It cracked in one area where I put it on real thick. I also could have done a poor prep job in that area, but who knows.... Still think it was a great product, I think the problem was my fault. The good news is that with the rough texture finish I can fix and blend my repair in very well.
I only used three of the four bottles that came with the kit. Had I known that, I would have had some other projects prepped and ready to be sprayed (wheel wells, frame undercoat, etc.).
Mayfair_Jeeper
Jack *** of All Trades
Mayfair_Jeeper's Reviews
01-06-2010, 10:21 PM
Price: $87.89
Pros: easy to put in. Nice and solid once it cures
Cons: Smells nasty
Recommended? Yes
Comments: Take your time masking. Makes all the difference. And do not put in seats until it is fully cured (about 3 days). It is easy to pull up until its cured.
vettefever5
vettefever5's Reviews
10-02-2009, 01:47 PM
Price: $99.00
Pros: very easy to spray, looks great
Cons: a lot of prep work, but that is inherent with any bed liner
Recommended? Yes
Comments: please see my complete review of the product, as well as my experience and pictures in my thread:
http://www.jeepforum.com/forum/f9/my-upol-raptor-experience-pics-lessons-learned-870197/
th3br4d
th3br4d's Reviews
09-20-2009, 03:49 PM
Price: $115.00
Pros: Easy to mix, easy to spray, durable, great spray pattern
Cons: Kind of smelly but goes away after about 2 weeks.
Recommended? Yes
Comments: I was reading the threads across the forum about the Upol Raptor liner and decided this was the one I wanted to go with. I purchased it on ebay and had it at the door within a week. It came with easy to follow directions, I used 60psi to spray the liner in with. I put the seats back in 2 days later. I've had it in for about 3 weeks now and it is still a tad smelly in the jeep but I'm sure it will be completely gone soon. Good product overall and would recommend to all
kellerumps
See Ya Coach.
kellerumps's Reviews
08-27-2009, 03:00 PM
Price: $110.00
Pros: Very Very Easy to use
Cons: Non So far
Recommended? Yes
Comments: Prep work is the key. I spent approx 15 hours sanding and cleaning and then another 3 hours taping and laying plastic. The first bottle went ALOT quicker than I realized. Adjusted the air pressure a little on each additional bottle and it seemed to last alot longer. I would recommend using a measuring cup for the hardening agent. I like to cook so eyeballing something isn't an issue, but pouring a clear liquid into black goo in a black bottle concerned me.
In all the finished product looks amazing. Well worth it...IMO.
2006_Sport
2006_Sport's Reviews
07-19-2009, 12:14 AM
Price: $110.00
Pros: Cost effective and looks great
Cons: none
Recommended? Yes
Comments: Good product. Only time consuming part is prepping
jim_bert
jim_bert's Reviews
07-08-2009, 11:56 PM
Price: $100.00
Pros: awesome, easy to use, looks amazing
Cons: none yet
Recommended? Yes
Comments: no experience spraying anything at all and this stuff came out amazing. If youre gonna line your tub, get this stuff, spend the $600 or so you save on some other cool stuff
bjperk3
bjperk3's Reviews
02-17-2009, 11:21 PM
U-Pol Raptor
Price: $100.00
Recommended? Yes
Comments: Much cheaper than having it done. Easy enough to do. Key is in prep work. Satisfied so far. Have to see how it holds up.
Glock Forum
