Tuffy Tuffy Stereo Security Console
Rating: |
Product Information
| MSRP: |
$600.00 |
| Average Price: |
$235.17 |
| Manufacturer: |
Tuffy |
| Recommended? |
Pry-Guard construction with pick-proof tubular locks. This heavy gauge steel box with all welded joints is finished with a durable epoxy wrinkle finish. Two drink holders and sunglasses holder complete the exterior. Inside the large storage area there's a small valuables holder. Grade 8 installation hardware.
MaddBones702's Reviews
Price: $300.00 Pros: Incredible Cons: Can't see any Recommended? Yes
Comments: Holds a ton of stuff. Don't have to worry about someone getting in to it
kornonthekob99's Reviews
Price: $250.00 Pros: super strong , great for storage in jeep Cons: stereo slot not so convenient to service, must custom mount console through floor... NEED A HELPING HAND Recommended? Yes
Comments: i love the concept of this box but ironically i did not end up using the stereo slot for my radio... i took the bin that sits in the dash where the stereo is now installed and slipped it into the slot in the console... the console, once installed is a ***** to take out and service a radio... unless u weld nuts into the floor... but i absolutely love it now that its in
RebuildRookie's Reviews
Price: $100.00 Pros: Very solid. Very Secure Cons: None at this time Recommended? Yes
Comments: I bought this used and it still works as good as new. I like having the radio right there at my finger tips when I put my arm on the armrest. Front legs are easy to bolt down. Rear legs are a little bit trickier. Still looking for best option to hide speaker and power wires from being exposed since the radio is no longer installed in the dash.
parrothedjustin's Reviews
Price: $35.00 Pros: Tuffy console protects my valuables from rain and the low life wondering around. Built out of thick steel with a tough integrated lock. This product is a great buy especially if you can find one for cheap. The cupholders can also be moved from the front side to the back. Cons: I wish the box was completely sealed to better protect against water. Also there needs to be a hole connecting the stereo compartment to the main compartment for wire routing. Recommended? Yes
Comments: Overall I would recommend this product tot anyone who wants a product that protects your valuables against the elements and thieves as well as a cool and convenient place for your stereo. The few cons I came up with can easily be modified.
89wangler's Reviews
Price: $80.00 Pros: lock stereo and nice arm rest great unpickable key lock cup holder that are deep Cons: wish it had a better mount in the rear and if you have a five speed and you go w/ cup holders its mounted right up on it . Recommended? Yes
Comments: went together easy the lock is a little tight and i ended up ditching their foam for some of my own. but theres enough room in there for every thing i even put a small amp inside for my stereo drilled a couple holes and preasto!!
Lemoore-on's Reviews
Price: $200.00 Pros: Fort Freakin Knox! Cons: Pricey Recommended? Yes
Comments: This thing is awsome. Fit and Finish are high quality. Seems indestructable. I mounted a small amp to the underside, then mounted it.
YWU
 Junior Member |
YWU's Reviews
Price: $235.00 Pros: Seems very secure. High quality construction. Comfortable arm rest. Cons: None. Recommended? Yes
Comments: I am very happy with this product. Installation was easy. I used self tapping screws instead of bolts from under the body.
bj19734's Reviews
Price: $285.00 Pros: Strong durable console Cons: Hard to install sub box using MDF. Recommended? Yes
Comments: Very good buy. Very secure. Wish the console had more room to store things, but that is the price you get to install the subwoofer
00dutchTJ's Reviews
Price: $441.74 Pros: Secure and fits perfectly. Cons: none Recommended? Yes
Comments: Great Product. Very secure and fits perfectly. I have no complaints.
Nicho's Reviews
Price: $350.00 Pros: Significant theft prevention. Cons: Less than desirable instructions. Recommended? Yes
Comments: Much more complicated to install than the one in m YJ. The 6 speed shifter set up looks a bit unfinished, there are two open slots closest to the seats. Overall very capable product.
JeffreyCharles's Reviews
Price: $258.99 Pros: Excellent construction, sturdy and secure. Great locking mechanism. Has a nice satisfying sound when closing the lid - it even sounds secure! Cons: A bit pricey. No simple way to bring wiring into the main compartment without drilling. Recommended? Yes
Comments: Easy to install, took about an hour - including drilling three holes through the bottom of the body tub. Provides a handy, safe place for storing things like my CB, flashlights, etc. Has a separate compartment for a standard DIN-sized stereo. This locks when the main lid is closed and locked (can also be left open when the main lid is closed).
The one thing I'd like to see is the inclusion of a hole in the main box large enough to accomodate wiring - if I wished to mount the CB inside the box for instance. As it stands I'd have to drill my own hole. Not a big deal but it seems like it would be easy enough to provide this, prior to the paint being applied, at the factory.
Otherwise I love it.
KUJeeper82's Reviews
Price: $150.00 Pros: Very secure with lots of space! Cons: Price if bought new; wide version + Shorty Female seatbelts = PITA... best to upgrade to the longer style at the same time... Recommended? Yes
Comments: I lucked out and picked one of these use NIB from a fellow jeeper who was down on his luck financially... $150 (this are normally $250 new).
Try to find a used one if at all possible... these are bricks and last a long time!
southbound's Reviews
Price: $225.00 Pros: Stout, looks great, locks up both valuables and a radio. Cons: Installation requires drilling 3 holes through the tub for the retention bolts. Must rewire radio to reach from the console to the factory connection. Recommended? Yes
Comments:
I got this console with the insurance money I received after my Jeep was broken into. The thief tried to steal my radio and tore up my dash. I haven't had any major issues with this console. It is a great product that does exactly what it's supposed to. I never worry about my radio being stolen again.
smoothop's Reviews
Price: $252.00 Pros: Well built, durable, solid Cons: scratches easily, weird stereo angle mount, lock resonates at certain RPM's (annoying rattle), does not include shock absorber to keep lid up, could be more eye pleasing to look at. Recommended? Yes
Comments: I had been looking for a center console for almost a year to replace the horrible home made contraption the previous owner had installed. I was deciding between the MaxBilt and the Tuffy Console, for me it came down to customer service. I emailed MaxBilt several times and never got a response, the rep from Tuffy responded immediately and verified my measurements ensuring that the console would fit. He even gave me tips on how to run stereo wires etc.
So I ordered up my tuffy console and boy is it impressive. Its solid and heavy, it feels super high quality. After doing some prep work to make sure the console would fit the way I wanted it to I noticed that it was quite easy for the surface of the console to get scratched. This to me is the biggest flaw of this product, the finish seems to easily scratch. I really wish Tuffy had coated the outside of the console with some sort of textured vinyl finish. It seems silly to paint the outside of the console and have it get scratched up every time something rubs up against it.
All in all I am very happy with the console, the 67 degree mount is a little bit odd, but it is very convenient. I wish tuffy would release a list of stereo manufacturers who's product would work with the console, as this would be easier to narrow down the options. At this point its kind of a crapshoot to figure out which stereos will work without skipping and which ones won't. I am still trying to figure that part out.
If you are looking for a well made console that will give you piece of mind for storing your valuables, this is the console to get. The customer service is excellent, the sales reps are patient and take the time to answer all the questions that you may have. The product design is well thought out and functions flawlessly. I just wish at this price point that tuffy used a more durable type of finish that doesn't scratch so easily.
slinkyj's Reviews
Price: $225.00 Pros: Tough as nails, Secure, Easy Install Cons: Interior seal prone to failure, Arm cushion wears prematurely Recommended? Yes
Comments: Installed this product in less than a day. Never felt more secure about my stereo and misc. items in my Wrangler. The locking mechanism for these units are just about bulletproof. I really have a hard time remembering what it was like before I had one of these. I am currently on my second Tuffy console and have loved both of them. They really stand up to abuse. My new one has cupholders, a slot for my CD player and serious storage space for just about anything. I would recommend these to any new Jeep owner as a first interior upgrade.
Petey0844's Reviews
Price: $320.00 Pros: the thing is a beast...heavy gauge still and the lock on it is a monster. Cons: didn't work so well with my T case drop. Shifter hits Recommended? Yes
Comments: as long as you don't have a T case drop it is unbeleiveable but you shifter will hit if you do have one, unless you bend the shifter. I just put in the SYE and ADJ UCA's and got rid of the T case drop works great.
plumber1's Reviews
03-03-2009, 02:14 AM |
Price: $1.00 Recommended? Yes
Comments: great product, I feel much safer with my valuables locked up. Also nice place to mount the CB
Leans93's Reviews
01-19-2009, 09:19 PM |
Price: $250.00 Recommended? Yes
Comments: I love this thing! I don't know how I survived without one. Keeps my radio and valuables safe. The arm rest and cup holders are a bonus! I recommend every Jeep owner get one of these.
TJTony's Reviews
01-13-2009, 01:49 PM |
Price: $200.00 Recommended? Yes
Comments: seems to be secure, but the cup holders suck and the lock always comes loose.
Jumphog's Reviews
01-01-2009, 10:25 AM |
Recommended? Yes
Comments: Provides security for those items I can't take with me! Also keeps my stereo system under lock and key, in addition to protecting it from mud/water that SOMETIMES get into the cab!
