Go Back JeepForum.com > Reviews > Interior > Misc > Quadratec TJ Dome Light Switch
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Quadratec TJ Dome Light Switch Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Misc Next Product
Rating:
Product Information
MSRP: $25.00
Average Price: $18.00
Manufacturer: Quadratec
Recommended?
Yes: 9 / No: 0
Deluxe Dome Light Switch w/ Harness for TJ
This is our best and most convenient solution to TJ dome lights remaining on when the doors are removed. Kit installs in a matter of minutes to allow dome lights to be deactivated with the flip of a switch. Includes detailed instructions, switch and a fused harness. No drilling required. Switch is concealed under the right corner of your dash. Always remember to wear your seat belt.
Also consider these side-view mirror options.
1 Year Limited Warranty.
fsSnowboard
fsSnowboard's Reviews
05-03-2011, 06:27 PM
Price: $29.99
Pros: Easy to install
Cons: None
Recommended? Yes
Comments: It works well to cut off the door switch/interior lights when you have your doors removed. It also removes the lights on warning sound so be careful to not leave your lights on when you park your Jeep.
greenone
greenone's Reviews
10-14-2010, 04:36 PM
Price: $1.00
Pros: Takes care of the light when the doors are off.
Cons: None.
Recommended? Yes
Comments: If you ever take the doors off your Wrangler, I highly recommend this. Easy to install and SO worth it.
99GeePTJ
99GeePTJ's Reviews
03-27-2009, 11:00 PM
Price: $20.00
Recommended? Yes
Comments: I like it, I don't need to worry about losing the cheaper screw on clips. It may have been around 20 bux but it's a piece of mind switch at an arms length away.
NBFarmboy
NBFarmboy's Reviews
08-07-2008, 10:13 AM
Price: $20.00
Recommended? Yes
Comments: works well, hard to find once put in unless you are on the floor looking for it, easy to install
johnnyw104
johnnyw104's Reviews
04-21-2008, 06:54 PM
Price: $25.00
Recommended? Yes
Comments: this is great and so much better than using the clips
Disconnect
Wandering Techie
Disconnect's Reviews
03-21-2008, 07:35 AM
Price: $20.00
Recommended? Yes
Comments: Dead simple, dead easy.
59WildWillys
59WildWillys's Reviews
03-15-2008, 10:30 PM
Price: $10.00
Recommended? Yes
Comments: Works good
Panici
(O|||||||O)
Panici's Reviews
01-16-2008, 10:05 PM
Pros: A quick flip disables dome lights, and door chimes. No more pulling that fuse!
Cons: Loss of "headlight on" warning, but that is not the switch's fault, same thing happens when you pull the fuse.
Recommended? Yes
Comments: Works great for me, allows me to turn off the dome lights and radio buzzer (when the key is in the ignition, and your listening to tunes with the engine off, and the door(s) open.
When I pull the passenger side door, i just flick the switch off.
Manateu
Manateu's Reviews
12-03-2007, 06:54 PM
Pros: Keeps lights off when doors dismounted
Cons: too short, passenger side mounting
Recommended? Yes
Comments: I received this as a gift. It is a great idea for those jeepers who go without doors. I installed the product and realized the manufacture intended for the switch to be near the passenger door. I didn't like that so I went to the hardware store and bought connectors to extend the switch to the drivers side. If you have a basic knowledge of electrical wiring you can build this unit for a few dollars. If not, then I would definately recommend this product for a future mod.
ThreadForumRepliesLast Post
JTSpotlight Rechargeable LED Light Misc 2 12-28-2009 01:29 PM
Quadratec Factory Console Cup Holder Misc 3 12-02-2009 10:42 PM
Quadratec Neoprene Covered Grab Handles Misc 12 09-23-2009 09:36 PM
Daystar Lower switch panel Misc 3 08-23-2009 07:16 PM
Glock Forum
