Comments: This provides a nice solution that utilizes otherwise wasted space. The only problem is that it sticks out a little too far which can cause you to turn off the far left switch when you shift back into 2wd, or possibly turn off the right most switches when shifting with a manual. This is probably more of a function of the switches that they use. There is almost no room behind the panel itself, so they have to push things out. (The price listed includes the switches.)
Comments: Ordered through Quadratec. Using the switches for the windshield lights presently. Will be adding a rear fog light from KC and additional HELLA fog lamps on the front. Both additions will run through the switches
Comments: I like this panel, well made, and the rockers are the nicest around.
BUT Don't get this if you have a manual trans JK. When you switch gears, the rubber on the manual flips the 2nd, 3rd, and 4th switches.
Comments: Getting the product ready for use was easy (cutting out switch holes) but when trying to install it into the dash the clips did not want to secure the panel to the dash. Had to self-modify in order to get it to stay, a bit agitating but it still looks great and functions appropriately.
Comments: This panel holds up to four switches but I would recommend only using a maximum of three in the rightmost slots. The left slot is right in front of the 4WD shift and subject to accidental activation.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
