Notices
ZJ Seats to TJ Swap Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Seats Next Product
ZJ Seats to TJ Swap
Rating: None
Product Information
MSRP: $100.00
Average Price: $104.17
Manufacturer: Jeep OEM
Recommended?
Yes: 5 / No: 1
Company Website: http://www.car-part.com
One of the more popular seat swaps for the Jeep TJ is from it's own brethren. The ZJ to TJ seat swap is very easy to do and is a great low cost upgrade.
The installation is easy as pie. You use the TJ seat risers, sliders, and brackets. They bolt right on to the ZJ seats once you take the ZJ brackets off.
All in all this is a great mod. One of my favorites. You can also find theses seats with power, leather, and sometimes heated. You would have to do your own wiring.
None
pineapple124
pineapple124's Reviews
05-12-2016, 06:25 PM
Price: $100.00
Pros: Comfy, easy
Cons: Pretty sure I'm sitting closer
Recommended? Yes
Comments: Used 2002 grand cherokee seats, bolted to 2003 tj bases. To put in my 2005 LJ
The early bases have the seat belt connector built in, later bases do not.
Also easier to remove earlier seats from bases than the later.
bluejunior
bluejunior's Reviews
06-22-2015, 02:59 PM
Price: $175.00
Pros: Black leather, 70/30 split fold rear, fronts are more comfortable and have adjustable lumbar support.
Cons: Less rear leg room, more complicated to fold down rear,
Recommended? No
Comments: Okay...There wasn't an option but I actually put ZJ seats in a TJ front and rear.
Wouldn't do it again, I'd just have an upholstery shop rewrap my stock XJ stuff in leather and maybe replace/upgrade the cushions. Going from manual to power is just flat-out inconvenient, everything takes longer and the car has to be on. the fronts are a little more comfortable, and are more tall-guy friendly because they sit slightly farther back than the XJ.
If I did it again I MIGHT do the ZJ fronts and have the rear XJ bench recovered to match. Very much a personal taste sort of thing though.
blubberthechunk
blubberthechunk's Reviews
09-22-2014, 05:58 PM
Price: $100.00
Pros: Electric tilt, slide, lean and lumbar Comfortable leather
Cons: Leather shrinks when wet Not appropriate size
Recommended? Yes
Comments: This is a Jeep Cherokee Laredo electric leather seat swap.
Please read my write up of this swap for details.
cpleasant
cpleasant's Reviews
06-01-2010, 08:08 PM
Price: $50.00
Pros: Heated power leather seats that match factory colors
Cons: to keep power slide and tilt function modifications needed. To keep only heat and power recline upper seat bolts directly to the stock riser. Doesn't seem auite as comfortable as stock.
Recommended? Yes
Comments: Good replacement for worn seats if they can be found for a good price. I got mine for $50 each from a pick and pull lot.
cpleasant
cpleasant's Reviews
06-01-2010, 08:05 PM
Price: $100.00
Pros: Power leather seats that match factory color. Heat is usable as well with a little wiring work.
Cons: Doesn't seem as comfortable as stock seats. Modification needed to keep power slide and tilt functions.
Recommended? Yes
Comments: Good replacement for worn seats if you can get them cheap.
theducksguts
theducksguts's Reviews
04-13-2010, 03:28 PM
Price: $100.00
Pros: Bolt in swap, low cost, adjustable headrests
Cons: seat back on passenger side does not lean forward for easier backseat access.
Recommended? Yes
Comments: By far the best mod I have done. The most bang for the buck for sure. I was able to get a set of perfect seats out of a CFC ZJ (98). I love them, they ride so nice.
Such an easy project and a great upgrade. Highly recommended.
ThreadForumRepliesLast Post
Smitty Bilt XRC Seats Seats 10 07-25-2014 11:52 AM
Aftermarket Heated Seats Seats 10 06-18-2012 08:33 PM
Hezco Suspention seats Seats 1 08-10-2008 02:44 PM
