Go Back JeepForum.com > Reviews > Interior > Seats > Corbeau Baja SS
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Corbeau Baja SS Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Seats Next Product
Corbeau Baja SS
Rating:
Product Information
MSRP: $1,000.00
Average Price: $303.82
Manufacturer: Corbeau
Recommended?
Yes: 11 / No: 1
The Baja SS suspension seat provides drivers with the ultimate in comfort and support. The revolutionary "suspension" design helps make the Baja SS the perfect off-road seat by absorbing heavy bumps and turns. Standard features include: powder coated steel frame, reinforced nylon inner liner laced with military grade suspension cords, integrated full body support and 5-point harness capability. The Baja SS will fit up to a 36-38" waist.
Michaelgoesrawr
Michaelgoesrawr's Reviews
04-15-2011, 02:08 AM
Price: $179.99
Pros: Comfortable.
Cons: Wider so hard to find a center console
Recommended? Yes
Comments: I knew I wanted off road style seats but I didn't want to for out the money so the Corbeau Baja SS seats it was. They are extremely comfortable and a great value for the money.
Michaelgoesrawr
04-15-2011, 02:05 AM
Price: $179.99
Pros: Very comfortable. Much better ride
Cons: Adapter brackets make the seat sit much higher. They are wider so center consoles are hard to fit
Recommended? Yes
Comments: I knew I wanted an off road style seat but I didn't want to fork out the major cash. I was on JC Whitney and I was put off by their off brands so Corbeau was the choice for me. They are a suspension seat with slots for harnesses. They lean back father and the back is about two inches lower then stock YJ seats. I needed to fab a different type of bracket and attach it my flip forward brackets in order for it to suite my needs better. Over all, it's a great value for the price.
LostJeep
LostJeep's Reviews
01-14-2011, 03:28 PM
Price: $350.00
Pros: Back support and comfort
Cons: Getting in and out of them
Recommended? Yes
Comments: They are very comfortable and sportie just make sure you buy proper brackets for mounting and they go in easily but there not great for getting in and out of every day.
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Reviews
04-18-2010, 01:39 AM
Price: $1.00
Pros: comfy
Cons: too comfy, I fall asleep in them
Recommended? Yes
Comments: Got a great deal on them and they are AMAZINGLY COMFORTABLE!
patcj7
patcj7's Reviews
01-15-2009, 10:48 AM
Corbeau Baja SS
Price: $1,000.00
Recommended? Yes
Comments: Nice seat, very confortable.... The only thing, you need to buy an adaptor to install them on the corbeau seat brackets.. But, the bracket are heavy and bolt on.
ace2001
ace2001's Reviews
12-26-2008, 05:03 PM
Corbeau Baja SS
Pros: great support, comfortable, price and easy to install
Cons: stock seat belt positioning and hardware
Recommended? Yes
Comments: I purchased a set of tan Baja SS's last year and the install was really easy. They sent me the parts but no hardware. The seats are wide and very comfortable but the seats get pressed against the roll cage and center console. If you have no center console then you will have no problems. If you use stock seat belts with it, it is also a little awkward using them but that is only if you have the center console. All in all the seats are great and I would recommend them.
64Jeeper
64Jeeper's Reviews
11-07-2008, 05:57 AM
Corbeau Baja SS
Price: $150.00
Recommended? Yes
Comments: The seats I have are actually made by Matrix, but look similar to the Corbeau LG1's which are not listed. They also came from a private sale, and came with 4 point harnesses.
zachary1991
zachary1991's Reviews
07-02-2008, 02:14 PM
Corbeau Baja SS
Price: $250.00
Recommended? Yes
Comments: good seats a little stiff when you first get them but there good after there broken in.
79BlackPearl
79BlackPearl's Reviews
06-08-2008, 12:09 AM
Corbeau Baja SS
Price: $210.00
Recommended? Yes
Comments: Actually installed the Corbeau Moab seats and they are great. They are little higher than the OEM low backs, so be carefull if you have thick thighs.
Twitchy
Twitchy's Reviews
05-06-2008, 11:10 PM
Corbeau Baja SS
Price: $500.00
Recommended? Yes
Comments: great seat and quite an impressive support system and it is as good as can be
Fred007
Fred007's Reviews
04-04-2008, 10:14 PM
Corbeau Baja SS
Price: $520.00
Recommended? Yes
Comments: So far, so good. I actually have the Moab Neoprene seats and like the way they fit so far. Had to redo the driver side riser as they were too high and too far forward.
ThreadForumRepliesLast Post
Corbeau Baja RS Seats 5 01-24-2011 02:17 PM
Corbeau Baja Ultra Seats 1 12-01-2009 08:16 PM
Corbeau A4 Seats 3 09-24-2009 03:57 PM
Corbeau Baja Bench Seats 0 11-20-2008 05:55 PM
Corbeau Baja Low Back Seats 0 11-20-2008 05:50 PM
Glock Forum
