Go Back JeepForum.com > Reviews > Suspension > Steering Stabilizers > Rough Country Steering Stabilizer
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Rough Country Steering Stabilizer Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $50.00
Average Price: $39.00
Manufacturer: Rough Country
Recommended?
Yes: 26 / No: 1
Extra-heavy-duty Stock Stabilizer Replacement
Page 1 of 2 1 2 > Last »
thegladiator
thegladiator's Reviews
09-26-2011, 10:06 AM
Price: $49.00
Pros: heavier duty
Cons: none yet
Recommended? Yes
Comments: Been Deployed hope to drive it soon.
oitprichard
oitprichard's Reviews
04-30-2011, 12:29 PM
Price: $50.00
Pros: Does it's job. Easy install
Cons: none
Recommended? Yes
Comments: This product does a great job of keeping my Jeep stable at any speed. I got the 2.2 version so it'd match my shocks. The cheaper white version probably would be just as good, but I'm kind of anal about my Jeep's appearances. Anyway, the install was super easy: probably took 30 minutes or less. I'd recommend using a pitman arm puller to remove the stock SS; made it that much easier.
Wrangler_X
Wrangler_X's Reviews
04-02-2011, 10:29 AM
Price: $60.00
Pros: works great took all the play out of my strearing a must if u run bi tires
Cons: none
Recommended? Yes
Comments: best on the market i think and u cant beat there customer service, a very good buy
Msprain10
Msprain10's Reviews
03-21-2011, 03:43 PM
Price: $50.00
Pros: solid beefy steel
Cons: hard to install lol
Recommended? Yes
Comments: A definite upgrade to stock.
btait1
btait1's Reviews
08-12-2010, 07:05 PM
Price: $40.00
Pros: low price comes with all the mounting hardware and awesome instructions.
Cons: did not come with a shock boot to protect it from the environment.
Recommended? Yes
Comments: Quick and easy to replace.
does its job.
sanchagrins
sanchagrins's Reviews
06-01-2010, 11:05 AM
Price: $50.00
Pros: Inexpensive, and easy installation
Cons: None
Recommended? Yes
Comments: An easy mod, at a great price. I installed the 2.2 performance steering stabilizer over a year ago, and so far have had no problems with it. No leaks, or any issue to date.
PolarBear83
PolarBear83's Reviews
05-24-2010, 01:59 PM
Price: $35.00
Pros: Price, Ease of installation
Cons: None at this time
Recommended? Yes
Comments: Call Jeff
slpv09
slpv09's Reviews
05-11-2010, 09:13 PM
Price: $50.00
Pros: cheap
Cons: rought countruy
Recommended? No
Comments: the bolt that goes in the drag link gets stuck if you wanna swap drag links
jeeprenegadeaz
jeeprenegadeaz's Reviews
05-02-2010, 03:03 PM
Price: $25.00
Pros: allows better handaling
Cons: none yet
Recommended? Yes
Comments: a must if u put on larger tires and lift
Toaste
Toaste's Reviews
03-13-2010, 10:22 AM
Price: $90.00
Pros: Needed it
Cons: None
Recommended? Yes
Comments: A must with the rc kits
tacweapon
tacweapon's Reviews
11-04-2009, 02:21 AM
Price: $30.00
Pros: Upgrade over stock
Cons: none so far
Recommended? Yes
Comments: I did not need a new steering stabilizer before I did the lift but I did this anyway and I can not tell a difference in the steering after the lift then before the lift.
mxboarder17
mxboarder17's Reviews
09-21-2009, 10:03 PM
Price: $27.00
Pros: Easy to Install
Cons: RC does not make a 2.2 for XJ
Recommended? Yes
Comments: Works a lot better than my stock stabilizer. I felt a little difference when I installed and how it made my steering a little tighter. I am happy with Rough Country and all of their products!
ROADDOG516
ROADDOG516's Reviews
09-10-2009, 05:13 PM
Price: $25.00
Pros: Easy install, heavy duty
Cons: none so far
Recommended? Yes
Comments: Much better than stock, and has a heavy duty feel to it, steering is smooth and would definitely recommend when doing lift kit.
DPaul
DPaul's Reviews
06-02-2009, 04:43 PM
Price: $25.00
Pros: Better Articulation and Control
Cons: The lock washer bent out of shape
Recommended? Yes
Comments: For the money this is an excellent modification for those running larger tires. The directions didn't indicate how much torque to apply and I ended pushing the lock washer out. Easily fixed and the stabilizer has worked perfectly since. The best value to cost ratio out there.
rob1208lv
rob1208lv's Reviews
04-07-2009, 06:28 PM
Price: $25.95
Recommended? Yes
Comments: works good
Rough country has top notch customer service will buy from them again
ElGuapoBond
ElGuapoBond's Reviews
04-06-2009, 11:52 PM
Price: $30.00
Recommended? Yes
Comments: I installed the 2.2 stabiliser when I did the lift kit. Make sure you have a pitman arm puller when tackiling the factory stabiliser as it makes things easier along with a few days of soaking the old one with PB Blaster. The hard hits I have taken on the trail have been smoothed out a bit with the new stabiliser, well worth the price.
vilseck21
vilseck21's Reviews
03-15-2009, 04:05 PM
Price: $50.00
Recommended? Yes
Comments: 2.2, looks good and works............................................. ............................
brand0nlp
brand0nlp's Reviews
03-05-2009, 09:17 PM
Price: $30.00
Recommended? Yes
Comments: well all i can really say is it makes the handling much better than the stock steering stabilizer the ride quality is great
Ged4th
Ged4th's Reviews
02-22-2009, 02:28 PM
Price: $50.00
Recommended? Yes
Comments: Does the job ok but I am going to upgrade again to a dual stabilizer setup to help keep the 35's under control.
mouse
Weekend Wheeler
mouse's Reviews
02-19-2009, 05:36 PM
Recommended? Yes
Comments: Nice stab for the price. very easy to install....................................
ThreadForumRepliesLast Post
Rough Country 4" Rough Country Suspension Lift Complete Lift Kits 46 12-22-2011 04:52 PM
Rough Country Rough Country 2.2 Shocks Shocks 15 08-14-2011 12:09 AM
Rough Country - Rough Country 4" Long Arm Kit Complete Lift Kits 2 11-19-2010 12:47 AM
Rough Country Dual Steering Stabilizer 2.2 Steering Stabilizers 6 01-21-2010 07:48 PM
Rough Country - Rough Country 6" Long Arm Kit Complete Lift Kits 0 11-01-2009 12:16 PM
Glock Forum
