Notices
Rancho rs 5000 Steering Stabilizer Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $134.98
Manufacturer: Rancho
Recommended?
Yes: 67 / No: 2
Rancho RS5000 steering stabilizers reduce steering shimmy, improve tire control, and give you more control over your vehicle if a tire should blow out. The single stabilizers protect front-end suspensions, and are used with tires up to 35 in. tall. Dual stabilizers are for off-roaders with tires 35 in. and taller.
Increase vehicle control under all driving conditions by reducing steering shimmy and driver fatigue
Improve tire wear and provide better control in blowout conditions
Single stabilizers help protect front-end suspension components, and are designed for use with tires up to 35" tall
Applications include 4WD, 2WD, trucks, sport utility vehicles, vans, motorhomes, and semi trucks/tractors (class 7 and 8)
Dual setups are designed for the aggressive off-roader with large oversized tires
Commonly known as "The 5th Shock", a Rancho steering stabilizer is a must for vehicles with oversized tires. Featuring RS5000 construction and available in single or dual configurations, Rancho steering stabilizers improve driver control, and minimize uncomfortable road input.
Rancho Steering stabilizer are shock absorbers which are specially engineered to operate horizontal. Acting as a horizontal shock absorber, steering stabilizers reduce vibrations that travel thought the steering system to the driver. The result can be increased control, improved safety and reduced driver fatigue. Simply put, steering stabilizers are installed between the main movable component of the vehicle steering system and its frame.
None
Page 4 of 4 1 2 3 4
rljsrubicon
rljsrubicon's Reviews
06-19-2007, 10:44 AM
Price: $54.00
Pros: Price and Performance
Recommended? Yes
Comments: I like the unit. It's much better than stock and the price is not bad either. I've used them for years, so they're a known product for me. Ron
DeconsTructionJ
DeconsTructionJ's Reviews
03-18-2007, 11:53 PM
Pros: seems to be doing its job
Cons: rust
Recommended? Yes
Comments: I have the superlift version of this steering stabilizer, When I installed it I noticed my steering became slightly stiffer than before the install. besides that there has not been a whole lot of difference so it is my opinion that it is working correctly.
The only issue I have had so far is that the paint on the body is cheap and it has started to rust at less than a year old.
h2oskikrazy
h2oskikrazy's Reviews
02-01-2007, 12:38 PM
Price: $44.00
Pros: Noticeable Improvement over OEM
Cons: Instruction Details could be improved
Recommended? Yes
Comments: Installed on a 98 TJ with 53k miles. The factory unit must have been nearly wore out because I noticed a significant improvement in steering feel and steering control. The improvement exceeded expectations.
Installation of the new unit was simple. Removal of the factory unit was not. I had to purchase a pitmam arm puller at a cost of $14 to remove the factory unit. This was not mentioned in the installation instructions.
ASUsax
ASUsax's Reviews
01-03-2007, 02:07 PM
Recommended? Yes
Comments: Really tightened up my steering, which had been getting looser. At 5 years and 66k, it's likely that the stocker was pretty much gone.
PudrowDSM
PudrowDSM's Reviews
10-04-2006, 10:31 PM
Price: $45.00
Pros: Simple to install, all needed hardware included
Recommended? Yes
Comments: Excellent product. My OEM unit was going out and started to get death wobble a little bit... also having 35's didn't help either. The install was straight forward and took no more than 30 minutes. The steering smoothness was night and day difference from the OEM unit.
Travis
gpJeep
gpJeep's Reviews
10-02-2006, 01:33 PM
Price: $70.00
Pros: works great nice and smooth
Cons: non so far
Recommended? Yes
Comments: Replaced the oem one about 3 weeks ago and so far the new unit works just great.
There does not seem much of a diffrence from the oem unit, I have standard tires.
Steering though, is more smoother over the rougher roads I go .
So far its a good thing with no problems .
ajmorell
ajmorell's Reviews
09-13-2006, 06:31 PM
Price: $34.00
Recommended? Yes
Comments: I had a gift cert. to Summit racing, so I bought this to replace my OE steering stabilizer. There was really no noticeable difference but I have had no problems whatsoever.
EvilSpock
EvilSpock's Reviews
09-06-2006, 02:01 AM
Recommended? Yes
Comments: No Problems
Page 4 of 4 1 2 3 4
ThreadForumRepliesLast Post
Rough Country Steering Stabilizer Steering Stabilizers 40 05-29-2016 03:49 PM
Old Man Emu Steering Stabilizer Steering Stabilizers 85 07-14-2015 11:49 PM
ProComp ES2000 Steering Stabilizer Steering Stabilizers 23 10-17-2012 07:43 PM
Rubicon Express Steering Stabilizer Steering Stabilizers 9 07-01-2012 10:31 PM
KYB - Kyb Steering Stabilizer Steering Stabilizers 2 07-28-2010 01:57 PM
