Notices
Rancho rs 5000 Steering Stabilizer Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $100.00
Average Price: $134.98
Manufacturer: Rancho
Recommended?
Yes: 67 / No: 2
Rancho RS5000 steering stabilizers reduce steering shimmy, improve tire control, and give you more control over your vehicle if a tire should blow out. The single stabilizers protect front-end suspensions, and are used with tires up to 35 in. tall. Dual stabilizers are for off-roaders with tires 35 in. and taller.
Increase vehicle control under all driving conditions by reducing steering shimmy and driver fatigue
Improve tire wear and provide better control in blowout conditions
Single stabilizers help protect front-end suspension components, and are designed for use with tires up to 35" tall
Applications include 4WD, 2WD, trucks, sport utility vehicles, vans, motorhomes, and semi trucks/tractors (class 7 and 8)
Dual setups are designed for the aggressive off-roader with large oversized tires
Commonly known as "The 5th Shock", a Rancho steering stabilizer is a must for vehicles with oversized tires. Featuring RS5000 construction and available in single or dual configurations, Rancho steering stabilizers improve driver control, and minimize uncomfortable road input.
Rancho Steering stabilizer are shock absorbers which are specially engineered to operate horizontal. Acting as a horizontal shock absorber, steering stabilizers reduce vibrations that travel thought the steering system to the driver. The result can be increased control, improved safety and reduced driver fatigue. Simply put, steering stabilizers are installed between the main movable component of the vehicle steering system and its frame.
None
Page 3 of 4 1 2 3 4 > Last
ScottHarr_TJ
ScottHarr_TJ's Reviews
11-22-2008, 04:12 PM
Price: $40.00
Recommended? Yes
Comments: looks real nice, but is also a way smoother ride than the old stock one. installing it was fun.
YJ_Auzzy
YJ_Auzzy's Reviews
09-26-2008, 09:18 AM
Price: $35.00
Recommended? Yes
Comments: still bumpy as heck lol does help on town roads and highways to moab. should have done double
Davetha
Davetha's Reviews
07-06-2008, 09:04 PM
Price: $48.99
Pros: Low cost, Better steering stability
Cons: No instructions
Recommended? Yes
Comments: I just finished installing the RS5000 about an hour ago. The first thing I noticed is it tightened my steering a little bit. I also noticed that when I had my wheels turned all the way and accelerated slowly, the wheels went back a bit slower.
I took my Jeep for a ride on the highway which needs an alignment, but even needing an alignment, it kept the wheels on track where I wanted them to go.
Taking off the old OEM Stabilizer was the hardest part, the left bolt and screw was on there pretty well, I ended up using 2 ratchets, one propped up on my spring, the other I turned myself.
After the OEM Stabilizer was out, it took me a minute to figure out how to install it, from ther it just fit right in no problems at all. I did need to purchase a new bolt and nut for the left side since they don't provide you with a new one.
CO98TJ
CO98TJ's Reviews
07-03-2008, 11:35 AM
Price: $50.00
Recommended? Yes
Comments: Goes great with the shocks and really makes a difference even in everyday driving so I am really happy with it!
xfanatic15
xfanatic15's Reviews
05-13-2008, 04:23 PM
Price: $55.00
Recommended? Yes
Comments: Before i had my stock stabilizer/damper and i had to deal with the death wobble, after i replaced with rancho part it full removed it and i now have very little to no shake in my wheel even with the biggest bumps
Ruffnek
Ruffnek's Reviews
05-08-2008, 04:07 PM
Price: $40.00
Recommended? Yes
Comments: It's a steering stabilizer, it works way better than the leaky stock one it replaced.
table
table's Reviews
04-28-2008, 07:30 PM
Price: $60.00
Recommended? Yes
Comments: Pretty much any aftermarket SS is worthwhile, even for a DD. Highly recommended over the pencil-thin stock SS
Calijeeper
Calijeeper's Reviews
04-25-2008, 10:48 PM
Recommended? Yes
Comments: like it. handling improved alot.
WillyB
110K miles and counting!
WillyB's Reviews
04-18-2008, 05:45 PM
Recommended? Yes
Comments: Freebie!
tractionhunter
tractionhunter's Reviews
04-15-2008, 10:11 PM
Price: $1.00
Recommended? Yes
Comments: 1
FunkyCold
FunkyCold's Reviews
04-03-2008, 03:48 AM
Price: $50.00
Recommended? Yes
Comments: does the job
SillyPutty
SillyPutty's Reviews
03-27-2008, 05:23 PM
Price: $1.00
Recommended? Yes
Comments: it stabilized my steering.
94YJEEPER
94YJEEPER's Reviews
03-26-2008, 08:59 PM
Price: $100.00
Recommended? Yes
Comments: Better ride? Yes
GibsJeep
GibsJeep's Reviews
03-16-2008, 03:49 AM
Price: $1.00
Recommended? Yes
Comments: Long lasting steering stabilizer
04WJLtd.
04WJLtd.'s Reviews
03-09-2008, 03:56 PM
Price: $40.00
Recommended? Yes
Comments: excellent
h2oskikrazy
h2oskikrazy's Reviews
01-15-2008, 05:41 PM
Price: $44.00
Pros: Performs better than stock
Cons: Pretty red/white finish starts to look rusty very quickly
Recommended? Yes
Comments: This is an update to a previous review. Although the stabilizer performs flawlessly, it is no longer pretty to look at after about 1 year of mostly
city driving.
TJ_Jackson
TJ_Jackson's Reviews
12-27-2007, 01:41 PM
Pros: Easy Install
Recommended? Yes
Comments: Installed very quickly, seemed to have tightened up the front end a bit. Good replacement over the stock one.
cherokee5up
cherokee5up's Reviews
12-11-2007, 10:15 AM
Pros: Works, fits
Recommended? Yes
Comments: Quick install, immediate improvements noted. Quality seems good.
RCJEEP2002
RCJEEP2002's Reviews
07-22-2007, 09:30 PM
Pros: Price
Cons: Paint
Recommended? Yes
Comments: Works great. No problems
Tims034x44Fun
Tims034x44Fun's Reviews
07-13-2007, 08:15 PM
Recommended? Yes
Comments: I purchased my first one after buying my jeep in 05 and getting the wobble on stock tires. I am jsut now replacing it since I don't know why else I'm getting wobble again, can't hurt right??
ThreadForumRepliesLast Post
Rough Country Steering Stabilizer Steering Stabilizers 40 05-29-2016 03:49 PM
Old Man Emu Steering Stabilizer Steering Stabilizers 85 07-14-2015 11:49 PM
ProComp ES2000 Steering Stabilizer Steering Stabilizers 23 10-17-2012 07:43 PM
Rubicon Express Steering Stabilizer Steering Stabilizers 9 07-01-2012 10:31 PM
KYB - Kyb Steering Stabilizer Steering Stabilizers 2 07-28-2010 01:57 PM
