Old Man Emu Steering Stabilizer Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $81.00
Average Price: $77.10
Manufacturer: Old Man Emu
Recommended?
Yes: 84 / No: 3
Designed to reduce the effect of wheel vibration and improve the feel, handling and control of the vehicle, OME’s steering stabilisers will also reduce the aggressive rotation of the steering wheel over rough roads without affecting steering wheel return.
Features:
* 9 Stage Coil Spring Valving – for optimum performance
* 15mm Piston Rod – stronger than the original
* Steel Stone Guard – protects the piston rod against stone damage
* 35mm Piston & Bore – increased oil volume
* Twin Tube Design – protects the internal components against stone damage
* Multi Lip Seal – prevents oil loss
* Original Mounts – for ease of installation original stabiliser mounts are used where appropriate
None
Page 3 of 5 1 2 3 4 5 > Last »
vonmuse
vonmuse's Reviews
03-15-2010, 08:50 PM
Price: $82.99
Pros: yellow
Cons: yellow
Recommended? Yes
Comments: easy to install 15 mns
palocop
palocop's Reviews
03-08-2010, 01:06 AM
Price: $75.00
Pros: Heavy Duty. Looks great. Easy install. Eliminated all my death wobble!!!! YEA!!!!
Cons: Expensive, had to switch bushings (very tight) for stock application. Not a big deal.
Recommended? Yes
Comments: My only regret was not doing it when I installed the initial lift. Ended up with an intermittent death wobble at about 45 mph after installing the 2.5" heavy duty OME lift. Worked great wheeling but the wife refused to drive it after the first time the wobble happend to her. Installed the steering stabilizer and it is now totally gone!!! So happy and it looks great matching my OME shocks and hardware.
trotsjeep
trotsjeep's Reviews
02-20-2010, 09:47 PM
Price: $73.00
Pros: OME what else should I say
Cons: AHHHHH I got nothing
Recommended? Yes
Comments: OME strikes again. When purchasing and driving my jeep "dispatch" home for the first time I'm not gonna lie to ya, I took my life in my hands everytime I drove any direction but strait however thanks to OME I can drive sideways and upside down if I really want to . . . well not upside down yet however that is coming soon!
WJ-matt
WJ-matt's Reviews
01-21-2010, 08:49 PM
Price: $180.00
Pros: durable, massive (compared to stock)
Cons: none
Recommended? Yes
Comments: i don't feel the bumps anymore in the steering wheel, and it turns a lot smoother. No more jerking of the wheel
youngwj
youngwj's Reviews
01-10-2010, 11:48 PM
Price: $90.00
Pros: Easy to install, tightened up steering, less wobble.
Cons: None really.
Recommended? Yes
Comments: Was shipped quick and very easy to install (30 mins or so). Was replaced for the new lift and the old SS was leaky and my steering felt loose. This definitely helped fix the problem. Overall a great product!
youngwj
youngwj's Reviews
01-10-2010, 11:46 PM
Price: $90.00
Pros: Stiffer steering, less wobble, easy to install.
Cons: None really.
Recommended? Yes
Comments: I replaced mine for the new lift I was getting and also the old was was leaky and my steering felt loose. Definitely tightened up my steering and made it more sensitive. Overall a great product.
02APEX
02APEX's Reviews
01-06-2010, 02:17 PM
Price: $50.00
Pros: easy install
Cons: bushing not nylon, and ...its yellow
Recommended? Yes
Comments: Does the trick except that in less than a year the bushing went out. Easy fix for steering shimmy.
MoCab
MoCab's Reviews
12-07-2009, 06:27 PM
Price: $67.00
Pros: matched the shocks and was at discount if I bought with rest of setup
Cons: none
Recommended? Yes
Comments: Hey it matches it it works!
DirtyRabbit
DirtyRabbit's Reviews
11-22-2009, 11:08 AM
Price: $1.00
Pros: Works as It supposed to.
Cons: None so far.
Recommended? Yes
Comments: This came with my Jeep. It's a really rugged steering stabilizer. I can beat the crap out of my Jeep on the trails, then hop on the highway and drive 65-70 MPh with no problems whatsoever.
bobthetj03
bobthetj03's Reviews
11-06-2009, 04:46 PM
Price: $75.00
Pros: cured bump steer
Cons: None
Recommended? Yes
Comments: Helped to cure my bump steer. Solid product. Installation easy.
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Reviews
09-04-2009, 09:40 AM
Price: $50.00
Pros: Works great!
Cons: None.
Recommended? Yes
Comments: Looks cool & stands out, but it functions great! Hardcore and can handle most bumpers you throw at it.
jimwww
jimwww's Reviews
05-25-2009, 01:08 AM
Price: $75.00
Pros: Smooth
Cons: None
Recommended? Yes
Comments: Made my steering smoother in my lifted YJ - 4.5 inch lift with 35's.
I would recommend it.. but I don't know if it is better than anything esle aftermarket - was better than stock.
Zakman
A locked & armored LJ
Zakman's Reviews
05-15-2009, 08:57 AM
Price: $75.00
Pros: Solid steering stabilzer. Twin tube for protection.
Cons: None so far.
Recommended? Yes
Comments: Great product from OME. No issues. Much better than stock.
TX02WJ
TX02WJ's Reviews
04-08-2009, 12:50 AM
Price: $70.00
Recommended? Yes
Comments: great stabilizer, seems to do a great job holding everything together and dampen the bump steer a great deal
TigerFanTJ
TigerFanTJ's Reviews
01-17-2009, 01:03 PM
Price: $75.00
Recommended? Yes
Comments:
XJ99RedNY
XJ99RedNY's Reviews
01-13-2009, 03:00 PM
Price: $100.00
Recommended? Yes
Comments: keeps the tires aiming strait and helps prevent loss of alignment. 7575757575757575757575
BlackBellamy
BlackBellamy's Reviews
09-30-2008, 10:58 AM
Price: $34.00
Recommended? Yes
Comments: Good price, good product, easy install. What else can I say about a ******* steering stabilizer to meet the required minimum review length?
Justin79
Justin79's Reviews
09-22-2008, 11:05 AM
Price: $40.00
Recommended? Yes
Comments: Quick, easy install to factory SS location. Stone guard is nice versus boot. Didn't notice much of a difference in steering though from stock stabilizer.
Guns
Guns's Reviews
09-17-2008, 01:58 PM
Price: $60.00
Recommended? Yes
Comments: Tough as nails! I ran this with my 35's and never felt any problems. I bent the snot out of my tie rod on a ledge, which banged up the stabilizer pretty bad. I replaced it with a cheaper one (big mistake). When I put on my 37's, I had to put it back on. After the nasty beating it took, it still works!!! I am going to replace it, but I am really impressed.
wjjeep4x4
wjjeep4x4's Reviews
09-10-2008, 12:55 PM
Price: $80.00
Recommended? Yes
Comments: Once again Old Man Emu provides a great product. Great heavy duty replacement or upgrade from the stock steering stabilizer.
ThreadForumRepliesLast Post
Rough Country Steering Stabilizer Steering Stabilizers 43 05-29-2016 02:49 PM
Monroe Steering Stabilizer SC2928 Steering Stabilizers 9 12-07-2015 12:14 AM
Rubicon Express Steering Stabilizer Steering Stabilizers 9 07-01-2012 09:31 PM
Teraflex 9550 steering stabilizer Steering Stabilizers 9 02-08-2012 05:31 PM
KYB - Kyb Steering Stabilizer Steering Stabilizers 2 07-28-2010 12:57 PM
