Notices
Old Man Emu Steering Stabilizer Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $81.00
Average Price: $77.10
Manufacturer: Old Man Emu
Recommended?
Yes: 84 / No: 3
Designed to reduce the effect of wheel vibration and improve the feel, handling and control of the vehicle, OME’s steering stabilisers will also reduce the aggressive rotation of the steering wheel over rough roads without affecting steering wheel return.
Features:
* 9 Stage Coil Spring Valving – for optimum performance
* 15mm Piston Rod – stronger than the original
* Steel Stone Guard – protects the piston rod against stone damage
* 35mm Piston & Bore – increased oil volume
* Twin Tube Design – protects the internal components against stone damage
* Multi Lip Seal – prevents oil loss
* Original Mounts – for ease of installation original stabiliser mounts are used where appropriate
None
Page 2 of 5 1 2 3 4 5 > Last »
claytonandson
claytonandson's Reviews
01-20-2011, 11:07 PM
Price: $60.00
Pros: looks better quality than stocker.
Cons: little pricy.liked the OME shocks so went w/ SSt.
Recommended? Yes
Comments: liked the yellow match to my tj. didnt really notice anything different than stock.when it comes down to it, if evrything is in check you could run w/o a stabilizer. think it more in the mind with the result claims, but i bought one...
bidd1
bidd1's Reviews
01-03-2011, 12:30 AM
Price: $70.00
Pros: Easy install
Cons: None
Recommended? Yes
Comments: Installed over 2 years ago, no problems.
USMCTJ
USMCTJ's Reviews
11-19-2010, 03:29 PM
Price: $79.00
Pros: Rock guard for stabilizer, no jerking steering wheel
Cons: na
Recommended? Yes
Comments: Great product, much beefier then stock
Zeusismyonlygod
Zeusismyonlygod's Reviews
11-03-2010, 08:13 PM
Price: $82.00
Pros: Great product
Cons: No complains
Recommended? Yes
corvettekid82
corvettekid82's Reviews
10-16-2010, 11:05 AM
Price: $60.00
Pros: Heavy duty, works great
Cons: Bright yellow color. Love it or leave it.
Recommended? Yes
Comments: Ended up spray painting it a different color to match my rig
Weelz
Weelz's Reviews
10-11-2010, 02:20 AM
Price: $70.00
Pros: --Simple install. --It works.
Cons: Slight more expensive than somer others.
Recommended? Yes
Comments: Hey, it works, it's easy to install and it's not too expensive. It's all good.
VegasMatt
VegasMatt's Reviews
10-03-2010, 12:28 PM
Price: $80.00
Pros: Much smoother steering, steering wheel doesn't jump all over the place.
Cons: removing the OEM one
Recommended? Yes
Comments: I bought this to replace my stock SS, which was shot. Removing the stock one is a PITA; use a pitman arm puller and a 1/2" drive with a long handle. I shore the heads off of two 3/8" ratchets. Also you gotta kind of ram the axle-end of this thing into place. But the ride improvement is definately worth it.
Barbarian
Barbarian's Reviews
09-19-2010, 01:06 PM
Price: $80.00
Pros: Not extremely expensive like the double ones. or the huge name ones. instantly I can safely drive 80 mph no death wobble. not shake at all. and handles alot better.
Cons: Didnt get it sooner.
Recommended? Yes
Comments: Best cheap purchase for a Daily Driver Jeep. my jeep didnt shake much before hand but when i got up to top speeds it was a little unstable. now im not worried at all. Handles alot better and no wobble at all going 80+. and i still have 8 year old stock (bad) shocks as of now. Great Product!! I bought just because my jeep was yellow. i bought there shocks also just because on the ride inprovment for this. the Old man knows his jeeps ;-)
04_Sahara_Man
04_Sahara_Man's Reviews
08-12-2010, 01:30 PM
Price: $84.00
Pros: Beefy, easy to install, no more wobble! You pay for what you get and you get the best!
Cons: Removing OEM one, PITA
Recommended? Yes
Comments: After talking to a guy at my local 4wd shop, I purchased it due to me having DW above 50mph, had already gotten a JKS track bar and still had it. Installed this and boom! had it up to 65 smooth as silk! Oh yea and it looks awesome too!
malfungton
malfungton's Reviews
07-13-2010, 09:56 PM
Price: $70.00
Pros: MUCH better feel than the stock stabilizer...
Cons: huge
Recommended? Yes
Comments: there is a huge difference between the stock stabilizer and Old Man Emu... really cuts down on road vibration in the steering... also got rid of a small wobble i had after installing a budget lift...
krahnilogikal
krahnilogikal's Reviews
07-12-2010, 10:17 AM
Price: $70.00
Pros: Heavy duty, easy installation, great performance.
Cons: A bit pricey for some but very worth it in my book.
Recommended? Yes
Comments: Great product from a great company. Install was simple with supplied hardware and was a direct OEM fit for my TJ. Looks to be easily converted for non-stock steering with some additional hardware. Stone guard could cause some slight interference with some drag links depending on set up. Power coating is pretty tough and hasn't chipped even after driving down gravel roads at speed. OME just makes a great product.
krahnilogikal
07-12-2010, 09:58 AM
Price: $70.00
Pros: Heavy duty, easy installation, all new mounting hardware, direct OEM fit or adapt to non-stock steering with additional hardware
Cons: A bit pricey but quality is worth it in my book
Recommended? Yes
Comments: Great product so far. Easy installation. Hardest part was removing the OEM unit. Easily adapts to non-stock steering with additional hardware though it was not included. The stone guard is a bit large and could get in the way depending on the angle of your draglink. Softens the highway jitters that a lot of TJs get. Poweder coating is pretty tough and hasn't chipped even after charging down gravel roads at speed. What else can I say, OME offers top-notch products. Period.
Chris_XJ
Chris_XJ's Reviews
06-24-2010, 04:29 AM
Price: $1.00
Pros: 0
Cons: 0
Recommended? Yes
Comments: Came with the Jeep when I bought it and seems to work good.
Nicho
Nicho's Reviews
06-11-2010, 10:19 PM
Price: $80.00
Pros: Wow- big difference over stock SS.
Cons: none although the upper shell is right against the tie rod.
Recommended? Yes
Comments: Wow- big difference over stock SS.
06unl
06unl's Reviews
06-02-2010, 07:22 AM
Price: $73.00
Pros: worked good
Cons: bushing didn't last
Recommended? No
Comments: Emailed ARBUSA 5/31 got a reply 6/1 whole new replacement being sent. Can't beat that
06unl
06unl's Reviews
05-31-2010, 11:16 AM
Price: $73.00
Pros: worked good
Cons: 1 year and 12,000 miles later the bushing on the end that connects to the tie rod is gone.
Recommended? No
Comments: Seeing how the warranty works between Quadratec, who I purchased it from, and ARBUSA
Fox01V
Fox01V's Reviews
05-19-2010, 12:50 PM
Price: $55.00
Pros:
Cons:
Recommended? Yes
Comments: I had a worn out SS before I put this in so not to sure what it was like new, but went with it when I put my other OME shocks in.
akordboy
akordboy's Reviews
05-07-2010, 11:43 AM
Price: $70.00
Pros:
Cons:
Recommended? Yes
Comments:
critterjeep
critterjeep's Reviews
03-25-2010, 09:24 PM
Price: $74.00
Pros: nice look, thick and solid, includes most hardware replacement parts.
Cons: doesn't include all new hardware so you have to reuse some of it.
Recommended? Yes
Comments: the stabilizer looks great, and i can tell some difference on bumpy roads. it's not like night and day, but it's a bit better than the stock shock. you have to re-use one bolt and nut, and the rest of the hardware is provided. installation was super easy. removing the stocker was the hard part.
Sterner09
Sterner09's Reviews
03-19-2010, 02:12 PM
Price: $85.00
Pros: Works alot better then my rc stablizer
Cons: none.
Recommended? Yes
Comments: expensive but well worth it!
ThreadForumRepliesLast Post
Rough Country Steering Stabilizer Steering Stabilizers 40 05-29-2016 02:49 PM
Rubicon Express Steering Stabilizer Steering Stabilizers 9 07-01-2012 09:31 PM
Teraflex 9550 steering stabilizer Steering Stabilizers 9 02-08-2012 05:31 PM
Monroe Steering Stabilizer SC2928 Steering Stabilizers 7 01-07-2011 06:00 PM
KYB - Kyb Steering Stabilizer Steering Stabilizers 2 07-28-2010 12:57 PM
