Go Back JeepForum.com > Reviews > Suspension > Steering Stabilizers > NAPA North American parts association Stablizer Bar REAR WJ # NCP2651602
NAPA North American parts association Stablizer Bar REAR WJ # NCP2651602 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $38.00
Average Price: $29.00
Manufacturer: NAPA North American parts association
Recommended?
Yes: 1 / No: 1
Stabilizer bars are part of a car's suspension system. They are sometimes also called anti-sway bars or anti-roll bars. Their purpose in life is to try to keep the car's body from "rolling" in a sharp turn.
Think about what happens to a car in a sharp turn. If you are inside the car, you know that your body gets pulled toward the outside of the turn. The same thing is happening to all the parts of the car. So the part of the car on the outside of the turn gets pushed down toward the road and the part of the car on the inside of the turn rises up. In other words, the body of the car "rolls" 10 or 20 or 30 degrees toward the outside of the turn. If you take a turn fast enough, the tires on the inside of the turn actually rise off the road and the car flips over.
Roll is bad. It tends to put more weight on the outside tires and less weigh on the inside tires, reducing traction. It also messes up steering. What you would like is for the body of the car to remain flat through a turn so that the weight stays distributed evenly on all four tires.
Stab links are the end parts of the sway bar that transfer the force of the turn onto the body, from the pushed down side to the rising side equalizing the force and stabilizing the car.
No Bushingsin your stab links equals badder handling new links are about about $40.00 each. they need to be upsized for truck lifts and suspension mods.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NCP&PartNumber= 2651602&Description=Sway+Bar+Repair+Kit+-+Rear+Suspension
Andrew47
Andrew47's Reviews
01-07-2009, 01:17 PM
Price: $20.00
Recommended? No
Comments: i wouldnt recomend this steering stabilizer it worked good for a month or so but now 5 or 6 months later its pretty much been useless. dont go cheap get a good one!
gpJeep
gpJeep's Reviews
08-04-2007, 07:27 PM
Price: $38.00
Pros: Does its job
Cons: getting the energy to replace em.
Recommended? Yes
Comments: Ibought a pair of these when I got the addco rear sway bar. Put these units in and they work so well you can forget they are there.
if they work for another 10 years I'll have my moneys worth.
Thre only hard part was getting a new braket from jeep about 2 weeks because the upper mount screw sheared off inside the upper mount bracket .
This was due to poor install practice (crosstreading ) in the factory
They do their job ..
Glock Forum
