Monroe Steering Stabilizer SC2928 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $30.00
Average Price: $38.00
Manufacturer: Monroe
Recommended?
Yes: 9 / No: 0
The Monro-Magnum steering stabilizer stops vibration before it gets to the driver. It is ideally suited for trucks, vans, and 4-wheel drive vehicles.
Monro-Magnum steering stabilizers increase control under all driving conditions by reducing steering shimmy and driver fatigue. Additionally, they can reduce tire wear and protect front-end components from premature wear.
Part Number: SC2928
(This product is the same as NAPA Item#: NS SC2928)
None
mashunitjeep
mashunitjeep's Reviews
12-07-2015, 02:14 AM
Price: $54.00
Pros: ITS A STABALIZER BETTE RTHE STOCK
Cons: ITS A SHOCK
Recommended? Yes
Comments: THIS IS A BETTER SETU AND STRONGER DONT LEAK AS EASY
SolarOne
SolarOne's Reviews
11-05-2015, 07:16 PM
Price: $23.00
Pros: It dampens steering, it's low in cost and as reliable as anyother Tenneco (Rancho) product.
Cons: It didn't come with a boot, factory paint job was half @$$3D.
Recommended? Yes
Comments: I'd suggest hitting this with a touch up job minimally. Mine was dropped shipped from the factory, with bare metal exposed near the weld where the shock eye meets the body. Otherwise paint appeared fine, even if I didn't touch it up, I'd expect to replace it before the body were to rust through.. I had to pick up a shock bot from the local parts store that brought my total to ~$28, at least I got my choice of color.
deerassassin22
deerassassin22's Reviews
01-07-2011, 08:00 PM
Price: $40.00
Pros: Works
Cons: None
Recommended? Yes
Comments: Good Product Great Price
Super6XJ
Super6XJ's Reviews
05-26-2010, 01:51 AM
Price: $37.00
Pros: works. better control (didnt have one on the WJ before)
Cons: no boot :(
Recommended? Yes
Comments: was gonna wait for when i was gonna order my RC lift but i figured i need it since if i go through any mud it will throw off y balance anc cause my DW. and steering and control is Alot Better not loose
will eventually upgrade to a RC 2.2
CTJeepWJ
CTJeepWJ's Reviews
07-29-2009, 11:11 AM
Price: $45.00
Pros: Easy install, seems to do work well
Cons: none yet
Recommended? Yes
Comments: I bought the Tenneco HD SS, which I have heard is made by Monroe. It seems to work well, I would recommend this to anyone with a WJ and minor modifications.
TJRubicon06
TJRubicon06's Reviews
05-24-2009, 10:58 PM
Price: $30.00
Pros: Its the same as the pro comp but cheamper and its black.
Cons: None, its a steering stabilizer.
Recommended? Yes
Comments: Its a cheaper version of most of the stabilizers you buy with brand names on them, plus its black so its not that gawdy.
4x4JeepinZj
4x4JeepinZj's Reviews
05-24-2009, 08:00 PM
Price: $45.00
Pros: Works like a charm
Cons: PIA to install
Recommended? Yes
Comments: I think it is pretty much a monroe, IRO sells it and it is made by tenneco who makes monroe. Helped firm up the steering, just a pain to get the old tapered shaft out of the drag link.
gdsamford
gdsamford's Reviews
02-23-2009, 06:39 PM
Recommended? Yes
Comments: does its job!!!! would recommend only if u have less then 3 inches of lift ....pepboys........
itasor
itasor's Reviews
01-07-2009, 11:43 AM
Price: $30.00
Pros: Cheap, as good as some of the more expensive ones, available at Advance Auto or Napa, easy to install
Cons: None...
Recommended? Yes
Comments: After getting my steering box replaced, I figured it wouldn't hurt to replace the stock steering stabilizer as well. I got the Monroe SC2928 at Advance Auto for around $30 after reading many recommendations here. It was said to be much better than stock.
I have never done any steering work, but with a pitman arm puller I was able to replace the stabilizer without any issues.
The difference is definitely noticeable. When I removed my stock stabilizer, I noticed that with only 39k miles on it, the piston had little to no resistance. The Monroe was much stiffer. My TJ seems to wander less and feels easier to control.
ThreadForumRepliesLast Post
Rough Country Steering Stabilizer Steering Stabilizers 43 05-29-2016 03:49 PM
Monroe - Monroe Reflex Shocks 9 01-05-2016 09:16 AM
Old Man Emu Steering Stabilizer Steering Stabilizers 87 07-14-2015 11:49 PM
Teraflex 9550 steering stabilizer Steering Stabilizers 9 02-08-2012 06:31 PM
KYB - Kyb Steering Stabilizer Steering Stabilizers 2 07-28-2010 01:57 PM
