JKS Quicker Disconnect Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Steering Stabilizers Next Product
Rating:
Product Information
MSRP: $153.00
Average Price: $130.06
Manufacturer: JKS
Recommended?
Yes: 45 / No: 3
Allows swift disconnection of the anti-sway bar to improve articulation of the front axle. Features greasable, rebuildable joints that allow for optimal swaybar linkage while connected and easy simplicity while disconnecting. Fully adjustable with beefy threaded center section to accomodate small to large lifts. Includes all necessary HD hardware, storage pegs and simple, detailed instructions with sticker.
None
Page 2 of 3 1 2 3 > Last
Fox01V
Fox01V's Reviews
11-19-2010, 09:41 AM
Price: $150.00
Pros: Work well and do their job
Cons: none
Recommended? Yes
Comments: These really do the job well, if your on level ground or not these are very easy to disconnect and easy to reconnect. With the storage mounts you keep your swaybar tucked up and out of the way.
MontesXJ
MontesXJ's Reviews
10-19-2010, 06:46 PM
Price: $150.00
Pros: Easy to install Looks great
Cons: None
Recommended? Yes
Comments: Love them, except one thing. I must use all my weight to pull down on the swaybar to separate the first link. I think my sway bar is warped which creates upward pressure on the link. Once the first one is out, the other disconnects with no effort. Equally difficult to reinstall the second link for the same reason. However, this is not a product issue. The problem is caused by my swaybar.
Hesher420
Hesher420's Reviews
10-10-2010, 01:22 PM
Price: $50.00
Pros: heavy duty, durable, greasable
Cons: none
Recommended? Yes
Comments: I've had these for about 3 years now so I can attest to their durability. They are in brand new condition. I just keep them well greased at all times! The disco's are incredibly easy to use if you take the time to set them up properly. The giant benefit comes when you disco them and can keep all 4 wheels on the ground off road.
Decimage
Decimage's Reviews
10-04-2010, 12:44 PM
Price: $200.00
Pros: Just got this installed and good customer service and good product.
Cons: None so far will keep updating.
Recommended? Yes
Comments: Just got this installed and good customer service and good product.
greenglazier
greenglazier's Reviews
08-27-2010, 08:30 PM
Price: $140.00
Pros: Great product
Cons: None
Recommended? Yes
Comments: Great product easy installation
YJWarrior
YJWarrior's Reviews
08-21-2010, 08:58 PM
Price: $179.00
Pros: - well made - easy to connect / disconnect - add a lot of articulation
Cons: - None
Recommended? Yes
Comments: Really like these a lot, they are made very well and are a breeze to take on and off. Lots of good travel off-road!
zanash2
zanash2's Reviews
06-21-2010, 05:15 PM
Price: $110.00
Pros: more flex
Cons: price
Recommended? Yes
Comments: flex
vague180
vague180's Reviews
06-03-2010, 06:44 PM
Price: $50.00
Pros: Easy to install, easy to unlock and lock back.
Cons: None
Recommended? Yes
Comments: Tough to put them back on unless ground is VERY level. Otherwise they work great.
Apples
Apples's Reviews
05-30-2010, 09:16 PM
Price: $125.00
Pros: Adjustable height
Cons: None
Recommended? Yes
Comments: I love the adjustable height "feature" To date Ive not had any issues and they are easy enough to disconnect
famousstar1026
famousstar1026's Reviews
05-22-2010, 02:12 AM
Price: $149.00
Pros: easy install abotu 45 min easy to use grease zerks are a plus
Cons: none
Recommended? Yes
Comments: every jeep should have a pair of jks diskos
Nicho
Nicho's Reviews
05-16-2010, 06:30 PM
Price: $140.00
Pros: Articulation
Cons: none
Recommended? Yes
Comments: Great product, added articulation, better off road control.
beserkur
beserkur's Reviews
04-08-2010, 09:34 PM
Price: $205.00
Pros: quick disconnect,can be stowed up out of the way so no damage can occur,adjustable for ride height,body leveling,easy to install.
Cons: none so far
Recommended? Yes
Comments: An improved JKS product which lives up to everything that is said about it.
These quicker discos are top of the line and great for the do-it-yourselfers out there.
TJ owners will like the fact that you can store them when off roading very quickly and easily due to 2 small holes drilled and tapped in the frame.very smart.
Did I mention that they look awesome as well?
I have no negative things to say about this product because it is far superior to the OEM part and more versatile as well.
JerseyWJ
JerseyWJ's Reviews
03-07-2010, 09:43 AM
Price: $120.00
Pros: Tougher than stock links
Cons: Price
Recommended? Yes
Comments: Good product, easy install.
Nashirak
Nashirak's Reviews
01-29-2010, 09:23 PM
Price: $140.00
Pros: Easy to use Easy to install Quiet Easy to lube
Cons: None
Recommended? Yes
Comments: Great product, worth every penny. Easy to connect and disconnect/stow. Keepers hold the links out of the way when not in use. First set of discos I've owned and I would get them again.
djt283
djt283's Reviews
08-16-2009, 07:50 PM
Price: $135.00
Pros: Great construction, easy install, quiet.
Cons: A little pricey, but none.
Recommended? Yes
Comments: Extremely well made and very easy to install. Very quiet. The pins for locking them on the frame when disconnected are convenient and it's nice they come with them to save me the hassle of making something myself. Rubber bushings have an ingenious system for distributing the grease. I have only had them on about a week so I can't comment on longevity.
Mystifire
Mystifire's Reviews
07-03-2009, 12:40 PM
Price: $143.00
Pros: Easy Install
Cons: None Yet
Recommended? Yes
Comments: Just installed these yesterday, and they fit like a champ. I have a 2" poly-spacer lift and I purchased the set designed for 2.5"-6" lifts (as opposed to the 0"-2" links) and it fits fine. Ideal angle for the sway bar on a TJ is 10 degrees above horizon and with these tightened all the way, it sits at ~7 degrees, so no fitment issues there. I plan on installing a 5.5" long arm lift in the next year, so I didn't want to waste money on the smaller ones only to have to replace them when I added this lift. They take about 1 minute to disconnect when on level ground. Unless you have a pickle fork, you must remove the sway bar and hammer the top ball joint out.
I got to use these today at Rausch Creek - I was disconnected and half aired-down before the TorX guys had their rusty links disconnected.
Zakman
A locked & armored LJ
Zakman's Reviews
05-15-2009, 08:59 AM
Price: $125.00
Pros: Great American made product. Solid components over stock.
Cons: Torx bolts in stead of hex bolts used.
Recommended? Yes
Comments: Have yet to really try them off. Only issue is the use of Torx head bolts vs hex head bolts.
Libtekguy
Libtekguy's Reviews
01-08-2009, 04:00 AM
Price: $136.99
Recommended? Yes
Comments: Easy install only requiring a few hand tools and a drill. (for the stud that you hang you discos on when they are disconnected)
The hardest part was tapping the hole for said stud.
These discos are very easy to install and remove, if you are level ground.
canyon47
canyon47's Reviews
12-28-2008, 11:35 PM
Price: $150.00
Recommended? Yes
Comments: Pretty Decent, bought them to replace the stock ones I broke. I like how they can adjust for a 0-2" lift.
portcityXJ
portcityXJ's Reviews
12-14-2008, 10:50 PM
Pros: easy to connect/disco.
Cons: pricey. you get what you pay for though!
Recommended? Yes
Comments: top notch. beefy design. adjustable to fit multiple lift heights. also comes with good instructions. its just a PITA to remove the stock links
ThreadForumRepliesLast Post
Warrior Quick-Disconnect Sway Bar Links Steering Stabilizers 4 05-16-2012 09:23 PM
