Savvy Offroad - Savvy/Currie Aluminum Adjustable Lower Control Arms TJ/LJ Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & Ham Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating: None
Product Information
MSRP: $299.99
Average Price: $542.50
Manufacturer: Savvy Offroad
Recommended?
Yes: 4 / No: 0
Company Website: http://www.savvyoffroad.com
TJ/LJ LOWER JOHNNY JOINTŪ CONTROL ARMS For 1997-2006 Jeep TJ's and Unlimited's. The Johnny JointŪ lower control arms are fully adjustable with thread Johnny Joints on both ends so that you are able to adjust your pinion angle after a lift is installed. The arms are fabricated out of 1.5" 7075 Aluminum rod and feature the Johnny JointŪ on both ends of the arms. The arms are 7075 Aluminum drilled and tapped with a wrench flat to ensure you can get them tight. Sold as a pair and INCLUDES greasable bolts.
The ARMS come with a Lifetime Warranty. Defined as should they fail or break in normal driving condition or off road activities we will replace them. Loose joints is not a failure but will cause them to fail. So make sure the joints are tight at all times. CURRIE WARRANTY ON THE JJS.
WARNING! THESE MUST BE CHECKED TO INSURE THE JOINTS ARE TIGHT WHEN INSTALLED. PERIODIC INSPECTION IS REQUIRED. LOOSE JOINTS CAN CAUSE THE LINKS TO FAIL RISKING INJURY OR DEATH!
None
Kaffa
Kaffa's Reviews
03-20-2016, 04:54 PM
Price: $1.00
Pros:
Cons:
Recommended? Yes
Comments: ...
edinct
edinct's Reviews
11-09-2013, 02:43 PM
Price: $1,000.00
Pros: great quality, double adjustable, wont rust
Cons: non
Recommended? Yes
Comments: doesn't get any better than Savvy double adjustable aluminum control arms.
wusmc71
wusmc71's Reviews
10-12-2013, 08:39 PM
Price: $900.00
Pros: everything
Cons: none
Recommended? Yes
Comments: .............
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Reviews
03-30-2012, 06:41 PM
Price: $269.00
Pros: Adjustable on the Jeep, Johnny Joints at both ends, shiny, tons of adjustability
Cons: Jam nuts have loosened up twice (could have been my fault)
Recommended? Yes
Comments: I ordered these after being annoyed with adjusting the Currie single adjustable rear uppers on the wife's Jeep. These were by far the easiest control arms I ever put on a Jeep. I took the old ones off (swapped one for one), bolted on one end, stuck the other end into the bracket and adjusted it by hand until the bolt hole lined up. I then added the bolt and adjusted it by hand to where I wanted it set. Once two lowers were added it took it for a ride to make sure there were no issues. You can install 2 arms in about 30 to 45 minutes. One of the best things you gain is the amount of adjust ability, the old single adjustables would have to be spun 180 degrees in or out, the new arm utilize every single little bit of adjust ability. Make sure the new JJ are grease right away.
The Jeeps suspension no longer has that "wandering" feeling and feels really tight. It is a whole new Jeep! The JJ add less stress to the mounts as well during articulation. These are a must have for any Jeeper and the money is WELL WORTH IT!
The only con I have is after my initial test drive I had one jam nut come loose. I cranked the crap out of all of them again. The next day my wife drove her Jeep to work, when she got home I check again only to find a different nut loose. I got underneath and re checked and tightened every Jam nut again. It has been a week not with not another one coming loose but because of the initial issue I will be sure to check it routinely.
Update 5-12-12
Another Jam nut loose. Not sure why I can not get these things tight enough.
ThreadForumRepliesLast Post
rough country Adjustable greasable front upper and lower control arms Control Arms 8 08-15-2016 04:21 PM
Rough Country - X-Flex Adjustable Control Arms Lower Control Arms 15 05-29-2016 02:38 PM
Iron Rock Offroad Adjustable Control Arms Control Arms 19 05-04-2016 11:13 AM
Rock Krawler Adjustable control arms Control Arms 8 12-02-2015 08:25 PM
Rusty's Off Road Adjustable Front Lower Control Arms Control Arms 9 06-07-2015 08:29 PM
