Go Back JeepForum.com > Reviews > Suspension > Control Arms > Rubicon Express RE3700
Rubicon Express RE3700 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating:
Product Information
MSRP: $200.00
Average Price: $454.64
Manufacturer: Rubicon Express
Recommended?
Yes: 9 / No: 2
CONTROL ARM SF2 LOWER FIXED
All Super-Flex Control Arms feature our rebuildable spherical bearing assembly. This assembly features a large 2.25" polymer race that encapsulates a 1.75" hard plated steel bearing. A threaded steel insert allows adjustable preload and easy maintenance. The unit is greasable and extremely quiet due to the non-metallic races. This bearing allows extra flex for off-road prowess, yet does not sacrifice on-road handling or long term durability.
thirdeye
Poke'mon Master
thirdeye's Reviews
01-03-2011, 08:40 PM
Price: $230.00
Pros: Flex joint
Cons: rubber bushing
Recommended? Yes
Comments: RE adjustable lower control arms. Pretty solid and good quality.
Vince Greva
Vince Greva's Reviews
11-07-2010, 01:10 AM
Price: $1,000.00
Pros: Great amount of adjustment, fantastic flex
Cons: none yet
Recommended? Yes
Comments: This is a must have on any lift...adjustment means proper angles, correct wheel base, and proper amounts of caster...
93ZJ_5.2_ca
93ZJ_5.2_ca's Reviews
07-01-2010, 12:37 PM
Price: $1,000.00
Pros: These arms came off my ZJ and worked out great for the TJ
Cons: None
Recommended? Yes
Comments: I drove with these on my ZJ for 75,000 miles and they are as nice as the day I put them on.
cbenez1
cbenez1's Reviews
06-07-2010, 04:20 PM
Price: $200.00
Pros: They do what they are meant to do.
Cons: None
Recommended? Yes
Comments: Easy install. Have had no problems with them. They do what they are meant to do
Hesher420
!!! SLAYER !!!
Hesher420's Reviews
04-27-2010, 10:13 PM
Price: $100.00
Pros: rubber (not poly) bushing, heavy duty
Cons: could be better w/ spherical joints both ends
Recommended? Yes
Comments: I bought these arms from a fellow JF member and am very happy with the quality of them. After 12k miles the bushings are still in great shape
LOCKED UP
Senior Web Wheeler
LOCKED UP's Reviews
04-08-2010, 08:24 AM
Price: $100.00
Pros: Easy to install and relatively cheap
Cons: Stupid hourglass bushings that were bad
Recommended? No
Comments: I installed the fixed lower control arms on my TJ only to have the bushings fail nearly instantly. RE sent replacements because they said they had a "bad run" of bushings but still ... PITA to change the bushings out. Other than that the arms were fine but I'd really recommend to anyone thinking of buying fixed LCAs to spring for the adjustable ones. they are much, much better.
joeroe
joeroe's Reviews
12-11-2009, 01:03 AM
Price: $900.00
Pros: good flex
Cons: Arms were trashed after 5 trips off road.
Recommended? No
Comments: They came with the RE 4.5" SF kit. $900 if bought separate.
Install was done just like the directions recommended (Jeep was on the ground when the arms were tightend) Rubicon said they had a bad batch of bushings but according to what I've read they have been saying that for years. There are people that say they have had good luck with these arms so don't take my word for it do some research before you buy. If you still want to buy these arms I'll be rebuilding mine and selling them after I purchase some Rokmen arms.
If you don't take your jeep off road these might be alright.
Boodyrider
Boodyrider's Reviews
11-01-2009, 01:14 AM
Price: $800.00
Pros: adjustable arms, full set of 8
Cons: price - ouch, this was used!
Recommended? Yes
Comments: No option for a full set of SF2 arms, so this was the selection. I like being able to adjust all the arms, and the flex is good. Rebuildable joints, fairly strong for shortarms, handle abuse well.
beneharis
beneharis's Reviews
03-20-2009, 12:47 AM
Price: $1.00
Recommended? Yes
Comments: these are very good control arms. they have held up nicely. i bought them used and the bushings were shot, but that can't be held against RE since it was the last owner who did that
DeconsTructionJ
DeconsTructionJ's Reviews
04-27-2008, 08:18 PM
Price: $200.00
Pros: great flex thanks to sf joint, easily serviceable wear parts
Cons: none
Recommended? Yes
Comments: great control arm, both the sf bushing and the rubber bushing are easy to replace
ThreadForumRepliesLast Post
Rubicon Express Monotube Shocks 40 04-11-2011 02:00 PM
Rubicon Express 4" standard kit YJ Complete Lift Kits 17 10-19-2010 11:00 PM
Rubicon Express RE5505 Complete Lift Kits 4 01-04-2010 08:46 AM
Rubicon Express 2 1/2 " Spring - Over Complete Lift Kits 2 03-02-2009 12:01 PM
Rubicon Express RE7002 Complete Lift Kits 8 04-29-2008 12:03 PM
Glock Forum
