Go Back JeepForum.com > Reviews > Suspension > Control Arms > rough country Adjustable greasable front upper and lower control arms
rough country Adjustable greasable front upper and lower control arms Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating:
Product Information
MSRP: $400.00
Average Price: $252.50
Manufacturer: rough country
Recommended?
Yes: 5 / No: 1
A full kit for the front control arms. Comes with two sets upper and lower adjustable control arms and bushings, zerk fittings. Aweseom idea for those who may want to go bigger in the future and would need the room for movement.
Good buy, would recommend
Fully adjustable control arms replace your factory stamped sheet metal OE arms and allow for better articulation and more control off road but does not sacrifice on road handling. They are fully greasable, and come with highly durable polyurethane bushings.
chutta
chutta's Reviews
11-23-2009, 06:37 PM
Price: $400.00
Pros: adjustability
Cons: thin non robust internal thread design in the sleeve
Recommended? No
Comments: I had 2 lowers strip the threads, allowing front to back axle slop/klunks likely contributing to my cv shaft's centering ball/socket failure.
After discovering that the arm doesn't rotate thru the full stuff/droop range, I welded both lowers to solidify the geometry.
Get the arms with the jamnut and heim joint.
StvDiego
Misconfigured DNS
StvDiego's Reviews
10-21-2009, 08:38 AM
Price: $20.00
Pros: Better than stock
Cons: Bushing wear out quickly, zerk fittings exposed to damage
Recommended? Yes
Comments: Rough Country is still one of the best for the budget Jeeper. These control arms are from the X-Series lift designed again for the budget-minded Jeeper. Fit and finish quality is up to Rough Country standards which means, not bad. Installation is straight forward. RC still uses rubber bushings which are better for flex than poly, not as good as Johnnie Joints but they will wear out in a year under heavy use.
For someone looking to save money and still get an acceptable lift and adjustable arms, Rough Country is the way to go
Heavylift
Heavylift's Reviews
07-08-2009, 07:20 PM
Price: $425.00
Pros: Really increased the articulation of the front and rear axles.
Cons: None
Recommended? Yes
Comments: Bought each set separately; all on ebay auctions:
Front lowers 116$
Rear lowers 77$
Rear upper 82$
Front uppers 150$
fireball27190
fireball27190's Reviews
03-10-2009, 09:42 PM
Price: $170.00
Recommended? Yes
Comments: bought the new design upper rear arms and all I can say is WOW. these are beefy arms and the price was great too given im still in college. The ride quality is still good. Great to have when you install a SYE and a longer driveshaft.
91Woody
91Woody's Reviews
05-21-2008, 03:02 PM
Price: $100.00
Recommended? Yes
Comments: only have adj. uppers waiting to be installed, I have the fixed lowers and have no complaints aside from trying to find a replacement zirk fitting that actually fits
hocgreen
hocgreen's Reviews
05-13-2008, 01:09 AM
Price: $400.00
Recommended? Yes
Comments: Fits right in where the stock parts come out. Fully adjustable and work wonders. Would never have a problem recommending these to anyone. Eliminates the need for control arm skids. A little squeeky for my taste, but that is the only draw back.
ThreadForumRepliesLast Post
Rough Country 3" Lift Kit w/ Control Arms Complete Lift Kits 10 02-09-2010 05:51 PM
Rough Country - X-Flex Adjustable Control Arms Lower Control Arms 4 01-05-2010 02:30 AM
Rusty's Off Road Adjustable Front Lower Control Arms Control Arms 4 08-26-2009 02:49 PM
Rough Country Adjustable Front Track Bar Track Bars 6 03-10-2009 09:45 PM
Rough Country Adjustable Uppers Control Arms 2 02-02-2009 11:02 PM
Glock Forum
