Go Back JeepForum.com > Reviews > Suspension > Control Arms > Rock Krawler Adjustable control arms
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Rock Krawler Adjustable control arms Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating:
Product Information
MSRP: $160.00
Average Price: $411.67
Manufacturer: Rock Krawler
Recommended?
Yes: 6 / No: 0
Rock Krawler mfgrs both front and rear upper and lower adjustable control arms. Google Rock Krawler for more info or go to www.rockkrawler.com.
thirdeye
Poke'mon Master
thirdeye's Reviews
07-29-2010, 05:52 PM
Price: $180.00
Pros: Adjustable, strong
Cons: With the front uppers, you have to bend the mounts on the frame because the flex joint is smaller than stock.
Recommended? Yes
Comments: Solid, relitavly cheap, flex joint. Very good, but if you are willing to spend a little more cash, something else might be a little better.
DustPuppy
DustPuppy's Reviews
06-02-2010, 11:12 PM
Price: $150.00
Pros: Great range of flex.
Cons: Stiffer ride than OEM control arms.
Recommended? Yes
Comments: A preferable solution to ProComp fixed arms for the price, IMO. Best when uppers can be installed along with lowers. Note: when promper caster is restored, the slight increase in wheelbase may cause light rubbing on the fender flares at full stuff, depending on what tires you run.
Hesher420
!!! SLAYER !!!
Hesher420's Reviews
04-27-2010, 10:07 PM
Price: $150.00
Pros: Heavy Duty, Round joint on axle end
Cons: Poly joint on frame end
Recommended? Yes
Comments: I purchased the arms used from a fellow JF member and am very happy with them. Heavy duty construction made of solid alloy steel and come with the RockKrawler Lifetime Warranty
Mrozandy
Mrozandy's Reviews
08-21-2009, 04:56 PM
Price: $230.00
Pros: These things are beefy. Very well built and good lookin. Direct replacement of factory arms.
Cons: Not free
Recommended? Yes
Comments: I originally ordered them to solve a wandering problem I had from my cheap lift kit (uses stock arms and caster bolts). I was very impressed when I took them out of the box, I did'nt expect them to be so high quality, these things are NICE! They were easy to adjust and install. They look really cool, especially from the front. And these are not just pipes with ends on them, these are litterally solid steel. I am slowly replacing all of my suspension components with Rock Krawler parts. I have already ordered their Drag link flip kit with the "Bomb proof" Drag link,Track bar and weld in track bar lift bracket.
Pillswoj
Pillswoj's Reviews
06-21-2009, 08:40 PM
Price: $1,600.00
Pros: Excellent Price, beefy construction, Joints are rebuildable without special tools. 4 link rear gets rid of trackbar for more rear flex.
Cons: Both ends of arms are RH thread so you still have to drop the arm to adjust the length.
Recommended? Yes
Comments: Just installed these arms / tri SA rear to replace the skyjacker crap I had. The ride is much better as is the flex. It is to early to comment on the durability of the joints. as compared to the Skyjacker it is great.
rlanderton
Red Rock 4-Wheeler
rlanderton's Reviews
11-12-2008, 11:36 AM
Price: $160.00
Recommended? Yes
Comments: Installed Rock Krawler front upper adj control arms as a part of the OME lift kit install. Very easy to adjust front caster and I attribute this to the good ride thus far - highway only, will report back when I get some offroad miles.
ThreadForumRepliesLast Post
Rough Country - X-Flex Adjustable Control Arms Lower Control Arms 4 01-05-2010 02:30 AM
rough country Adjustable greasable front upper and lower control arms Control Arms 6 11-23-2009 06:37 PM
Iron Rock Offroad Adjustable Control Arms Control Arms 5 10-06-2009 01:42 PM
Rusty's Off Road Adjustable Front Lower Control Arms Control Arms 4 08-26-2009 02:49 PM
Rock Krawler RK 6.5" Coils - XJ Springs 0 12-02-2007 06:39 PM
Glock Forum
