Go Back JeepForum.com > Reviews > Suspension > Control Arms > JKS Lower Adjustable, PN 6100
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
JKS Lower Adjustable, PN 6100 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Control Arms Next Product
Rating:
Product Information
MSRP: $500.00
Average Price: $334.38
Manufacturer: JKS
Recommended?
Yes: 13 / No: 0
Take CONTROL of your Jeep® suspension with new upper and lower Control Arms from JKS. The adjustable design allows the user to control caster and pinion angle, as well as position the axle housing for proper tire clearance. Furthermore, each end of the control arm can rotate independently to accommodate extreme suspension travel off-road.
JKS Control Arms utilize greasable brass bearings for smooth, reliable operation and excellent longevity. Fine pitch adjustment threads ensure superior strength and unsurpassed tuning ability. With over 3" of adjustment, the working length of each JKS Control Arm can be increased, decreased or exactly the same as the OE suspension arm.
Constructed of heavy-gauge steel tubing and MIG welded for quality and consistency, our Control Arms are much stronger and resistant to impact than the original suspension arms. New OE rubber bushings are used to isolate road noise and vibrations without over-stressing the mounting brackets. Finally, a durable powdercoat finish and zinc plating provide excellent corrosion protection.
chopperkid2000
Hey man, Check this out !
chopperkid2000's Reviews
08-04-2011, 06:14 PM
Price: $1.00
Pros: Clevite both ends
Cons: Not sure yet
Recommended? Yes
Comments: I like the clevite both ends. Little to no maintenace
ZJ Raven
ZJ Raven's Reviews
07-02-2010, 01:40 PM
Price: $1,200.00
Pros: Strong, and rotate to accomendate the axle movement, Graseable.
Cons: None as of yet
Recommended? Yes
Comments: 1200.00 for Front/Rear Upper/Lower Package (8)
Absolutely recommend for any lift beyond budjet of 2.5" to 6" Lift
my rear lower to direct hits and survived... with only cosmetic sratches that would have damaged the stock control arms.
NorCOWJ
NorCOWJ's Reviews
03-18-2010, 09:20 PM
Price: $200.00
Pros: size quality
Cons: spacing in factory brackets
Recommended? Yes
Comments: big control arms with zerk fittings are a plus. no jam nut to come loose. these are the heaviest duty control arms out there. the downfall of these is that you have to shim them with washers when installed on the wj because the brackets are to wide
famousstar1026
famousstar1026's Reviews
03-14-2010, 05:10 AM
Price: $600.00
Pros: beefy , fully adjustable no jam nut spring loaded rotates while flexing
Cons: a bit pricey
Recommended? Yes
Comments: i bought rubicon express superflex arms was not to impressed on the style and quality decided to go with these we'll see how the do
limeking
limeking's Reviews
11-19-2009, 09:47 AM
Price: $290.00
Pros: heavy, adjustable and greaseable
Cons: pricey
Recommended? Yes
Comments: Love them but some of the grease fittings where bad.
DoinSumthin
DoinSumthin's Reviews
10-07-2009, 09:15 PM
Price: $350.00
Pros: Not certain of the price. But its in that range. Very easy install, HEAVY and DURABLE! These have grease points on them, which was a good selling point. I dont see myself ruining these anytime soon reguardless of the abuse I put them through.
Cons: None
Recommended? Yes
Comments: Go buy some!
rstolz
rstolz's Reviews
03-24-2009, 03:35 PM
Price: $129.00
Recommended? Yes
Comments: Love JKS stuff. I will be buying more stuff from them. These were an easy install and are fairly easy to put on. Sometimes it takes a little convincing to get them on, but always doable, and without tools.
IceKnight
IceKnight's Reviews
10-17-2008, 08:37 PM
Price: $322.00
Recommended? Yes
Comments: WOW...install was a breaze and they are so smooth. A quite ride after installing these. Cant wait untill I replace uppers also.
Jeepers76
Jeepers76's Reviews
05-05-2008, 08:37 PM
Price: $130.00
Recommended? Yes
Comments: The best LCA for articulation.
Prerun
Prerun's Reviews
04-17-2008, 03:47 PM
Price: $250.00
Recommended? Yes
Comments: Very Beefy!
WKENDWARIOR69
WKENDWARIOR69's Reviews
04-13-2008, 12:15 AM
Price: $250.00
Recommended? Yes
Comments: Great & Strong
StrokedWJ
StrokedWJ's Reviews
04-10-2008, 09:11 PM
Price: $125.00
Recommended? Yes
Comments: best SA's out there
Islidur
Islidur's Reviews
04-07-2008, 12:49 AM
Price: $500.00
Recommended? Yes
Comments: Haven't gotten them on the trail yet, but they're beefy and well built
ThreadForumRepliesLast Post
JKS Adjustable Trac-Bar Track Bars 26 09-26-2011 03:27 PM
BDS Adjustable Front Trackbar Track Bars 3 03-18-2010 12:13 AM
Rough Country - X-Flex Adjustable Control Arms Lower Control Arms 4 01-05-2010 02:30 AM
rough country Adjustable greasable front upper and lower control arms Control Arms 6 11-23-2009 06:37 PM
Rusty's Off Road Adjustable Front Lower Control Arms Control Arms 4 08-26-2009 02:49 PM
Glock Forum
