Go Back JeepForum.com > Reviews > Suspension > Control Arms > JKS Adjustable Rear Upper PN 7101
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
JKS Adjustable Rear Upper PN 7101 Reviews, Ratings, Specs & Prices
Review Categories
Armor
  Bumpers
  Differential Guards
  Rocker Guards
  Roll Cages
  Skid Plates
Audio, CB, & Electrical
  Audio Players
  Batteries
  CB & HAM Radios
  GPS
  Speakers
Axles
  Axle Shafts
  Brakes
  Gears
  Hubs
  Lockers
  Steering
Body
  Body Lifts
  Consoles, Security & Storage
  Exterior Accessories
  Fender Flares
  Lighting, Lenses & Bulbs
  Roof Racks & Cargo Areas
  Tops
Engine
  Alternators
  Carburetors
  Chips
  Exhaust
  Headers
  Induction
  Internal Parts
  Motor Mounts
  Starters
  Throttle Body
Interior
  Gauges
  Misc
  Seats
Recovery
  Winch Cable and Hooks
  Winches
Suspension
  Complete Lift Kits
  Control Arms
  Shocks
  Springs
  Steering Stabilizers
  Track Bars
Tires & Wheels
  Tires
  Wheels
Transfer Case
  SYE Kits
  Transfer Cases
Transmissions
  Transmissions
Previous Product Control Arms Next Product
Rating:
Product Information
MSRP: $264.00
Average Price: $715.43
Manufacturer: JKS
Recommended?
Yes: 7 / No: 0
Take CONTROL of your Jeep® suspension with new upper and lower Control Arms from JKS. The adjustable design allows the user to control caster and pinion angle, as well as position the axle housing for proper tire clearance. Furthermore, each end of the control arm can rotate independently to accommodate extreme suspension travel off-road.
JKS Control Arms utilize greasable brass bearings for smooth, reliable operation and excellent longevity. Fine pitch adjustment threads ensure superior strength and unsurpassed tuning ability. With over 3" of adjustment, the working length of each JKS Control Arm can be increased, decreased or exactly the same as the OE suspension arm.
Constructed of heavy-gauge steel tubing and MIG welded for quality and consistency, our Control Arms are much stronger and resistant to impact than the original suspension arms. New OE rubber bushings are used to isolate road noise and vibrations without over-stressing the mounting brackets. Finally, a durable powdercoat finish and zinc plating provide excellent corrosion protection.
ZJ Raven
ZJ Raven's Reviews
07-02-2010, 01:43 PM
Price: $1,200.00
Pros: Strong, and rotate to accomendate the axle movement, Graseable.
Cons: None As of Yet
Recommended? Yes
Comments: Absolutely recommend for any lift beyond budjet of 2.5" to 6" Lift
my rear lower to direct hits and survived... with only cosmetic sratches that would have damaged the stock control arms.
famousstar1026
famousstar1026's Reviews
05-22-2010, 01:05 AM
Price: $2,590.00
Pros: beefy greasable easy adjustments
Cons: pricey
Recommended? Yes
Comments: worth every penny highly recommended
Plate
I'd Hit It
Plate's Reviews
05-17-2010, 07:42 PM
Price: $277.00
Pros: Simple to install. Easy to adjust pinion angle. Great price as always from Northridge.
Cons: Free shipping took nearly a week to arrive, but to be expected.
Recommended? Yes
Comments: 10 char
TiredOldMan
TiredOldMan's Reviews
02-23-2009, 10:24 AM
Price: $264.00
Recommended? Yes
Comments: Nice beefy control arms. Love the engineering that went into them and the OEM rubber bushings. When you consider the extra work and materials that go into these control arms the price is reasonable.
apexjeepinjoe
apexjeepinjoe's Reviews
07-04-2008, 09:55 PM
Price: $247.00
Recommended? Yes
Comments: All of the JKS products I have purchased have been awesome. Easy to use and great quality.
flatlander757
Now in the 937
flatlander757's Reviews
04-15-2008, 09:11 PM
Price: $180.00
Recommended? Yes
Comments: Work very well, easy to adjust, no noises, greasable.
Islidur
Islidur's Reviews
04-07-2008, 12:58 AM
Price: $250.00
Recommended? Yes
Comments: Nice arms
ThreadForumRepliesLast Post
Currie Rear adjustable uppers Control Arms 9 02-18-2011 08:41 AM
Teraflex TJ Wrangler Rear Adjustable Trackbar Track Bars 2 12-07-2009 05:32 PM
JKS Adjustable Front Upper PN 7100 Control Arms 3 11-29-2009 03:44 PM
rough country Adjustable greasable front upper and lower control arms Control Arms 6 11-23-2009 06:37 PM
TeraFlex Rear Upper Adj. Control Arms Control Arms 5 06-17-2009 02:46 PM
Glock Forum
