Currie Rear adjustable uppers
Rating: |
Product Information
| MSRP: |
$284.99 |
| Average Price: |
$336.00 |
| Manufacturer: |
Currie |
| Recommended? |
Adjustable upper rear control arms using Currie's Johnny joints.
The Johnny Joint® rear upper control arms are fully adjustable so that you are able to adjust your pinion angle after a lift is installed. The arms are fabricated out of 1" heavy wall D.O.M. tubing and feature the Johnny Joint® on both ends of the arms. Sold as a pair.
cavmedic's Reviews
Price: $200.00 Pros: Great Joints Cons: none Recommended? Yes
Comments: Simple install, fixed rear CV angle
J+A's Reviews
Price: $240.00 Pros: easy to understand instructions Cons: none Recommended? Yes
Comments: I purchsaed these control arms based on the reviews of this forum. And I was not disappointed with this product.
J+A's Reviews
Price: $240.00 Pros: Easy install and great instructions Cons: none Recommended? Yes
Comments: I chose these control arms because of the reviews on this forum. And I have to agree these where a great purchase.
greenglazier's Reviews
Price: $259.00 Pros: easy to install great product Cons: none Recommended? Yes
Comments: installation was easy and this is a graet quality product
Weelz's Reviews
Price: $980.00 Pros: Easy install. Tough. Moderately priced. Cons: Mediocre installation instructions. Recommended? Yes
Comments: This review (and the price) is for the full 8-arm kit (front and rear uppers and lowers) from Savvy. Moved up to 35s and decided I needed some beefier control arms. Adjustment and install was quite easy. Control is much improved. Lots more confidence in the handling both on and offroad. I feel these are the best overall value in a control arm kit. Some manufacturers' arms are a bit stronger. Some are a bit less expensive. I sincerely believe the Curries are the optimal mix of price, performance (i.e., better "control" and flexibility), and toughness. Install instructions were kinda lame, but Jeepforum and other sources provided ample info.
Richd1963's Reviews
02-18-2011, 08:41 AM |
Price: $259.99 Pros: Johnnie joints, grease fittings, all hardware. PRICE Cons: single end adjustable. Recommended? Yes
Comments: I would have rather had them be a little beefier and if they could have been adjustable from the center like steering linkage for alignment, rather than having to have to take one end off to screw it in or out for adjustment. They are top notch quality, construction and finish. Good price too.  Quadratrec
RaggedOleMan's Reviews
Price: $550.00 Pros: Outstanding quality Cons: Incomplete directions Recommended? Yes
Comments: I installed the Currie front upper mounts, Currie front uppers and Currie front lowers. Very happy with them and would recommend them.
Z-man246's Reviews
Price: $0.01 Pros: Johnny Joints
Well Made Product Cons: none Recommended? Yes
Comments: No Comment
attackcammel's Reviews
Price: $775.00 Pros: can adjust pinion algle and wheel base
bought a set of all 8 Cons: none Recommended? Yes
Comments: These contrl arms are beefy. I installed them in one night. and took them wheeling the next day. they preformed great.
Zakman
 A locked & armored Sport |
Zakman's Reviews
Price: $220.00 Pros: Dual Jonny Joints, DOM tubing, adjustability. Cons: None so far Recommended? Yes
Comments: Dual JJs on DOM tubing. JJs ride muh better than stock OE rubber bsuhings. Greasable and abjustable to dial in the pinion angle.
ksquier89's Reviews
Price: $250.00 Pros: awesome product Cons: price Recommended? Yes
Comments: Pure beef, love it. The feel of the ride is also fantastic. Probably going to replace uppers later this year.
paydirtdave's Reviews
Price: $770.00 Pros: Adjustable upper's and lowers full 8 piece set finger lick-in good Cons: Poor installation instructions, More maintenance required than stock arms, Only good for 0" - 4" of lift Recommended? Yes
Comments: Parts where shipped fast and at a very good cost. Costumer service was helpful and friendly. Came with some good swag as well
vilseck21's Reviews
Price: $229.00 Pros: Its a currie Cons: Some say the Rokman is better, I dont think its 80 dollars better however Recommended? Yes
Comments: A must have for a SYE, this dont cost much more than cheapies and they have dual JJ
oj707's Reviews
Price: $250.00 Pros: strong. love the jonny joint Cons: not alot of ajustment Recommended? Yes
Comments: great control arms.
jlclar09's Reviews
02-12-2009, 10:46 PM |
Price: $284.99 Recommended? Yes
Comments: Good and strong. Very fast shipping direct from manufacture. Very detailed install instructions
Takota's Reviews
10-13-2008, 12:12 AM |
Recommended? Yes
Comments: CURRIE, what more can you say about that?! Once again, you need 75 characters!
BlackBellamy's Reviews
09-30-2008, 09:56 AM |
Price: $200.00 Recommended? Yes
Comments: Johnnie joints slightly increase flex and a quality product overall. Painted them black because I don't like the gold.
Hrothgar's Reviews
04-22-2008, 01:07 PM |
Price: $120.00 Recommended? Yes
Comments: good quality adjustable upper control arms. They flex well. Greasable johnny joints. However, no where to bolt the emegency brake cable to like on the stock arms, and have notice my cables rubbing on the arms. For that reasons I give them a six, otherwise an 8 or 9.
